ANH DUY AUDIO: khuyến mãi giảm giá khủng lên đến 50% nhiều mặt hàng! (liên hệ)
Discussion in 'VNAV Shop - Showrooms' started by AnhDuy, 21/8/07.
  1. AnhDuy
    AnhDuy Shop
    Accuphase DP-560
    DP-560 là đầu phát mới được thiết kế để thay thế DP-550. Nó thừa hưởng các đặc tính của dòng đầu phát đầu bảng là DP-950 đem đến cho người yêu nhạc chất âm đặc biệt của riêng Accuphase.
    The state of the art laser module is mounted on silicon vibration absorbers and the longer drive mechanism features a high-mobility, ultra-quiet motor to eliminate tray vibrations. The ultra modern, elegant cover is made from three parts; a rigid molded base, a high grade iron insulator, and a sleek aluminum cover with air gaps between each material to further reduce vibration. These features insure that the total noise is reduced dramatically. The DP-560 outputs 119dB signal to noise ratio, which means 2.8uV of output voltage noise. Giving the DP-560 a 20% reduction in voltage noise than the DP-550, effectively reducing the noise to zero.
    For the D/A converter section, Accuphase has updated the DAC chip to ESS Technology’s 32bit Hyperstream DAC ES9018S with 8 DACs inside. The highly advanced DAC circuit has 4 DACs connected in parallel per channel with Accuphase’s unique, cutting edge MDS+ conversion system. In addition, the independent low pass filter is installed for each audio output. The end result is an analog signal of outstanding quality, allowing the music to emerge in perfect clarity, demonstrating the ultimate potential of the SA-CD format.
    4 digital inputs, Coaxial, Optical, HS-LINK and USB.
    USB Input accepts 384kHz/32bit-PCM or 11.2896MHz-DSD.
    DSD data can be received both DoP(DSD over PCM)and ASIO2.1
    Original HS-LINK Ver.1 transmits and receives at 192kHz/24bit-PCM or 2.8224MHz-DSD, Ver.2 transmits and receives at 384kHz/32bit-PCM, 5.6648MHz-DSD.
    DATA Disc playback is available.
    DP-560 có thể phát định dạng 192kHz 24 bit data của WAV, FLAC, AIFF , và 5.6MHz 1bit DSD data
    Kích thước: Width 465 mm (18.3 in) Height 151 mm (15.9 in) Depth 393 mm (15.5 in)
    Trọng lượng: 18.8 kg (41.5 lbs) net 25.0 kg (55.1 lbs) in shipping carton[​IMG]
    Giá: 200.000.000 VNĐ
    ANH DUY AUDIO
    172 Pasteur, Phường Bến Nghé, Q1 TP HCM
    STK: 198525979 - NGÂN HÀNG TMCP Á CHÂU HCM - Chủ TK: Nguyễn Anh Tuấn
    ĐT: 0972972217 - 02822437008
    (Liên hệ sẽ có giá tốt)
  2. AnhDuy
    AnhDuy Shop
    Tai nghe Klipsch Reference X20i
    Klipsch Reference X20i là chiếc tai nghe hợp lý. Nghe có vẻ đơn giản vậy nhưng dường như lại thành xa xỉ với dòng tai nghe cao cấp, bởi nhóm sản phẩm này thường đưa chất lượng âm thanh lên đầu mà bỏ qua nhiều yếu tố quan trọng khác.
    THIẾT KẾ
    Có một thực tế là không ít tai nghe cao cấp hiện nay đều cố gắng sử dụng quá nhiều driver. Một chiếc tai nghe, xét cho cùng cũng để phục vụ mục đích nghe nhạc linh hoạt, vậy yếu tố thoải mái, tiện dụng nên được quan tâm hàng đầu. Tôi từng rất hài lòng với âm thanh của 1 số tai nghe chụp đầu, nhưng cũng chỉ bởi trọng lượng của chúng không đi đến quyết định sở hữu. Hoặc giả, chiếc Ultimate Ears TripleFi 10 cũng khiến người dùng khá vất vả để đeo cho chắc, nên tiếng trầm luôn thiếu.
    Trở lại đối tượng chính của bài viết, Klipsch Reference X20i là một trong những tai nghe in-ear cao cấp có kích thước nhỏ nhất tôi từng thấy, và nó dễ dàng nằm gọn gàng, bám chắc trong ống tai nghe khi đeo lên. Tuy nhiên, X20i chưa đạt độ thoải mái tương đương các sản phẩm của Phonak, thương hiệu sở hữu những thiết kế hàng đầu về thiết bị thính giác chuyên nghiệp. Song mọi sự tồn tại đều có căn cớ của nó.
    Phần vỏ Klipsch Reference X20i được làm từ thép không rỉ, đạt tiêu chuẩn của dụng cụ phẫu thuật. Khó có thể yêu cầu nó nhẹ được như các sản phẩm vỏ nhựa của Phonak, và đây cũng là sự khác biêt chính.
    Thực ra, kích thước nhỏ cũng khiến Klipsch phải đánh đổi đôi chút. Phần dây cáp có thể tháo rời, song Klipsch thiết kế điểm kết nối rời ở phía dứoi, thay vì ở trong phần vở như các hãng khác.
    Điều này làm tăng trọng lượng tổng thể, nhưng vẫn ở mức chấp nhận được. Connector của X20i là chuẩn SSMSX dạng xoáy thay vì chuẩn MMCX thông dụng, cho phép giảm kích thước tới 35% song lại khó kiếm cáp nâng cấp hơn.
    Việc sử dụng cáp rời không phổ biến này đã nảy sinh một số tranh luận về việc, đó là ưu hay khuyết điểm. Thực chất chúng tối chưa thể kết luận việc để cáp rời có thể nâng cấp đáng kể âm thanh hay không, bởi dây tín hiệu nối trực tiếp tới driver không thể thay thế chỉ chuyển đổi được đoạn cáp dưới. Và điều này khiến việc nâng cấp cáp ít ý nghĩa hơn. Bên cạnh đó theiets kế cáp của X20i cũng không cho phép đeo kiểu móc ngược cáp trên vành tai,mà tối ưu hoàn toàn cho kiểu đeo thẳng truyền thống. Đây không hẳn là nhược điểm dù một số người lại thích có nhiều cách đeo hơn.
