10 lý do tại sao đầu đọc không thể đọc đĩa & cách xử lý
Discussion in 'Thiết bị số' started by tamtam, 12/1/10.
  1. tamtam
    tamtam Advanced Member
    SAIGON
    Vừa qua, sau khi chạy rà em Esoteric X10W sau khi thay tụ, đầu đĩa em lại không đọc được đĩa xịn. Lọ mọ vệ sinh mắt rồi cân chỉnh và đọc tài liệu trên mạng, em phát hiện ra trang web tuyệt vời này phát hiện bệnh về mắt và cách cứu chữa bao gồm cả hình ảnh. Mời các Bác cũng tham khảo:
    http://www.lampizator.eu/LAMPIZATOR/TRA ... ology.html
    Trích đoạn dưới đây hy vọng giúp các Bác nào bị đầu CD vật khổ sở như em.
    Laserology
    Some thoughts about laser failures that never happened.
    And about those that did.
    Hey, do you know where I can buy a new laser for my CD? It just died.
    I heard it so many times that I decided to write about lasers, their problems and easy fixes.
    I looked inside over 100 CD players which DID NOT READ the CD anymore and only one (in decimal and binary mode it is 1) had failed laser. And that one was dead because of my stupidity. But it (my stupidity) is not the subject of this article.
    Other peoples stupidity is.
    Anyway, what happens is that there is probably 20 different reasons why the CD player does not read the disc, and people have such strong prejudice that they all call these failures DEFECT LASER.
    This is CRIMINAL because lasers are not produced anymore, and the scarce resources left, the holy reserves - are brutally cannibalized by people who know no better and simply buy the new units.
    The top ten reasons why CD's are not read - according to "my vast experience" in that matter - are:
    1. There is a CD disk inside the player as resulting from moving to a different house with the disc left in the drawer. Disc falls out into the guts of the CD player and blocks the mechanism. When the owner puts second disk afterwards - the player rightly displays ERROR.
    - remedy: the first cure that springs to my mind is - open the CD and remove the stuck CD.
    2. The 20 year old belt that powers the drawer starts slipping or breaks. After closing the drawer - CD is not properly positioned on the spindle.
    - remedy: replace the belt
    3. The CD player was being used in a dusty environment and the dust or cigarette tar settled on the laser optics. Dust causes beam dispersion. Laser looses focus.
    - remedy: open the player and clean the laser surface with a Qtip. First- with wet tip dipped in the window cleaning liquid, then - dry one.
    If this is not enough - clean the laser INSIDE the reading head. This is for advanced people. Better to give this job to a watch repair man. See below - some pics.
    4. The power supply of the laser circuit is defective: either too low voltage, or noisy, or starts oscillating from poor filtering or regulation. The cause may be dried out electrolytes.
    - remedy: replace all electrolytes in the digital part of PCB, or better - all of them.
    5. There is a cold joint in the laser circuit.
    - truth is that the solder joints do corrode and do fail. Our best players are 20 years old and this shows. A joint which is hot, like a leg of a regulator, or a point where the raw supply is rectified, or a laser power controller - from the heat they develop accelerated deterioration - mixture of oxidation, flux burning, and tin evaporation.
    - remedy - look at all solder joints, especially around laser cable connectors, around all regulators, around places that look toasted, brownish or cooked - and re-solder these points adding a bit of fresh solder with fresh flux.
    6. Moving cables - or ribbons - do get broken after a million bends.
    Check for continuity in flexing ribbons leading to the laser, the drawer, the motor or the tracking mechanics.
    7. The tracking mechanism accumulates dirt, hairs or dust on the greasy part and the tracking can not arrive at the center-most starting position. With every ride of the tracking - the dirt is pushed away and forms a sort of a "bumper" that stays on each side of the shaft.
    - remedy: clean the tracking shafts, axis and rods at their extreme ends.
    8. The main motor is not keeping the right speed.
    - it will look like the laser can't read, but it is simply the wrong rotation speed. May be caused by CD slipping on the spindle, or motor defect, or something blocking the CD like audible friction against the surface of the drawer. For instance - the spindle can wear off its bottom bearing and the whole CD will be lower by 1/10th of mm. The laser will loose focus and the top clamp will not press hard enough. In any event - the spindle must be brought back up this 1/10th of mm.
    - remedy - if the motor is just a normal Mabuchi for 5 bucks - replace it. If it is a CDM or KSS Magnetic series with brushless motors - just adjust the spindle height.
    9. There is a hair or something else inside laser focusing mechanism
    The laser can't freely move up and down. Since CD is strongly electrostatic - it attracts hair, dust and animal furs. During playback - these can get caught under laser focusing suspension.
