Các bác ơi, cho tui hỏi với. Tui có thằng bạn ở nhật hức cho tui một cái amply Sansui 1000. Âm thanh và chất lượng cái Ampli này như thế nào và chơ loa gì thì phù hợp? Có ai chơi thử nó chưa? Xin cảm ơn trước!!!
Bác vào xem tạm trang sau xem có đúng Sansui 1000 không: http://www.tube-amps.net/Sansui_Tube_Era_Products.htm
Chào Bác, đây là thông số con sansui 1000 bán dẫn đây: SANSUI BA-1000 \ 89,800 (point in time of June of 77) The power amplifier of the pure complimentary OCL system which actualizes the sound quality which uses new development vertical type power FET for the output step, is superior. The power source automatic following type bias circuit is adopted, stability operation of power FET is obtained. In order to make quality of vertical type power FET full show, adopting the new development driver circuit. Adopting the power source section which uses the toroidal trance whose regulation is good. Large output of the MONO operation 95W with BTL connection is possible. The rear section heat sinker where the heat dissipation effect is good Rating of type Type Stereo power amplifier Effective output 45W+45W (both ch operation, 20Hz~20kHz and 8Ω) 95W (BTL connection mono operation, 20Hz~20kHz and 16Ω) All the harmonic distortion factors 0.08% or less (at the time of rated output, 8Ω) Cross modulation distortion factor 0.03% or less (70Hz: 7kHz=4: 1 SMPTE) Output bandwidth 5Hz~30kHz (IHF and 8Ω) Frequency characteristic 5Hz~80kHz (+0 -1dB, 1W) Ham and noise Above 105dB (IHF) Input sensitivity/input impedance 700mV/50kΩ Load impedance 2ch: 4 and 8, 16Ω Mono: 8, 16Ω Damping factor 70 (8Ω) Channel separation Above 85dB (1kHz) External size Width 482× height 88× depth 338mm Weight 10kg