    Phần cáp của X20i được Klipsch gọi là cáp Reference, sử dụng lõi đồng bọc nhựa màu khói. Tôi hơi bất ngờ bởi cáp khá lớn song nhờ độ hoàn thiện tốt mà X20i không hề bị hiện tượng microphonic. Việc chọn màu khó để khoe lói đồng cũng khá an toàn bởi nó sẽ không bị ố màu sau một thời gian sử dụng. Sợi cáp này tuy không phải dạng dẹt, nhưng cũng không dễ dàng bị rối hơn nữa đã có túi đựng đi kèm.
    TIỆN ÍCH
    Bộ điều khiển âm thanh được tích hợp sẵn trên dây cáp đi kèm có lớp vỏ bằng nhựa với màu hơi lệch chút (nhạt hơn) phần vỏ.Kích thước bộ điều khiển này khác lớn bố cục rõ ràng với nút nhận cuộc gọi ở giữa nhô lên. Chữ “i” ở cuối tên sản phẩm được hiểu như thiết kế dành cho iPhone, iPad và iPod nên bộ điều khiển này có thể sẽ không tương thích đầy đủ với một số điện thoại Android.
    Không có quá nhiều thứ để nói về giắc cắm của chiếc tai nghe này ngoài việc nó được chế tác đẹp mắt với kích thước hợp lý. Kiểu giắc chư l cộng với kích thước nhỏ gọn khiến Klipsch Reference X20i không gặp khó khăn khi sử dụng kèm các bộ vỏ case bảo vệ iPhone như 1 số loại giắc chữ L kích thước lớn khác.
    Thiết kế đệm tai silicone hình oval của Klipsch là điểm đáng khen ngợi. Thay vì hình tròng như các hãng khác đệm tai hình oval đem lại cảm giác đeo khít và cách âm rất tốt. Trong khi thông thường tôi sử dụng đệm tai cỡ S thì với thiết kế này tôi sử dụng đệm tai cỡ M cũng không vấn đề gì. Vật liệu silicone mà Klipsch chọn sử dụng cũng đủ êm ái và thoải mái đủ ma sát để bám lấy tai trong các điều kiện khác nhau.
    CẤU TRÚC
    Phần ống dẫn âm của X20i khá nhỏ và không sử dụng filter lọc bụi dưới dạng lưới thông thường. Song nếu nhìn kỹ bên trong sẽ thấy 1 điều thú vị : có đến 2 ống thoát âm ở trong đồng nghĩa với việc chiếc tai nghe này quả thực sử dụng mô hình 2 đương tiếng mà theo Klipsch gọi là “true two-way”. Dựa vào thông tin Klipsch cung cấp thì hãng điều chỉnh âm thanh cấu trúc Acoustic. Cách làm này không hề dễ dàng nên giờ đây đã ít hãng còn dám sử dụng công nghệ này.
    Phần vỏ củ X20i được thiết kế dường như hở song thực ra nhờ sử dụng driver Balanced Armature nên kết cấu của chiếc tai nghe này rất kín. Độ cách âm nhờ đó mà trở nên rất tốt khi đeo đủ khít. Ngay khi nhạc bắt đầu chơi tôi gần như không nghe được âm thanh xung quanh và dĩ nhiên người bên cạnh cũng không biết là tôi đang nghe nhạc.
    Là tai nghe được thiết kế dành cho smartphone nên Klipsch X20i không yêu cầu nhiều về công suất ngồn phát.Với 1 chiếc điện thoại có công suất trung bình như iPhone 5s thì cũng chỉ cần khoảng 60-70% là đủ nghe.T ôi nghĩ rằng phần lớn smartphone hiện nay đều đủ công suất để nghe với Klipsch X20i.
    Vậy Klipsch X20i có cần nguồn phát cao cấp hơn 1 chiếc smartphone hay không? Rõ ràng là vẫn nên có nếu bạn có điều kiện. Klipsch không làm nhưng chiếc tai nghe quá kén nguồn phát và cũng không thực sự phô với bản nhạc cũ được âm chất lượng.
    Trước khi đi sâu vào phân tích phần âm thanh. Có lẽ tối cần phải nhắc lại rằng Klipsch X20i là chiếc tai nghe dòng tham chiếu thường sẽ mạnh mẽ phần kỹ thuật và không chọn lựa kiểu chơi nhạc nịnh tai. Và đó chính là điều khiển tối nhắc tới Phonak.Tuy nhiên Phonak lại không có sản phẩm ở phân khúc giá này.
    ÂM THANH
    Cảm nhận đầu tiên khi nghe âm thanh Klipsch X20i là tai nghe này mang thiên hướng tái tạo âm thanh chính xác cân bằng , tự nhiên song vẫn có độ mướt nhất định. Dù là 1 chiếc tai nghe tham chiếu thì nó vẫn không khó nghe âm thanh có phần mộc, trung tính nhưng không cứng, không gắt gỏng và dĩ nhiên có độ chi tiết cao.
    Klipsch X20i sử dụng câis hình khá tương đồng so với chiếc Custom Art Music Two mà tôi đang dùng song về cách chơi bass thì khác nhau.Viêc sử dụng driver woofer lớn không đồng nghĩa với việc sẽ nhiều tiếng bass. Dải trầm của Klipsch tập tring vào phần midbass khá ít sub-bass.Điểm tích cực trong kiểu trình diễn này là khả năng tách bạch tiếng bass để dải trầm không ảnh hưởng tới các dải âm còn lại luôn được kiểm soát tốt. Tiếng trầm của Klipsch X20i vừa đủ sâu và cắt đuôi gọn gàng.Có thể thấy tiếng bass được tái tạo sạch sẽ, chi tiết nhưng lại thiếu đi một chút độ nảy để tạo cảm giác tự nhiên tốt hơn.
    Trong quá trình trải nghiêm X20i trên smartphone tôi co cảm giác như cần thêm 1 chút hài âm để kết dính upper bass và mid-low tạo sự liền lạc trên toàn bộ dải tần. Điều này có thề được cải thiện khi dùng máy nghe nhạc chuyên dụng
    X20i có độ chi tiết và tốc độ rất tốt,đây chính là điểm mà tôi gọi là sự phô diễn về mặt kỹ thuật của Klipsch đồng thời cũng tạo ra cảm giác rằng phần trình diễn âm thanh của tai nghe nghiêng về phân tích bản khí với kết cấu rõ ràng, mạch lạc.
