AUDIO SƠN HÀ: HÀNG ĐẸP GIÁ TỐT ĐẦU NĂM
Discussion in 'VNAV Shop - Showrooms' started by AudioSonHa, 19/1/06.
  1. AudioSonHa
    AudioSonHa Shop
    TP HCM
    Bạn vui lòng để lại số điện thoại, bên mình sẽ chủ động liên hệ cho bạn nhé.
  2. AudioSonHa
    AudioSonHa Shop
    TP HCM
    Loa Chario Pegasus + Ampli AMR AM-777
    (Hàng Demo, còn mới, không thùng)
    AMPLI AMR AM-777
    Đặc điểm kỹ thuật:
    AM-777 Specifications
    Inputs:
    • 4 x RCA
    • 1 x XLR Bal. shared with 1 RCA
    • 1 x USB
    Volume Control:
    • -71dB – 0dB in 1dB steps + Mute
    Input Sensitivity (IHF 2.83V Out)/Impedance:
    • < 0.05V / > 20KOhm
    Analogue Outputs:
    • 1 x RCA; 1 x XLR per channel
    Power Output IHF Dynamic Power:
    • 60 watts per channel at 4 or 8 ohm (stereo mode)
    • 70 watts per channel at 8 ohm (monoblock mode)
    • 120 watts per channel at 2 or 4 ohm (monoblock mode)
    FTC:
    • 70 watts at 8 ohm (monoblock mode)
    Output impedance:
    • 0.33 ohm, 20 - 20,000 Hz
    Frequency Response (-1dB):
    • 10Hz - 30kHz
    Signal-to-noise ratio “A” weighted:
    • >100 dB
    Total Harmonic Dist. + Noise (THD+N):
    • < 0.3%
    Operational Modes:
    • Pre-Main amplifier mode;
    • Power amplifier mode
    • Monoblock option;
    Thermionic Electron Valves amplification stage:
    • 6H1n-EV fitted
    • ECC88, E88CC, 7308, Cca, 6DJ8, 6922,
    • 6H23n-EV optional
    Power Transformer:
    • 380 VA Custom Torroid (Output Stage)
    • 32 VA Custom EI Transformer (Valve Stage)
    Power consumption:
    • Standby: <1 W
    • Power on: 25 W
    • at rated output (4R): 250 W
    Power Supply Capacitance:
    • 44,000uF in total
    Rated voltage:
    • 100V/120V/230V~ AC 50Hz - 60Hz
    Mains Fuse:
    • 100V/120V: 4A slow blow; 230V: 2A slow blow
    Colour:
    • Silver or Black
    Dimensions:
    • 17.7 in W by 4.7 in H by 14.6 in D
    • 45 cm W by 12 cm H by 37 cm D
    • 57 cm W by 49 cm H by 25 cm D (shipped)
    Weight:
    • AM-777: 31 lbs / 14 kg
    • Shipped: 40 lbs / 18 kg
    CHAIRIO PEGASUS
    Đặc điểm kỹ thuật:
    • Thiết kế “bass hướng sàn”
    • Cấu hình loa cột 3 đường tiếng
    • 1 củ loa Tweeter vòm luạ 38mm (T38 Wave) có hướng âm, tần số nối với dải Mid
    • 1 củ loa Mid 170mm giấy tổng hợp với nhựa dẻo
    • 1 củ loa Woofer 170mm giấy tổng hợp với nhựa dẻo nằm gần đáy, hướng sàn
    • Độ nhạy 90dB
    • Tần số đáp ứng 45 – 20.000Hz, điểm cắt tần số ở 170/1.500Hz
    • Trở kháng 4Ω
    • Ampilfier được đề nghị 50 watt – 140 watt/4Ω
    • Kích thước cao – rộng – sâu 1030 x 230 x 370 mm
    • Khối lượng 26kg.
    Giá: 140.000.000đ/ 1 Bộ
    (Liên hệ điện thoại để có giá tốt. Hotline 0908.812.754)
  3. truong tri thanh
    truong tri thanh Advanced Member
    toàn hàng đẹp quá shop. tiếc là ở xa
  4. AudioSonHa
    AudioSonHa Shop
    TP HCM
    Bên mình có ship cho người ở xa, bạn yên tâm. Bạn cần gì cứ liên hệ hotline 0908.812.754 nhé
  5. AudioSonHa
    AudioSonHa Shop
    TP HCM
    Re: AUDIO SƠN HÀ:Hàng đẹp giá tốt từ trang 1 đến trang cuối
    Combo Micro Seiki BL-111, Cần SME 3010
    (Hàng Demo, điện 110V nguyên bảng. Made in Japan. Không Kim.)
    Giá: 87,000,000 VND
    (Liên hệ điện thoại........)
  6. AudioSonHa
    AudioSonHa Shop
    TP HCM
    Dây XLR MIT Oracle MA-X2
    (Hàng Demo thật đẹp. Dây dài 10 mét. Thùng bọng đầy đủ)
    Giá: 218.000.000 VNĐ/ 1 cặp giảm còn 165 tr
    (Liên hệ điện thoại ...)
  7. AudioSonHa
    AudioSonHa Shop
    TP HCM
    Mark Levinson Nº532 Power Amplifiers
    (Hàng Demo thùng xốp sách đầy đủ. Còn bảo hành, hàng chính hãng )​
    Tham khảo: http://audiosonha.com/sp/mark-levinson-no532--power-2275
    Giá: 290.000.000/ 1 Cái
    (Liên hệ điện thoại để có giá tốt..........)