    - remedy - remove the obstacle.
    10. The CD does not spin.
    After closing the drawer nothing happens and defect is displayed. It maybe just the result of not spinning at all. The CD behaviour must be observed - so the top cover must be removed.
    CD laser diagnostics - a quick guide
    Is CD laser really dead ?
    Without specialized equipment we small mortals can diagnose the problem pretty well and save tons of money on service.
    Or even new laser purchase. Or even a new player.
    1. Open the player's hood
    2. Put the original factory made CD with clean surface and press drawer CLOSE button.
    3. Does the drawer close fully?
    4. If 3 is yes, then does the CD spin at all?
    5. If 4 is yes, does it spin for 2-3 seconds or for over 10 seconds? Does it spin VERY FAST like crazy or with somewhat controlled speed ?
    6. If the 5 answer is - controlled speed and 2-3 seconds - the laser is alive and it can detect the beam reflection from silver surface.
    Tips: if the laser is dead, the CD will not spin at all. The CD motor has a signal to start spinning only after the laser heads reports: "reflective surface detected on the height where CD is expected to be ". However, as someone rightly pointed out, some servo mechanisms will try spinning without checking if CD is in place or not. Apparently, they made assumption that a small motor spin in vain will not hurt.
    7. Does the display show after 3 s of spinning the correct number of tracks and time ?
    If the CD was spinning but can not show time - it means it could not read the TOC - famous Table Of Contents. So the laser head was seeing the disc surface but could not read the first line of data. This first line is at the very center of CD disc, so the tracking of the laser assembly must be on position "center most". The inner-most position. So if we have a tracking problem - we cant move to the very center and TOC cant be read.
    8. If the TOC is displayed correctly but the PLAY does not happen - it means that:
    - laser is OK
    - TRACKING does not move the laser from first "groove" of the disc to another. Then go down to tracking problem chapter.
    9. The CD starts to play, but skips
    - observe if it skips forward or backward. If there is a mechanical problem - the advance of tracking is blocked - the skipping will happen backward. If the tracking controller is too enthusiastic - it will skip forward.
    Adjust the physical levelling of the CD player, and adjust the tracking gain (see below).
    10. The CD plays well the factory CD's but fails on the CD-R's
    The laser focus on CD-R is different than in factory CD. The pit reflection is also different on these two CD media
    The amount of plastic film that protects the metallic layer in the CD and CD-R is very different.
    Generally, it is always easier to read the CD than the CD-R, no matter how good is the blank media and how slowly it has been recorded. Not to mention the no name CD-R recorded at 24x.
    So if the normal CD plays well and the CD-R plays faulty (distorts, skips a lot, reads slowly or not at all) there is probably a problem on the horizon. The system is already too weak for CD-R but still somehow manages on regular CD's.
    This common problem can be a result of any other problem listed above - dirty laser, bad adjustment, worn out spindle, slipping disc, slipping belt, anything really. INCLUDING of course - a dying laser. All slowly building-up problems show on CD-R's first, months before CD's will show same problem.
    Problems 9 and 10 usually get worse as the laser is further away from the center - meaning - on higher number of the tracks. If it starts skipping on track 4, it will probably very badly skip on track 10th and never ever reach track 12th.
    11. Lasers which die on players bought 2 weeks ago from E-Bay
    If the otherwise excellent, pretty and valuable mint player starts having laser problems at the original owner, it will inevitably end up in the hands of the laser guru, who will turn up the power of laser emission. It may help the laser to read better TEMPORARILY.
    Then the guru gives the player back to the owner and says: " well, I managed to help you, the bill is 200 Euro, but take my good expert advice and start looking for a new player. This one will not last long. Sell it quickly, while it still works okay.
    Then the owner goes home, and he freaks out. Gee, if the adjustment costed me 200 Eu, how much is gonna be next time around, when the big un strikes ? So he puts it on ebay with a story attached about the uncle who passed away and while the nephew was cleaning up his house this cd player was found. (Funny that these houses always get cleaned by the nephews not sons or wifes) It was always well taken care of because the uncle was a music lover. He only listened to it occasionally - one opera CD every sunday after a mess. It is sold as it is, without warranty, because the young nephew is too busy to check it. "
    That is how mint collectors players end up in the hands of happy new owners only to die 2 weeks later.
    If that story is familiar to you - the laser is REALLY DEAD. A dying laser with cranked up emission will die very fast.
    Hy vọng hữu ích.
    Kính
    Wilson Fans likes this.
  2. audio-abc
    audio-abc Advanced Member
    Hữu dụng thật, cám ơn Bác
  3. minhhp6365
    minhhp6365 Advanced Member
    Cám ơn bác có thông tin hữu ích, bác chịu khó dịch luôn thì bà con cám ơn bác thêm lần nữa.