    Ở dải mid, X20i khá dễ chịu. Độ chi tiết cao giúp nó bộc lộ rõ âm chất trong giọng của từng ca sĩ âm thanh của mỗi nhạc cụ không thêm bớ màu mè.Tiếng hát đặc biệt là giọng nữ trong vắt có độ vang rất chính xác song không có độ ấm bởi X20i chơi thiên về kỹ thuật.
    Tiếng treble của X20i khá giàu năng lượng song vẫn còn hơi “hiền”.Dường như Klipsch cố tình làm như vậy để X20i không tạo cảm giác sạn với các bản thu chất lượng thấp, hay nhạc nén MP3 .Rất có thể Klipsch đã nghiên cứu kỹ về thói quen nghe nhạc cũng như nguồn nhạc phổ thông mà người ta hay nghe trên smartphone để tạo ra chiếc tai nghe hợp lý, nghe lâu không khó chịu đôi tai.
    Và tôi cũng không kỳ vọng quá nhiều vào không gian của 1 chiếc tai nghe dòng Reference như thế này .Nó có hiệu ứng 3D, sắp xếp có lớp lang, vị trí cụ thể nhưng không gây ấn tượng về sự rộng rãi của âm trường.Ngoài ra thì mọi chi tiết âm thanh được X20i được duy trì đều đặn trên 1 dải tần tương đối rộng , không bị trội lên ở 1 quãng âm nào.
    KẾT LUẬN
    Nếu thực sự cần tới 1 tai nghe tham chiếu với âm thanh chính xác không màu mè thì Klipsch X20i là thiết bị đáng để đưa vào “short list” , bởi các tai nghe đạt tiêu chuẩn vốn không nhiều, thường có giá rất cao và thậm chí khó mua được ở Việt Nam.
    THÔNG SỐ KỸ THUẬT
    THIẾT KẾ DRIVER : KG-2625 AcuPass(R) Two-way
    LOẠI DRIVER : Balanced Armature KG-125B Super Tweeter + KG-926T Woofer
    TẦN SỐ ĐÁP ỨNG : 5 Hz – 40 kHz
    ĐỘ NHẠY (1mw) : 111dB
    TRỞ KHÁNG (1kHz) : 50 ohm
    CÁCH ÂM : -26dB
    CHUẨN GIẮC CẮM : 3,5mm
    TRỌNG LƯỢNG : 22 gram
    Giá: 11.000.000 VNĐ
    ANH DUY AUDIO
  3. AnhDuy
    AnhDuy Shop
    ACCUPHASE CLEAN POWER SUPPLYPS-530
    The PS-530 can deliver as much as 510 VA, covering the requirements of most standard audio components.
    AC voltage stabilizer based on waveform shaping technology
    Acts as a source of extremely clean energy
    Low-distortion reference waveform generator
    Highly effective waveform compensation
    Outstanding current capability
    Superb interference rejection
    Built-in meter for monitoring vital parameters including output power, input/output voltage, and input/output distortion
    Advanced protection features
    Large high-efficiency toroidal transformer.
    Giá: 139.000.000 VNĐ
    ANH DUY AUDIO
  4. AnhDuy
    AnhDuy Shop
    Prestige Gold Reference Super Tweeter, Loa Siêu Treble mới của Tannoy
    Để kỷ niệm 90 năm thành lập hãng, Tannoy đã công bố vài dòng sản phẩm ra đời trong dịp này. Một trong số những sản phẩm đặc biệt đó là loa super tweeter thuộc dòng Prestige.
    Prestige GR Super Tweeter là thế hệ loa tép rời mới vừa được Tannoy cho xuất xưởng, thay thế dòng loa cũ và hứa hẹn khai mở được những cung bậc cảm xúc mới cho các audiophile. Với Gold Reference Super Tweeter bạn sẽ bắt gặp những “cảnh giới” của âm thanh mà bạn chưa từng “chạm” đến. Nó giúp nới rộng khoảng cách giữa âm tần số thấp và tần số cao, đồng nghĩa với việc bạn vừa thưởng thức âm tần số siêu cao vừa cảm nhận âm trầm sâu lắng và gọn gàng hơn.
    Với thiết kế lấy cảm hứng từ mẫu Micro để bàn Tannoy của những năm 1950, Prestige GR SuperTweeter kết hợp nhuần nhuyễn giữa kiểu dáng vượt thời gian với công nghệ âm thanh đỉnh cao của Tannoy. Chân đế loa được làm từ gỗ Walnut được xử lý dầu vecni để tạo vân nổi đẹp mắt. Bên dưới loa có 4 chân nhỏ bằng cao su, vừa giúp khi đặt trên loa chính không bị rung và xê dịch vừa không làm trầy sướt loa chính. Giá trị của Prestige Gold Reference SuperTweeter còn được biết đến với việc được xử lý bằng tay với những công đoạn lắp ráp và hoàn thiện sản phẩm tại Anh Quốc.
    Màng loa được làm dạng dome siêu mỏng 44 micron, với hợp chất magiê được gia cố creamic có độ cứng cao. Cuộn coil siêu mảnh được hàn với độ chính xác cực cao bằng plasma và nam châm neodymium từ tính mạnh mẽ. Tất cả giúp âm tần số cao mở rộng và độ phân giải xuất sắc. Mẫu loa này được rút tỉa từ việc thiết kế loa siêu tép cho dòng loa Kingdom Royal. Nó cho âm thanh chính xác và mượt mà khi loa đạt công suất đỉnh lên đến 700 Watt.
    Gold Reference Super Tweeter mang lại chất âm có độ phân giải cao cho các dòng loa Prestige của Tannoy. Nó được thiết kế để dễ dàng kết hợp với tất cả các dòng loa cũ và mới của Tannoy. Loa có khả năng tái tạo dải tần âm thanh lên đến 100kHz cũng như giảm những lỗi về pha. Điều này đem đến kết quả tích cực là nó nâng cấp đáng kể sự trình diễn của toàn bộ hệ thống âm thanh với độ chính xác của âm sắc giàu âm điệu của nhạc cụ, âm nhạc được tái tạo tốt hơn với độ chi tiết trên cả tuyệt vời.