  8. AudioSonHa
    AudioSonHa Shop
    TP HCM
    Chuột Entreq Vibb Eater
    (Hàng mới nguyên bảo hành chính hãng)​
    Một trong những sản phẩm thú vị nhất ủa Entreq chính là những chú chuột Vibb ater. Hệ thống loa gồm nhiều loa con thường được bố trí ở mặt trước của loa.
    Với loa treble, màng loa sẽ dao động từ khoảng đến trền 20Khz, các loa con khác như mid, bass cũng dao động ở dải tần thấp hơn vô hình chung làm cho mặt trước của loa, nơi giữ các loa con, cũng rung động khoảng từ 400 đến 900Hz. Những rung động này chắc chắn sẽ làm ảnh hưởng đến màng loa treble nhạy cảm, làm méo tiếng, mất chi tiết.
    Tương tự với các loa mid và đặc biệt là loa bass, khi thùng loa có xu hướng di chuyển theo 2 chiều tới/lùi, màng loa bass cũng di chuyển theo hai hướng này, nó sẽ làm giảm tốc độ di chuyển màng do lực triệt tiều, dẫn đến chất âm trầm thiếu độ chắc khỏe.Chuột Vibb Eater hoàn toàn vô hại, đúng như tền gọi của nó (Vibberation Eater), chú chuột sẽ “ăn” những rung chấn có hại này.
    Vibb Eater cấu tạo từ bột đồng được xay nhuyễn, kết hợp với một số kim loại quý. Chính những kim loại quý sẽ giúp tối ưu hóa vùng tự trường của loa con treble, giúp loa hoạt động tốt hơn.
    Chuột Entreq có trọng lượng từ 1 đến 4kg, bạn có thể chọn cho mình một đôi chuột phù hợp với bộ loa đang sử dụng. Những tác dụng ngay lập tức mà bạn có thể nhận ra chính là treble trở nền rõ nét hơn và bớt độ chói, dải trầm nhanh và chắc hơn.
    Tham khảo: http://phukienaudio.com/p/1041-entreq-v ... jumpo-1cai
    Apollo Loa Máy > 70Kg giá Đang cập nhật Hãy DT cho chúng tôi
    Jumbo loa máy > 40 kg giá
    Maxi loa máy > 30 kg Giá
    Midi loa máy > 20 kgs Giá: 1 Cặp
    Ultra chuyên cd, pre Giá: 1 Cặp
    (Liên hệ điện thoại để có giá tốt..............)
  9. AudioSonHa
    AudioSonHa Shop
    TP HCM
    Thiết bị nối mát Entreq
    Theo nhà sản xuất, thiết bị giảm nhiễu nội và ngoại sinh bằng cách phân tán ion âm gây nhiễu có chủ đích, cho đường đi của tín hiệu âm thanh liền mạch, không bị ngắt quãng, giảm độ ồn giữa các nốt nhạc, các dải âm, cho âm thanh tự nhiên như vốn có, rộng mở, không gian âm nhạc tự nhiên... Thiết bị này không làm thay đổi chất âm của thiết bị âm thanh, mà chỉ làm cho nền âm tĩnh nhất.
    Thoạt đầu tôi hơi hoang mang vì... dường như không thấy sự cải thiện nào?! Tuy nhiên, điều đó khẳng định việc cấp mát không làm ảnh hưởng theo hướng thay đổi chất âm. Sau khi nghe được vài nhịp, tôi bắt đầu thấy sự khác biệt. Nền âm tĩnh hơn, từng tiếng đàn mạch lạc, tự nhiên hơn, giữa các nốt nhạc không có tiếng ồn... Nghĩa là, tiếng nhạc trong trẻo, chặt chẽ, chi tiết, rộng và động hơn, nghe thấy to hơn. Những cải thiện chỉ đến mức cho ta thấy rõ (và phê) chứ không làm biến đổi chất âm gốc. Khi rút dây tiếp mát ra khỏi giắc RCA đực, người nghe cũng không thấy ngay sự thay đổi trong chất âm mà cũng phải vài nhịp sau mới thấy. Đây cũng là giá trị cơ bản của thiết bị cấp mát. Có thêm thiết bị cấp mát, tiếng nhạc phát ra từ dàn máy hay và sang trọng hơn, dễ nghe và muốn nghe lâu
    Tham khảo:http://phukienaudio.com/ncc/7-phu-kien/287-entreq
    Tellus II - 3 ngõ mát độc lập Giá:DT
    Silver Tellus - 4 ngõ mát DT
    Silver Minimus - 1 ngõ mát DT
    Olympus Minimus - 1 ngõ DT
    Olumpus Tellus - 7 ngõ mát DT
    Poseidon - 3 ngõ mát Giá 1 Cái
    Silver Cleanus - Power Cleaning Giá DT
  10. AudioSonHa
    AudioSonHa Shop
    TP HCM
    Dây loa Acrolink 6N S5000
    (Hàng Demo còn rất đẹp. Dây dài 2m)​
    Giá: 30.500.000đ/ 1 cặp
  11. AudioSonHa
    AudioSonHa Shop
    TP HCM
    Tannoy DC 10A
    (Hàng Demo tại Cty thùng xốp đầy đủ. Còn đẹp như mới)​
    Giá: 195,.000.000đ/ 1 cặp