  4. garbolino
    garbolino Advanced Member
    ZVL Skalica
    Em dốt tiếng Anh, các bác dịch ra hộ thì em cám ơn, nhưng sẽ cám ơn thật to nếu các bác chỉ quote khi cần thiết.
  5. tamtam
    SAIGON
    EM sẽ dịch cho các Bác vậy.
  6. vohao
    vohao Approved Member
    Bác tamtam cho hỏi đầu cd của tôi bị lỗi như trường hợp 8 và 10 đề cập trong bài viết theo link trên thì phải xử lý ntn !? Cám ơn bác nhiều!
    - laser is OK
  7. minhtriet
    minhtriet Advanced Member
    Huế
    Cái này tác giả đã có trả lời ở phần trên rồi mà :D
    - Lỗi phần 8 liên quan đến phần cơ tracking (phần cơ di chuyển cụm mắt laser), tracking không di chuyển tia laser đến rãnh đầu tiên của mỗi bài hát.
    Theo hướng dẫn của tác giả là do bụi bẩn, tóc, lông bám vào thanh truyền động (do phần này luôn dính dầu mỡ) nên làm cụm cơ mắt laser di chuyển không chính xác, nên vệ sinh lại phần này.
    Với câu 10 tác giả cũng trình bày liên quan đến các lỗi như: mắt cd bị bẩn, cân chỉnh sai, mâm chạy ép vào đĩa cd khi quay bị mòn... hoặc cũng có thể mắt laser quá yếu :D
  8. tamtam
    SAIGON
    Kính thưa các Bác, theo yêu cầu em đã bỏ giờ nghỉ trưa (ăn bánh mì uống nước lã) để tạm dịch nội dung để các Bác tiện tham khảo. Tuy nhiên, trước khi các Bác đọc em xin có cáo bạch (Disclaimer) vài dòng như sau:
    1. Em không phải là cao thủ DIY theo nghĩa "Do It Youself" mà chỉ ở cấp độ mẫu giáo lớp mầm, chỉ thích đọc, khoái nghịch, khoái tìm tòi! Do vậy các Bác đừng hỏi em nhiều về CDP em không trả lời được :oops: . Nếu có câu hỏi, xin các đại cao thủ ở đây giúp giùm. Tuy nhiên nếu mà các Bác lấy nghĩa DIY là "Destroy It Yourself" thì em đúng là đại cao thủ. Nhưng em tin chẳng Bác nào nghe em xúi đâu.
    2. Những điều nói ở trong trang web cũng như hướng dẫn này theo em là rất có ích cho em và các Bác nào chưa rành về CDP trong qua trình tự mày mò. Tuy nhiên nếu các Bác nào hổng chắc lắm thì tốt nhất là nhờ các đại cao thủ hoặc thợ đúng nghĩa để đảm bảo cho cái đầu phát của các bác yên lành.
    3. Em vốn không phải của dân kỹ thuật nên bản dịch có thể làm ngứa mắt các cao thủ, vậy xin giúp em hiệu chỉnh nếu được. Xin cảm ơn
    Với vài lời rào trước đón sau, giờ thì em mạnh dạn post bản dịch đây:
    Có một số suy nghĩ cho rằng việc mắt đọc laser bị "tèo" không bao giờ xảy ra. Và một số cho rằng có.
    “ Ê Này, cậu có biết có thể mua mắt đọc laser mới ở đâu cho đầu CD của tớ? Nó vừa bị tèo.” Tớ đã nghe điều này rất nhiều lần và quyết định viết điều gì đó về đầu đọc laser, những hư hỏng và một số cách sửa chữa đơn giản.
    Tớ đã xem bên trong trên 100 đầu máy CD không còn đọc được đĩa và chỉ có một (đúng cả theo hệ thập phân và hệ nhị phân là chỉ 1) trong số chúng là đã hư mắt đọc laser. Và mắt đọc đã hư là do sự ngớ ngẩn của chính tớ. Nhưng điều này (lỗi ngớ ngẩn của tớ) không phải là việc mà tớ muốn bàn ở đây mà chính là sự ngớ ngẩn của kẻ khác.
    Vậy thì, điều gì đã xảy ra khi có khoảng 20 nguyên nhân tại sao đầu đọc CD không chịu đọc đĩa, và ai nấy đều hùng hồn phán: tất cả hư hỏng này là do “hư hỏng mắt đọc laser”
    Đây chính là ”tội hình sự” vì những người không biết sẽ chỉ đơn giản là đi mua máy mới do
    việc mắt đọc cũ không còn được sản xuất, lo không còn mắt đọc, nguồn dự trữ từ việc làm thịt phụ tùng các máy không còn.