    Mạch phân tần được thiết kế siêu đẳng bằng các thành phần linh kiện lọc lựa tối đa. Mặc dù chỉ vài chi tiết của cấu hình nhưng Tannoy gần như toàn tâm toàn ý cho sản phẩm quan trọng trong dịp kỷ niệm trọng đại. Nó được cấu thành với các cuộn cảm bằng lõi khí, giúp tần số cao cực tuyến tính. Các điện trở dùng loại màng oxide kim loại không cảm ứng (non-inductive metal oxide film resistor ) có độ chính xác và tuổi thọ cao, ít phụ thuộc vào nhiệt độ. Loại này có độ ổn định nhiệt, chống ẩm cực tốt. Sau khi trải qua những đợt thử nghiệm thực tế trên mô hình loa có sẳn, hệ thống dây dẫn đồng OFC loại tinh thể có độ tinh khiết cao, mạ bạc được chọn lựa để dùng kết nối bên trong loa. Cọc đấu loa của GR Supper Tweeter được mạ vàng để sao cho việc kết nối dây loa bảo đảm tiếp xúc tốt nhất. Nó cũng có một cọc thứ năm dùng đấu đến mass của Ampli nhằm triệt tiêu sóng cao tần, giữ cho âm thanh sạch và rộng mở hơn.
    Thành phần chính của loa là củ loa được gắn trong một vỏ từ hợp kim magie mạ vàng và định vị trên một giá đỡ. Nó có thể được điều chỉnh lên xuống để tối ưu góc phát. Để có thể kết hợp hoàn hảo với toàn bộ các đời loa Tannoy khác nhau, GR Super Tweeter được thiết kế có thể thay đổi độ nhạy và điểm cắt tần số, cho phép điều chỉnh tần số cắt ở 3 mức 14/16/18 kHz và 5 mức độ nhạy cách nhau 1,5 dB (từ 89dB đến 95dB) với cơ cấu điều khiển dạng ốc vặn chắc chắn và vô cùng tinh tế.
    Gold Reference Super Tweeter đem đến âm thanh độ phân giải cao cho các dòng loa Tannoy. Loa được thiết kế để dễ dàng kết hợp với các dòng loa cũ và mới của Tannoy. Gold Reference Super Tweeter có khả năng tái tạo âm thanh lên đến 100kHz cũng như giảm những lỗi do pha. Kết quả nó nâng cấp đáng kể về trình diễn của hệ thống loa, với độ chính xác âm sắc giàu âm điệu của nhạc cụ, Âm nhạc được tái tạo tốt hơn với độ chi tiết trên cả tuyệt vời.
    Cuối cùng chúng tôi muốn gởi đến các bạn một ý kiến riêng rằng, hầu hết các bác sỹ đều cho rằng tai con người bình thường như chúng ta chỉ có thể nghe được dải tần âm thanh lên đến 20kHz là tối đa. Thế tại sao các hãng loa lại cố công sản xuất ra những đôi loa siêu tép tái tạo dải tần lên đến 100kHz? Không khó để trả lời câu hỏi này. Chúng ta biết rằng, các nhạc cụ có thể phát âm lên những tần số rất cao, vượt lên đến 40kHz, các thiết bị thu âm và lưu trữ những file nhạc có độ phân giải lớn. Như các đĩa SACD, các DVD-A hoặc các ổ cứng lưu nhạc lossless. Với hệ thống hiend, các thành phần hoàn hảo có thể tái tạo âm thanh có độ phân giải cao này với những âm thanh có tần số rất thấp hoặc rất cao. Loa là thành phần cuối cùng để chuyển tải âm thanh đó đến tai người nghe. Khi những chiếc loa truyền thống vì hạn chế về mặc kỹ thuật, về giá thành, không thể có những loa siêu tép theo nó. Và đó là lý do cho super tweeter ra đời. Những thứ âm thanh này, khi đứng riêng lẻ, có thể chúng ta chằng lấy gì làm thú vị khi nghe nó. Nhưng trong tổng thể của bản nhạc, những chi tiết dù nhỏ nhất vẫn có giá trị góp phần làm bài nhạc có sức sống, có hồn hơn, đặc biệt nó thể hiện được đẳng cấp của dàn máy. Có thể nói rằng, nhờ có super tweeter mọi điều như cho âm thanh đúng hơn.
    Thông số kỹ thuật
    Công suất loa chịu đựng liên tục: 175 W
    Công suất chịu đứng tối đa: 700W
    Độ nhạy (2.83V @ 1m): 95 dB
    Trở kháng: 8 Ohm
    Đáp tuyến tần số: (-6dB) : 62 kHz -100 kHz
    Củ loa: 25mm, màng loa hợp nhôm mỏng 44 micron với nam châm Neodymium
    Bộ phân tần
    Chỉnh tần số cắt: 14, 16, 18 kHz
    Mức chỉnh độ nhạy: 89 dB, 90.5 dB, 92 dB, 93.5 dB, 95 dB
    Cấu trúc loa
    Kích thước: (C x R x S): 130.4 x 146.9 x 206.2 mm
    Màu: Gỗ Walnut / Nhôm mạ vàng
    Giá: 72.000.000 VNĐ
    ANH DUY AUDIO
  5. AnhDuy
    AnhDuy Shop
    Unico Primo
    ampli hybrid của Unico ( Unison Research) Unico primo là ampli stereo hybrid có công suất 80W RMS tính trên những loa 8ohm. Khả năng phối ghép nhiều loa khác nhau.
    Thông số kỹ thuật
    Công suất: 80 RMS/ 8 ohm_
    Đáp tuyến tần số: -0.1dB @ 10Hz, - 0.5dB @ 100kHz
    Tầng vào: Pure A Class Tube stage (1 x ECC83/12AX7)
    Tầng khuếch đại: Dynamic A Class POWER MOSFET complementary pair
    ngõ vào: 5 line unbalanced (1 phono optional)
    ngõ ra: 1 tape, 1 sub (volume controlled)
    Outputs connectors: 4 + 4 bi-wiring
    Power consumption: 340W max
    kích thước: N43.5cm x C9.5cm x S43cm
    Trọng lượng: 15kg
    Made in Italy
    Giá: 33.900.000 VNĐ
    ANH DUY AUDIO
  6. AnhDuy
    AnhDuy Shop
    Unico Secondo
    Ampli stereo hybrid class A Ampli Unico Secondo của Unison Research với mạch công suất dynamic class A mạnh mẽ giúp dễ dàng kết nối với các dòng loa hiend khó đánh. Mạch hybrid với tiền khuếch đại bằng 2 bóng ECC 83 cho âm thanh mềm mại chi tiết. Ngõ vào balance.
    Technical characteristics
    • Output power: 100W RMS on 8ohm 200W RMS su 4ohm
    • Frequency response: flat @ 10Hz- 0.5dB @ 100kHz
    • Input impedance: 50kohm // 47pF
    • Input sensitivity: 375mV
    • Input stage: Pure A Class. Double tube stage ECC83/12AX7
    • Output stage: Dynamic A Class double POWER MOSFET complementary pair
    • Inputs: 5 line unbalanced, (1 phono optional), 1 line balanced
    • Line Outputs: 1 tape, 1 sub (volume controlled)
    • Outputs connectors: 4 + 4 bi-wiring
    • Damping factor: >50 on 8ohm
    • Feedback factor: 8dB
    • THD: <0.5% @ 1kHz, 100W su 8ohm
    • Power consumption: 400W max
    • Dimensions: 43.5cm x 13cm x 43cm
    • Weight: 15kg
    Giá: 55.918.000 VNĐ
    ANH DUY AUDIO
  7. AnhDuy
    AnhDuy Shop
    Unico 150
    Ampli tích hợp dòng hybrid kết hợp giữa đèn và bán dẫn, có công suất 150W+150W ở 8 Ohm và 220W + 220W ở 4 Ohm, mạnh mẽ và chi tiết, phối ghép với các dòng loa hiend công suất lớn.
    Output power: 150+150 W RMS at 8Ω / 220+220 W RMS at 4Ω
    Frequency response: -1dB @ 12Hz & 45kHz, -3 dB @ 6Hz & 80 kHz
    Input impedance: 24kΩ // 100pF
    Input sensitivity: 860mV RMS
    Input stage: Pure A class, double triode totem pole ECC83
    Driver stage Pure A class, double triode totem pole 6H30
    Output stage: Class AB thermostable, complementary Hexfet (4 pairs for channel)
    Input: 6 line (3 unbalanced, 2 balanced, 1 “bypass” unbalanced)
    Output connectors: 4 + 4 bi-wiring
    Global Feedback factor: 0 dB
    Local Feedback factor: 16 dB
    THD: < 0.15% @ 1kHz, 1 W
    < 0.25% @ 1kHz, 10 W
    < 0.35% @ 1kHz, 100 W
    < 0.9% da 20 a 20000 Hz, 150 W
    Output resistance: <0.4Ω, resistive on all audio frequencies
    Power Consumption: 550 W (at max power on 8 ohm)
    Dimensions: 43.5 cm x 18 cm x 44 cm
    Net weight: 25 kg
    Giá: 102.000.000 VNĐ
    ANH DUY AUDIO
  8. AnhDuy
    AnhDuy Shop
    Unico CD Primo
    Đầu phát CD Đầu phát Unico CD Primo với mạch class a cho tần xuất âm.
    Transport: TEAC CD5010A
    Digital interface: Wolfson Micro WM8804
    Sample Rate Converter: Burr Brown SRC4192
    Convertiter D/A: Wolfson Micro WM8524
    Sampling: 24bit / 96kHz
    Digital Standard: AES3, IEC60958 (S/PDIF) e EIAJ CP-1201
    Digital input (Ext): Isochronous-Out 16bit / 32-48kHz (USB-B)
    Digital output: 44.1kHz
    Output stage: solid state, Class A
    Outputs: 1 RCA
    Gain: Triode Class-A
    Valve: 1 x ECC82 (12AU7)
    Power conumption: 100W max
    Dimensions (la x lu x alt): 43.5 x 43 x 9.5 cm
    Net weight: 10 kg
    Giá: 30.510.000 VNĐ
    ANH DUY AUDIO
    STK: 198525979 - NGÂN HÀNG TMCP Á CHÂU ACB HCM - Chủ TK: Nguyễn Anh Tuấn
  9. AnhDuy
    AnhDuy Shop
    Unico CDDue
    Unico CD Due là chiếc CD cao cấp tích hợp bộ DAC với 3 ngõ vào gồm USB B, Optical, Coaxial và Coaxial balance. Đặc biệt đầu CD Due có thể nhận tín hiệu bluetooth từ các thiết bị nghe nhạc cầm tay. Bộ DAC tương thích với DSD64, DSD128, DSD256. Âm thanh trung thực, xuất sắc. Đầu CD này có mạch Hybrid với chế độ class A, 4 bóng 12AX7/ECC83. Ngõ ra RCA và Balance.
    Ngõ vào digital:
    1 x USB
    Standard: USB 2.0 Audio Class
    frequencies: 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384, DSD64, DSD128, DSD256
    Resolution: 16 to 32 bits
    1 x S/PDIF
    Sensitivity: 0.5Vpp on 75 Ohms
    Sampling frequencies: 44.1, 48, 88.2, 96, 176.4, 192
    DSD64 (DoP)
    Resolution: 16 to 24 bits
    1x AES/EBU
    Sensitivity: 2Vpp on 110 Ohms
    DSD64 (DoP)
    1x Toslink™
    1 x Bluetooth™ Receiver
    Ngõ ra digital
    1x S/PDIF
    Output voltage: 0.5Vpp on 75 Ohms
    1x AES/EBU
    Output voltage: 2Vpp on 110 Ohms
    1x Toslink™
    Transport: 8829CD-KHM DVD-Loader , Only audio CD
    Display
    128 X 64 White OLED graphic display , (can be turned off)
    Digital to Analogue Stage
    DAC:
    ESS Sabre ES9018K2M with jitter eliminator
    SNR: 128dB (0dBFS, 1kHz, 192kHz, “A”
    weighted)
    THD+N: 0.0003% (0dBFS, 1kHZ, 20Hz-20kHZ)
    Timing: low phase noise, high precision crystal oscillators
    Output Audio Stage
    Number of channels: 2
    Output stage:
    Duble Triode, pure class A differential Totem-pole
    Valve complement:
    4 x 12AX7/ECC83
    Ngõ ra Analog:
    1 x RCA stereo
    1 x XLR stereo
    Trọng lượng/Kích thước
    Power consumption: 100W max
    Dimension: 45cm x 38cm x 13cm
    Net weight: 10Kg
    Giá: 80.000.000 VNĐ
    ANH DUY AUDIO
  10. AnhDuy
    AnhDuy Shop
    Unico 90
    The heart of the Unico 90 circuit is found in its hybrid structure. All of the gain, and subsequently the "character" of the amp, is determined by the only tube stage made with ECC83 and ECC 81in particular multiple-parallel-totempole. This stage is made with the six triodes for channel, and is configured so that they present limited gain with the least output impedance possible. The choice of the triode was determined by multiple factors during the development process although our testing and research made our ultimate choices rather obvious. These factors included the following.