    Theo “kinh nghiệm chiến trường của tớ”, thì 10 nguyên nhân chính tại sao đĩa CD không được đọc là:
    1. Do đã có một đĩa CD bên trong máy bị kẹt lại ở khu vực nào đó trong máy. Đĩa này đã rơi ra khỏi máng đĩa của máy và cản bộ cơ. Khi người nghe đưa đĩa thứ hai vào thì đầu đọc báo ‘Lỗi”. Chữa Trị: cách chữa trị đầu tiên mà tớ nghĩ ra là : Mở đầu CD, lấy đĩa bị kẹt ra.
    2. Dây curoa khởi động khay đĩa sau 20 năm xử dụng đã bị trượt, hoặc đứt. Sau khi đóng khay đĩa, CD sẽ không được đặt đúng vị trí trục quay. Chữa trị: thay dây curoa.
    3. Đầu CD đã được sử dụng trong môi trường bụi bẩn và bụi hoặc ám khói thuốc lá đã đóng vào cụm thấu kiếng mắt đọc laser. Bụi dẫn đến tia laser bị phân tán. Mắt đọc không tập trung được vào điểm cần đọc. Chữa trị: Mở đầu đọc và làm sạch bề mặt của mắt đọc laser với tăm bông. Đầu tiên là với tăm bông nhúng ướt dung dịch lau kính, sau đó là lau sạch lại với tăm bông khô. Nếu chưa đủ thì lau mắt đọc laser bên trong phần đọc. Cái này thì cần phải có tay nghề. Tốt nhất là đưa cho mấy lão sửa đồng hồ. Xem một số hình ( mở và lau mắt đọc KSS-151A của Sony và CDM của Phillip ở trang web đường dẫn đính kèm–chú thích của người dịch).
    4. Mạch điện cấp nguồn cho mắt đọc bị lỗi: hoặc là hiệu điện thế quá thấp, hoặc là bị nhiễu, hoặc từ nguồn lọc hoặc do hiệu chỉnh kém. Nguyên nhân là có thể do các tụ hóa lâu ngày bị khô. Chữa trị: thay thế tất cả các tụ hóa trong mạch digital, hoặc tốt hơn thay thế tất cả các tụ.
    5. Có một mối hàn lỏng trong mạch điều khiển mắt đọc. Thực tế là có thể có những mối hàn đã bị hỏng và không còn chặt. Với những đầu CD tốt nhất đã 20 năm tuổi, điều này có thể xảy ra. Mối hàn tại chân của các bộ điều chỉnh, hoặc các diểm nắn dòng, hoặc bộ điều khiển nguồn mắt đọc, do nhiệt lâu ngày đã làm lão hóa (oxi hóa, chảy dịch hàn, hoặc thiếc hàn bốc hơi). Cách chữa: Xem xét tất cả các mối hàn, đặc biệt là xung quanh các mối nối dây mắt đọc, xung quanh các bộ điều chỉnh, xung quanh các vị trí có dấu hiệu nâu, cháy… và hàn mới lại các điểm này.
    6. Dây cáp nối bị gẫy sau hàng triệu lần uốn tới uốn lui. Kiểm tra độ đàn hồi của các cáp dẫn đến đầu đọc, khay đĩa, mô tơ hoặc bộ phận nhận bài (tracking)
    7. Bộ phận cơ tracking của máy đã bị đóng dơ, do tóc, bụi trên bộ phận có bôi mỡ và việc nhận và bộ phận tracking không thể đến được điểm trung tâm – vị trí khởi động. Với mỗi lần di chuyển nhận bài, bụi bẩn được đẩy ra xa và tạo thành “lớp đệm” nằm tại mỗi bên của rãnh. Cách chữa: Làm sạch các rãnh, trục quay và thanh trượt tại những điểm cuối.
    8. Mô Tơ chính đã không còn quay đúng tốc độ. Hiện tượng dường như là mắt đọc không thể đọc được bài nhưng đơn giản chỉ là do tốc độ quay của Mô tơ không đúng. Có thể do đĩa đã trượt khỏi trục quay, hoặc lỗi mô tơ, hoặc cản trở việc đọc đĩa CD của mắt đọc như hiện tượng đĩa ma sát vào khay đĩa. Ví dụ: trục quay có thể bị mòn phần đáy làm toàn bộ CD sẽ thấp hơn khoảng 1/10mm. Mắt laser sẽ không hiệu chỉnh được và phần chặn phía trên đĩa sẽ không áp sát đủ. Cách chữa: Nếu Mô Tơ chỉ là loại Mabuchi giá 5 $, hãy thay nó. Nếu nó là loại CD hoặc khe từ KSS thì chỉ cần chỉnh lại độ cao của trục quay.