    • Output power: 100+100 W RMS su 8Ω / 160+160 W RMS su 4Ω
    • Frequency response: -1dB @ 12Hz e 45kHz -3 dB
    • Input impedance: 21Kohm // 300pF
    • Input sensitivity: 860mV RMS
    • Input stage: Pure A class, double triode totem pole ECC83 and parallel totem pole ECC81 This single stage due to the particular circuitry is able to amplify the input signal and drive directly the power stage.
    • Output stage: Class AB thermostable, complementary Hexfet (3 pairs for channel)
    • Number of stage: 2, This amplifier due to the particular circuitry is realized by only two stages: input stage and output stage, and use only local feedback
    • Input: 6 line (3 unbalanced, 2 balanced, 1 “bypass” unbalanced)
    • Output connectors: 4 + 4 bi-wiring
    • Global Feedback factor: 0 dB
    • THD: < 0.15% @ 1kHz, 1 W
      < 0.5% @ 1kHz, 10 W
    • Output resistance: <0.4 ohm, resistive on all audio frequencies
    • Power Consumption: 550 W (at max power on 8 ohm)
    • Dimensions: 43.5cm x 44 cm x 18 cm h
    • Net weight: 20 kg
    Giá: 79.000.000 VNĐ
    ANH DUY AUDIO
  11. AnhDuy
    AnhDuy Shop
    GIẢM 50% CHO BỘ DÀN HIEND
    LOA TĨNH ĐIỆN MARTIN LOGAN ĐẦU BẢNG CLX ART: 610 TRIỆU
    AMPLI INPOL 2 CỦA PATHOS: 165 TRIỆU
    TỔNG CỘNG: 775 TRIỆU GIẢM CÒN 388 TRIỆU
    CLX ART
    Đôi loa mành tốt nhất thế giới thuộc dòng Reserve ESL Martin Logan nổi tiếng thế giới với dòng loa mành tĩnh điện. Đôi loa đầu bảng CLX Art thuộc dòng Reserve ESLcủa Martin Logan được xem như đỉnh cao công nghệ làm loa, hướng đến những đôi tai khó tính có khả năng thẩm âm cao sành sỏi nhất.
    INPOL2
    AMPLI HIEND MẠCH INPOL CÔNG SUẤT 45W CLASS A
    MẠNH MẼ VÀ NGỌT NGÀO
    (TRÌNH TRẠNG HÀNG DEMO, THIẾU THÙNG VÀ REMOTE)
  12. AnhDuy
    AnhDuy Shop
    Giảm giá 45% Boston Acoustics M 340
    42.940.000 VNĐ ==> 23.670.000VND
    Loa đứng với 4 loa bass mạnh mẽ M340 với 1 loa treble, 1 mid và 4 loa bass. Kích thước loa nhỏ gọn nhưng âm thanh xuất sắc với âm bass sâu lắng và âm treble cao vút lên đến 30kHz.
    Tần số: (±3dB) : 45Hz - 30KHz
    Công suất đề nghị: 50-350 watts
    Độ nhạy: 88 dB
    Trở kháng: 4 ohms
    Loa bass: 4 x 114mm/ polypropylene/ aluminum Loa Mid: 1 x 114mm
    Loa treble: 25mm/ Extended Wide Bandwidth (EWB)/Dome
    Kích thước (C x N x S): 1026x224x 290mm
    Trọng lượng: 21 Kg
  13. AnhDuy
    AnhDuy Shop
    Giảm giá 45% Boston Acoustics M 350
    49.720.000 VNĐ ==> 27.346.000 VND
    loa đứng với 4 loa bass mạnh mẽ M series là dòng loa cao cấp của Boston Acoustics với thiết kế công phu, nhiều đặc điểm kỹ thuật chưa từng được ứng dụng. Dòng loa M sẽ đem lại người nghe một trung âm đặc sắc và tiếng bass thật mạnh và sâu lắng. M350 là đôi loa lớn nhất trong dòng này.
    Treble 25mm EWB dome cho âm tần số cao rõ và chính xác không méo tiếng
    Loa mid 114mm cho trung âm trong trẻo
    4 loa bass 138 mm cho tiếng bass tràn đầy
    Kỹ thuật làm thùng loa Lo-Q giảm rung chấn và triệt tiêu cộng hưởng.
    Cấu trúc thùng loa với hộc loa mid thiết kế riêng biệt để ngăn sự nhiễu âm qua lại giữa các dải tần
    Thông số
    Công suất đề nghị: 50-500 watts
    Độ nhạy: 90 dB
    Trở kháng: 8 ohms
    Loa bass: 4 x 138mm/ polypropylene/ aluminum
    Loa Mid: 1 x 114mm
    Kích thước (C x N x S): 1076 x 245 x 310mm
    Trọng lượng: 25.4 Kg
  14. AnhDuy
    AnhDuy Shop
    Giảm giá 45% Loa sub Boston Msubwoofer
    Giá: 22.380.000 VND ==> 12.309.000 VND
    Loa sub công suất 1000W. Loa có 3 loa bass với 1 loa active và 2 loa passive. Âm thanh mạnh mẽ, uy lực. Thiết kế vỏ ngoài sơn mài bóng, sang trọng.
    Thích hợp cho dàn nghe nhạc, xem phim, karaoke.
    Thông số kỹ thuật
    Tần số: (±3dB) : 23Hz - 150Hz
    Công suất 500 -1000 watts
    Trở kháng: 4 ohms
    Loa bass: 1 x 254mm ( active)/ polypropylene/2 x 203mm ( passive)
    Kích thước (C x N x S): 331 x 425 x 392mm
    Trọng lượng: 23.5 Kg
  15. AnhDuy
    AnhDuy Shop
    Giảm giá 30% DENON AVR-X2200W
    18.880.000 VNĐ ==> 13.261.000 VNĐ
    Tích hợp những kỹ thuật video và audio mới nhât, AVR-X2200W mang đến âm thanh surround tràn ngập thú vị, dựa trên nền tảng của một bộ khuếch đại công suất mạnh mẽ và âm thanh xuất sắc. Với kỹ thuật Dolby Atmos bạn sẽ trải nghiệm âm thanh surround 3 chiều như trong rạp chiếu bóng chuyên nghiệp.