    9. Có sợi tóc hoặc vật gì đó bên trong bộ phận hiệu chỉnh mắt laser. Mắt laser không thể di chuyển lên xuống bình thường. Do CD tích điện mạnh nên nó sẽ hút tóc, bụi bẩn. Trong quá trình hoạt động những vật bẩn này sẽ kẹt vào dưới hệ thống treo mắt đọc. Cách chũa: Lấy vật cản ra.
    10. Đĩa CD không xoay: Sau khi khay đĩa đóng, không thấy đầu đĩa có hoạt động gì và đầu hiển thị lỗi. Đây có thể là do đĩa không quay. Hoạt động của đĩa cần phải được quan sát, do vậy cần mở phía trên đầu CD ra.
    Chẩn bệnh CD laser – hướng dẫn nhanh:
    Mắt đọc CD dó thật sự tèo chưa?
    Nếu không có các thiết bị chuyên dùng, chúng ta có thể chẩn đoán một số bệnh nhỏ và tiết kiệm được khối tiền cho dịch vụ sửa chữa hoặc phải mua mắt đọc laser mới hoặc mua đầu đĩa mới.
    1. Mở khay đĩa.
    2. Bỏ đĩa gốc chính hãng (có mặt đĩa sạch) vào đầu CD rồi nhấn nút close đóng khay đĩa.
    3. Khay đĩa có đóng vào sát không?
    4. Nếu 3 có, thì đĩa có xoay chút nào không?
    5. Nếu 4 có thì nó có xoay trong khoảng 2-3 giây hoặc hơn 10 giây không? Đĩa có xoay rất nhanh như điên hay có vẻ như không được kiểm soát?
    6. Nếu câu 5 là : có kiểm soát và xoay trong khoảng 2-3 giây thì mắt laser còn “sống” và nó có thể nhận tia phản xạ từ bề mặt bạc của đĩa. Mách nhỏ: Nếu mắt laser “tèo”, CD sẽ không xoay chút nào cả. Mô Tơ của đầu CD chỉ có thể nhận được tín hiệu xoay đĩa khi mắt laser báo “đã nhận tín hiệu phản xạ bề mặt đĩa với vị trí mà đĩa CD cần phải tại vị ” Tuy nhiên một số Bác đã đúng khi chỉ ra rằng một số bộ chế động (servo mechanism) sẽ xoay đĩa mà không cần mắt đọc kiểm tra đĩa có ở đúng vị trí hay không. Và như vậy, các Bác này cho rằng việc xoay đĩa trong thời gian ngắn ban đầu không nói lên việc mắt đọc có hư hày không.
    7. Sau khi đĩa quay 2-3 giây, màn hiển thị trên đầu đọc có báo đúng số track và thời gian của đĩa hay không? Nếu đĩa đã xoay nhưng không thể hiện thời gian của đĩa – có nghĩa là nó không thể đọc được TOC – Nội dung tổng quát của đĩa. Như vậy mắt đọc laser có thể thấy được bề mặt đĩa nhưng không thể đọc được dòng đầu tiên của dữ liệu. Dòng đầu tiên này được ghi sát vị trí của trung tâm của đĩa, như vậy để nhận bài mắt đọc laser phải ở vị trí “gần trung tâm nhất”. Vì vậy, nếu chúng ta có vấn đề về việc tracking (bộ cơ di chuyển mắt đọc)– mắt đọc không thể di chuyển đến vị trí trung tâm và nội dung tổng quát của đĩa (TOC) không thể đọc được.
    8. Nếu nội dung tổng quát của đĩa đã được thể hiện nhưng không thể chạy được, điều này có nghĩa là:
    a. Mắt laser OK.
    b. Bộ phận nhận bài không thể di chuyển mắt laser từ vị trí rãnh đầu tiên của đĩa đến rãnh kế tiếp. Như vậy, hãy xem xuống phần về vấn đề nhận bài (tracking).
    9. Đĩa CD đã được đọc nhưng “nhảy cóc": Hãy quan sát xem nhảy tới hay nhảy lui. Nếu có vấn đề về cơ khí (việc tracking tới bị cản trở), việc nhảy bài sẽ là nhảy về phía sau. Nếu bộ kiểm soát nhận bài quá nhạy thì sẽ bị hiện tượng nhảy về trước. Hãy hiệu chỉnh độ cân bằng của máy, và hiệu chỉnh độ nhạy của tracking (tracking gain). Xin xem bên dưới.