    Công suất: 125W x 7(6ohm, 1kHz,THD 0.7%,)
    -- 95W x 7(8ohm, 20Hz-20kHz,THD:0.08%)
    -- Dolby Atmos 7 Channel processing (5.1.2)
    -- Mạch DSD (Direct Stream Digital)
    -- 2 zone cho 2 nguồn phát khác nhau
    -- Chuyển đổi tất cả các nguồn hình vào và up scale lên 4K (3840x 2160 pixels) cho ra ngõ HDMI
    -- Hỗ trợ “Denon Remote App” để có thể điều khiển ampli từ iPod/iPhone hoặc smartphone chạy phần mềm Android.
    -- Tính năng AirPlay có thể truyền phát các file nhạc từ iPad, iPhone và iPod touch hoặc từ iTunes trong PC đến ampli.
    -- Bluetooth cho phép các thiết bị nghe nhạc cầm tay hoặc smartphone có thể phát nhạc trực tiếp vào ampli.
    -- Kỹ thuật setup phòng phim: Audyssey MultEQ
    -- Dolby TrueHD, dts-HD Master Audio, DTSUHD, DTS:X ready (update firmwave), Dolby Pro Logic IIz, Audyssey
    -- DSD, FLAC, ALAC, AIFF qua ngõ USB
    Kết nối:
    -- Networking: AirPlay, Internet Radio, Spotify Connect, DSD & AIFF streaming và DLNA 1.5
    -- Ngõ vào : HDMI x 8 ( 1 trước, 7 sau), Opt x 2, Composite x 2, RCA Audio x 4, USB x 1
    -- Ngõ ra: HDMI x 2
    -- Cắm và phát các thiết bị iOS vào USB mặt trước
    -- Kích thước: 167 x434x339 mm
    -- Trọng lượng: 9.4Kg
  16. AnhDuy
    AnhDuy Shop
    BỘ DÀN NGHE NHẠC MINI DENON DN-8
    GIÁ 20.230.000 VNĐ GIẢM CÒN 13.000.000 VNĐ[​IMG]
    Bộ dàn mini nghe nhạc, kết nối iPod/iPhone,network, Airplay Máy có thể kết nối iPod/iPhone/iPad, kết nối internet bằng sóng wifi.
    Tương thích với các file nhạc lossless như WAV 192kHz/24bit, FLAC 192kHz/24bit
    Tương thích với App Remote Denon Công suất 65w x 2 kênh ( 4 Ohm)
    Cắm và phát nhạc trong thẻ nhớ USB.
    Phát được CD, CD-R /CD-RW (WMA or MP3).
    Nghe FM/AM.
  17. AnhDuy
    AnhDuy Shop
    Khuyến mãi tặng loa Subwoofer. Chương trình đến hết tháng 9
    Khi Mua Ampli DENON Receiver
    ➡AVR-X1300W + 1 cặp loa bất kỳ - Tặng SUB Klipsch R-8SW
    Giá AVR-X1300W: 13,500,000đ
    ➡AVR-X2300W + 1 cặp loa bất kỳ - Tặng SUB Jamo J 10
    Giá AVR-X2300W: 19,000,000đ
    ➡AVR-X3300W + 1 cặp loa bất kỳ - Tặng SUB Jamo J 10
    Giá AVR-X3300W: 26,000,000đ
    ➡AVR-X4300H + 1 cặp loa bất kỳ - Tặng SUB Klipsch R-10SW
    Giá AVR-X4300H: 39,000,000đ
    ➡AVR-X6200W + 1 cặp loa bất kỳ - Tặng SUB Klipsch R-12SW (Đến hết sản phẩm)
    Giá AVR-X6200W: 56,000,000đ
    ➡AVR-X6300H + 1 cặp loa bất kỳ - Tặng SUB Klipsch R-12 SW
    Giá AVR-X6300H: 67,000,000đ
  18. AnhDuy
    AnhDuy Shop
    Giảm giá 30% dàn xem phim, nghe nhạc DENON X520BT vs BOSTON SoundWare XS 5.1
    Ampli DENON Receiver AVR-X520BT 5.2 kênh với bluetooth streaming và HDCP 2.2, 4K ULTRA HD/60HZ VIDEO PASS-THROUGH
    Bộ loa Boston SoundWare XS 5.1 Home Theater System Hệ thống loa SoundWare XS 5.1 Có hình dáng nhỏ gọn nhưng âm thanh thật mạnh mẽ và sống động.
    Giá 21.050.000 VNĐ ==> 14.735.000 VNĐ
  19. AnhDuy
    AnhDuy Shop
    Giảm giá 30% dàn nghe nhạc, xem phim DENON X520BT vs BOSTON SoundWare XS 2.1 Stereo
    Ampli Receiver AVR-X520BT 5.2 kênh với bluetooth streaming và HDCP 2.2, 4K ULTRA HD/60HZ VIDEO PASS-THROUGH
    Hệ thống loa 2.1 kênh dùng xem phim, nghe nhạc phòng nhỏ Hệ thống loa SoundWare XS 2.1 Stereo bao gồm 2 loa nhỏ và 1 loa sub điện 100W. Dễ dàng kết nối với ampli 2 kênh như PMA-520AEđể có bộ nghe nhạc dùng phòng nhỏ. Gọn nhẹ, dễ lắp đặt.
    Giá 15.400.000 VNĐ ==> 10.780.000 VNĐ
  20. AnhDuy
    AnhDuy Shop
  21. AnhDuy
    AnhDuy Shop
    Neckband là dòng tai nghe mới của Klipsch, nằm trong chuỗi sản phẩm tai nghe nhét tai kết nối bluetooth khá thịnh hành hiện nay. Neckband có thiết kế toàn diện hướng đến sự thẩm mỹ, thời trang và đầy đủ chức năng của một tai nghe bluetooth. Nó có hai model gồm X12 Neckband và R6 Neckband.
    Với tên gọi neckband (vòng đeo cổ) hai sản phẩm tai nghe X12 Neckband và R6 Neckband có thiết kế như một chiếc vòng trang sức cho cả nam và nữ. Đây là một điều khó làm vì nếu thiên về một phái nào, vô tình sẽ làm cho chiếc tai nghe chỉ dùng cho một đối tượng hoặc nam hoặc nữ mà không được dùng rộng rãi. Đến đây ta có thể liên tưởng đến những chiếc điện thoại iPhone, vốn có thiết kế dùng chung như thế này. Mặc dù thiết kế lưỡng tính, nhưng khi người dùng nam hay nữ khi đeo vào, mặc nhiên nó như hòa hợp đến độ như thể được thiết kế cho họ vậy.