    10. Đầu CD phát tốt đĩa gốc nhưng không phát được đĩa chép. Hội tụ tia laser của đĩa chép khác với đĩa gốc. Phản xạ của lỗ đĩa (pit) khác nhau giữa hai loại đĩa này. Số lượng phim nhựa phủ bảo vê mặt kim loại ở đĩa gốc và đĩa chép rất khác nhau. Thông thường, đầu CD luôn dễ đọc đĩa gốc hơn đĩa chép cho dù chất lượng phôi đĩa chép tốt như thế nào và được chép chậm ra sao đi nữa. Ở đây Tớ không đề cập đến loại phôi đĩa không tên tuổi và được ghi với tốc độ 24x. Vì vậy, nếu một đĩa CD gốc được phát tốt và đọc đĩa chép thì bị lỗi (nhiễu, nhảy bài, đọc chậm hoặc không chịu đọc) thì vấn đề sẽ vẫn tồn tại. Một hệ thống đã quá yếu sẽ khó đọc đĩa chép nhưng vẫn có khả năng đọc được các đỉa CD gốc. Lỗi thường gặp này có thể là do các nguyên nhân đã được liệt kê trên đây : mắt đọc dơ, hiệu chỉnh kém, trục xoay mòn, đĩa trượt khỏi khay, dây curoa, và các nguyên nhân khác. BAO GỒM mắt đọc đã tèo – lẽ đương nhiên! Những hiện tượng hỏng hóc sẽ thể hiện đầu tiên ở các đĩa chép, và hiện tượng tương tự sẽ xảy ra với đĩa gốc vài tháng sau đó.
    Vấn đề số 9 và 10 thường sẽ càng trở nên tệ hơn khi mắt đọc di chuyển xa khỏi khu vực trung tâm của đĩa (có nghĩa là ở những bài có số thứ tự lớn). Nếu đầu đọc đã bắt đầu nhảy ở track 4 thì sẽ có khả năng nhảy nhiều hơn ở track 10 và sẽ không thể tiếp cận đến track 12.
    11. Mắt laser bị tèo ở những đầu CD mới mua có 2 tuần từ Ebay: Nếu vì một lý do nào đó một đầu đọc đẹp, xuất sắc, có giá trị, và tình trạng như mới bắt đầu có vấn đề về mắt đọc với chủ cũ, hiển nhiên cái đầu này sẽ chạy đến tay của chuyên gia về mắt đọc, người sẽ chỉnh tăng dòng cho mắt đọc. Việc này sẽ giúp mắt laser đọc được tốt hơn MỘT CÁCH TẠM THỜI”. Người chuyên gia này sau đó sẽ trả lại đầu CD cho chủ khổ sở và phán là ” Này, Tớ đã giúp cậu rồi nhé! Giá là 200 Euro, nhưng hãy nghe lời khuyên chân thành của Tớ là hãy bắt đầu đi tìm một đầu phát mới đi. Cái đầu phát này sẽ không hoạt động lâu. Hãy bán nó thật nhanh khi nó vẫn còn hoạt động”.
    Khổ chủ về nhà và lầm bầm “Tiên Sư, nếu mà chỉ có hiệu chỉnh mắt mà mình đã mất đến 200 Euro thì lần tới bị nặng hơn sẽ tốn bao nhiêu? Vậy là hắn ta đưa nó lên Ebay với một câu chuyện về một người chú qua đời và người cháu trong khi dọn dẹp ngôi nhà phát hiện ra cái đầu CD này (Quái lạ, sao ngôi nhà này lại không được dọn bởi các bà vợ hay những đưa con mà phải là cháu). Và rằng cái đầu này luôn được chăm sóc cẩn thận vì người chú rất yêu nhạc! Và rằng Ông ta ít khi nghe, chỉ một đĩa opera vào mỗi Chủ Nhật sau khi đi nhà thờ! Và rằng nó sẽ được bán đúng hiện trạng, không bảo hành, vì người cháu bận quá không thể kiểm tra được.
    Đấy là lý do những người săn đồ sưu tầm đã trở thành chủ nhân hạnh phúc của một đầu CD sẽ bị tèo trong vòng 2 tuần.
    Nếu câu chuyện này có quen thuộc với các Cậu, thì mắt đọc laser đã chết hẳn rồi. Một mắt đọc laser bị chỉnh tăng dòng sẽ chết rất nhanh!
    hangtoan, gobi and chiêunam like this.
  9. doanhnhan2000
    doanhnhan2000 Advanced Member
    Ha Noi
    Đứa em của Em dùng con Teac 25 trơn bị hiện tượng Khay đĩa chạy ra rồi chạy vào ngay khi bấm open lấy đĩa
    Các bác cho em hỏi về cách xử lý hiện tượng này thế nào ah?
    Thân,
  10. tcqanh
    tcqanh Advanced Member
    Q3, Sài Gòn
    fantastic :D
    thanks bác tamtam.
  11. gacon
    gacon Advanced Member
    hanoi
    Cách này rất phổ biến ở VN
  12. DũngAudio
    DũngAudio Advanced Members
    Saigon Q3.
    :D bệnh này trị rất nhanh - bị dơ thanh tiếp điện bên dưới khay trượt CD , tháo khai trượt ra làm 5ph là xong ... nhưng nếu không rành , phải đem ra thợ làm . bệnh này làm cho khách quen , em cóc lấy khói được :mrgreen:
    các bác chú ý là nếu các jack cắm điện nguồn cho CD bị lỏng lẻo , điện ba chớp ba nháng thì mọi điều trên đều vô nghĩa ... có những CDP chạy cả chục năm êm re , có CDP chạy vài tháng ...im re
    he he - ổ cắm nguồn lỏng lẻo là nguyên nhân chính gây tiêu tùng máy móc của bạn ... chưa kịp đợi con mắt nó dơ đâu :D
    phòng cháy hơn chửa cháy - có con CDP đẹp , bự thì làm ơn dòm qua cái ổn áp kia coi có cần trùng tu lại chút nào không .. ba cái ổn áp lâu năm coi chừng chổi quét bị lờn , dơ - tiếp xúc không tốt ..ốc vít lỏng le các mối điện ..
    - mấy con cd loại bự , em chưa hốt được con nào quá 100k : nguyên tắc sửa : vệ sinh và ..chấm hết -- trừ mấy em bị luộc đồ hoặc bị mấy ông thợ kia quậy nát cái máy :mrgreen:
    - CDP loại trung bình - lau năm : vệ sinh và chấm hàn lại các mối hàn củ
    _ cdp quấn chăn mền đem tới tiệm ? miển sửa ! vì rắc rối nhiều hơn thuận lợi :mrgreen:
  13. tamtam
    SAIGON
    Khà khà, cái này thì em bị rồi nên có thể nói với Bác:
    Đầu Teac 25 cũng xài cơ VRDS -2 và mắt đọc KSS-151A xem hình.
    Triệu chứng: Bấm open khay đĩa đi ra, chưa kịp lấy thay đĩa, đã hổ thẹn đi vô.
    Chẩn đoán:
    - Theo sinh học: Cơ thể nàng chưa tắm rửa bị bẩn nên xấu hổ không cho người ta nhìn vào.
    :oops:
    - Theo cơ học: Các nhông và bánh răng truyền động của khay đĩa bị dơ, hoặc dây cu roa dẫn truyền động của khay đĩa bị nhão.
    Chữa trị:
    - Theo sinh học: Chuẩn bị cầm đĩa trên 1 tay trái, tay phải bấm và dơ lên chuẫn bị sẵn sàng. Khi khay đĩa ra chưa hết, chụp nhanh đĩa cũ lấy ra và tay trái đưa ngay đĩa mới vào. Cái này phải luyện tâp thường xuyên để có phản xạ tốt và nhịp nhàng.
    :D - Theo cơ học: Tháo khay đĩa ra và đầu che phía trên để nhìn thấy bánh răng truyền động, tháo ra làm vệ sinh, cả răng bên hông khay đĩa và thay dây cu roa nếu bị nhão
    Em trị nó vậy. các cao thủ có ý kiến khác xin chỉ giáo thêm
  14. Lion_Heart
    Lion_Heart Advanced Member
    Chữa trị:
    Em thấy cách chữa trị này của bác là hay nhất đấy! :lol:
  15. doanhnhan2000
    Ha Noi
  16. tamtam
    SAIGON
    Chết! Em nói về cách chữa trị Teac 25 trước khi biết Bác Thợ Săn Post bài nếu biết trước thì sao dám múa dao lam cạo râu trước mặt Điền Bá Quang! :).
  17. tuanj
    tuanj Advanced Member
    em cũng có câu hỏi về teac 25 trơn ạh . Con teac nhà em nhét đĩa nào vào nó cũng nhận bài nhanh gần như nhau . Nhưng sau khi nhận thì cái nó đọc nhanh , cái nó đọc lâu và cái o chịu đọc .
    Đôi khi 1 số đĩa khi máy mới bật lên nhét vào bật 1 bài đầu tiếng nó bị tạp , rè rè .
    2 hiện tượng này sau khi cho chạy lâu lâu thì đỡ , lần sau bật lại thế . Có phải do mắt em nó sau nhiều năm phục vụ giờ đuối quá đòi nghỉ hưu o ạh . Em hỏi chút vì mắt 151a giờ hơi khó kiếm và khá đắt ( hôn trc hỏi 700k) .