    X12 Neckband
    Trên nền tảng của chiết tai nghe nhét tai X12i, Klipsch đã nâng cấp, cải tiến nó thành chiếc tai nghe bluetooth với đầy đủ tính năng, vừa nghe nhạc với đầy đủ phím bấm chức năng, trả lời điện thoại, vừa làm vòng trang sức, và đặc biệt nó giúp người đeo tiện lợi và thoải mái nhất khi dùng. Các audiophile giờ đây có thể vừa lái xe hơn hoặc xe máy, vừa nghe nhạc chất lượng cao một cách dễ dàng.
    Khi nhìn chiếc tai nghe từ phía sau người đeo ta thấy đó là một vòng đeo trang sức. Nó được làm bằng khung thép sơn tĩnh điện, bên ngoài bọc da thật và được đánh bóng sang trọng. đoạn da này có chiều dài khoảng 10cm và được nẹp hai vòng đồng sáng có in logo Klipsch lên trên, trông cực kỳ ấn tượng. Nó cũng được may bằng chỉ nổi, tạo dáng rất thời trang, giúp người đeo tự tin khi biết nó vừa là tai nghe vừa là đồ trang sức.
    Phía ngoài cùng của khung được thiết kế để bố trí các phím chức năng. Nếu ta đeo vào cổ thì phía bên phải là tất cả các phím bao gồm, chọn nghe nhạc, chọn tới lui bài hát, bấm trả lời điện thoại. Phía bên trái chỉ là nút dò tìm bluetooth và tắt mở nguồn.
    Thiết kế kỹ thuật bên cho tai nghe này khá đặc biệt. Vì nó là dòng tai nghe X12i nên sở hữu driver loại Amature có số hiệu KG-926, có cấu trúc tí hon nằm trong vỏ nhôm thân như chiếc đũa và có lỗ vòi nghe cực nhỏ như cây tăm. Đầu vòi nghe là nút silicon nhét tai mềm mại, đủ nhỏ để nhét lọt vào tai mà không gây tí khó chịu nào. Nếu ai đã từng dùng các loại tai nghe theo điện thoại hoặc các dòng tai nghe nhét tai có đầu lớn, khi đeo tai nghe này sẽ đem lại cho bạn cảm giác thật dễ chịu êm ái. Chỉ cần cầm nó và nhét vào tai, không cần một giây suy nghĩ phải đeo nó theo chiều nào cả.
    Nói thêm một chút về driver Amature KG-926. Nó là loại dùng cho audiophile với chất âm cân bằng. Nó được định vị trong vỏ (housing) làm bằng nhôm. Mặc dù có driver nhỏ nhưng nó có đáp tuyến tần số từ 5Hz đến 19kHz, khá lý tưởng cho một tai nghe nhét tai như vậy. Chất âm cho chi tiết và mượt mà.
    Dây nối từ khung xuống tai nghe loại có tính mềm dẻo, chống xoắn và kháng nước. Đoạn dây dài khoảng 30cm mỗi bên, vừa đủ cho ta đeo ngược vào tai, khi không đeo thả xuống chấm ngang bụng.
    Khả năng kết nối bluetooth với kỹ thuật aptX và AAC phân giải cao, kết nối nhanh và sóng mạnh. Chỉ kết nối lần đầu với điện thoại, những lần sau chỉ cần bấm nút bên trái, tai nghe tự động dò tìm và kết nối chưa đến 3 giây.
    Micro loại dùng cho X12 Neckband là cVc® (Clear Voice Capture) bắt âm người nói cực rõ và không bị tạp âm ngoài đường. Đặc biệt chúng tôi đã trải nghiệm nó trên xe máy chạy ngoài đường để trả lời điện thoại, người nghe thật rõ từ đầu bên kia. Đây là một đặc điểm quan trọng đáng ghi nhận khi địa hình Việt Nam vốn chạy xe máy và ảnh hưởng nhiễu từ các bugi đánh lửa của xe. X12 Neckband có khả năng chống nước cấp độ 4 (IPX4). Pin sạc dùng lâu đến 18 giờ. Tai nghe khi nhận cuộc gọi báo rung nên dễ dàng nhận biết khi bạn không đang đeo vào tai.
    R6 Neckband
    Tai nghe R6 Neckband được phát triển trên nền tảng của chiếc tai nghe R6. Tai nghe dùng loại driver dynamic thông thường nhưng được trang bị nam châm kép nên có thể nói dòng này thiên bass, cho âm thanh mạnh mẽ và mềm tiếng.
    Vòng đeo cổ được dùng cùng loại với X12 Neckband nên rất đẹp và thẩm mỹ. Như đã nói ở trên, nó thiết kế để người đeo không cảm thấy vướng víu hay lạ lùng mà có tính trang sức cao.
    Những đặc tính kỹ thuật như kết nối bluetooth, bố cục các phím chức năng trên khung đeo, micro trả lời điện thoại đều tương tự như X12 Neckband. Cấp độ chống nước đạt đến mức IPX4 (chống nước tạt vào), pin sạc dùng liên tục 18 giờ. Chế độ báo rung khi có cuộc gọi đến.
    Mặc dù driver loại dynamic của R6 Neckband có đường kính 6.5mm nhưng vòi nghe được thiết kế cực nhỏ như một que diêm vừa đủ để chụp nút đệm silicon nhỏ để nhét vào tai một cách nhanh chóng và thoải mái như dòng X 12 Neckband vậy. Đáp tuyến tần số đo được từ 10Hz đến 19kHz. Chất âm của R6 Neckband tỏ ra vượt trội về âm bass nhưng khá trong trẻo ở dải mid, thích hợp cho bạn nghe nhiều thể loại nhạc khác nhau.
    Phụ kiện đi theo cho 2 model này đều có hộp đựng với đầy đủ dây sạc và 4 cặp nút đệm tai với 4 cỡ từ nhỏ đến lớn để người dùng chọn cho mình một cặp vừa tai.
    Klipsch là hãng loa thành danh trên 70 năm. Những năm gần đây đã chứng tỏ mình là hãng loa phát triển toàn diện tất cả sản phẩm phục vụ cho người nghe nhạc. Với dòng sản phẩm tai nghe bluetooth khung đeo này, nó đã tiếp cận đến những người nghe nhạc cá nhân bằng các thiết bị di động như smartphone hoặc máy nghe nhạc mini cầm tay.
    Giá của hai model này có mức vừa phải, X12 Neckband 7.3 triệu và R6 Neckband 3.6 triệu.