    Trình em dốt nêm đọc qua qua cái trên kia ngẫm chưa ra . Các bác góp nhời vàng ngọc hộ em nhé :wink:
  18. clio206
    clio206 Advanced Member
    Các cụ cho hỏi mấy câu ngớ ngẩn 1 tý:
    có 1 số đầu mới (tức là mắt mũi còn khỏe) nhưng cho CDR vào lại kén, lúc thích đọc thì đọc, lúc không thích thì thôi. Cái này có cách nào trị không ạ? Có đầu còn chơi chiêu này: cho cdr vào nó "tức mình" treo máy luôn, không "play" hay "open" được, phải ngắt nguồn rồi khởi động lại thì nó mới ngoan ngoãn đọc.
    Với lại cho em hỏi có phải đĩa cdr chép càng nhiều track đầu càng khó đọc không? Tại sao lại thế nhỉ?
  19. Lion_Heart
    Bác để ý đĩa CD và CDR có gì khác nhau không nhé. Theo em biết thì ở đĩa CD máy ghi bằng cách khác thành các rãnh lên trên mặt đĩa ( mặc dù mắt ta không nhìn thấy được), giữa các track còn thấy cả đường ranh giới nữa cơ, trong khi CDR là cách "chụp ảnh" toàn bộ dử liệu digital của đĩa gốc lên trên mặt đĩa CDR ( tức là đĩa CD giống như chính con người, còn CDR giống như hình ảnh của chính con người đó trong tấm gương soi vậy). Một số đầu CD nhà sản xuất không chú ý đến khả năng đọc đĩa CDR ( Tây họ có mấy khi dùng đĩa CDR như mình đâu) nên mới sinh ra hiện tượng như bác mô tả.
    Ơ! Em nói có lung tung không nhỉ?
    Bác nào có cách giải thích chính xác hơn thì góp ý tiếp để mọi người cùng biết ạ.
    :D
  20. clio206
    Em cũng đoán rằng phương pháp ghi của 2 thằng này chắc phải khác nhau nhiều. Mà đúng thường những cdp kén là cdp làm ở châu Âu. Nhưng vấn đề là ở chỗ chính chúng nó quảng cáo là chạy cả cdr.
  21. mengkut
    mengkut Advanced Member
    Đồng Nai
    Chỗ này theo em hiểu như vậy không biết đúng ý tác giả không:
    Mô tơ quay đĩa chỉ nhận tín hiệu để quay khi mắt đọc báo cho nó biết là "phía trên nó đã có cái đĩa rồi". Tuy nhiên, nếu có ai đó có lý khi cho rằng 1 vài dàn cơ quay đĩa mà không cần kiểm tra xem là đã có đĩa hay chưa là vì rõ ràng 1 mô tơ nhỏ chạy không tải thì cũng chẳng có hại gì. (tức là cho nó chạy vô tư luôn cả khi không có đĩa)
    Các bác bảo giúp có loại dàn cơ nào như thế không?
  22. coi
    coi Advanced Member
    các bác bắt bệnh giúp e con cpd: hiện nó hơi kém đĩa. e xài toàn đĩa chép 5k, đọc đĩa khi tốt khi ko đọc dc,có khi đọc số bài rất nhanh, nhưng khi ấn play thì ko chạy nữa. Có khi cho đĩa vào cpd quay 1 lúc đọc ko dc rồi mất luôn cả hiển thị rồi có trở lại.
  23. nhat_nam80
    nhat_nam80 Advanced Member
    CDP bác có vấn đề ở phần nguồn cấp, lỏng chân con tụ (hoặc mấy con lk ổn áp tản nhiệt kém nóng thường dễ lỏng chân) trước đây em cũng bị như vậy.
  24. minhhp6365
    Mấy cái CDP kha khá hay cũng có cái kha khá cà chớn. Nếu cdp của bác có bữa chạy thấy thương ơi là thương, có bữa chạy cà chớn ơi là cà chớn. Vậy thì mỗi lúc như vậy bác kiểm tra xem điện có đúng như nhà sản xuất ghi không. Nhiều cái CDP -/+5% điện thế là nó cà giựt
  25. Vannam
    Vannam Advanced Member
    Lý do thứ 11 đây
    Cái này dành cho các bác khu vực phía bắc và xảy ra 1 mùa trong năm , đó là khi trời nồm , độ ẩm trong không khí quá cao , máy trở nên ỳ ạch hoặc tịt hẳn , ngâm điện lâu hoặc dùng máy sấy tóc là lại ngon , Bên trời Tây không biết lỗi này thì phải
