có bác nào có loa bose 601 iii làm ơn cân giúp em xem chính xác bao nhiêu kg với cứ cãi nhau thật giả nặng nhẹ
Specs đây bác; Technical data Driver complement (per enclosure) Two 8'' long-excursion Digital Dynamic Range woofers and four 3'' tweeters mounted in a Free Space array Nominal impedance 8 Ohms Power rating 200 watts IEC, compatible with amplifiers/receivers rated from 10 to 350 watts per channel Fusing Series-connected 2A fast-blow fuse recommended Cabinets Genuine hardwood veneer with walnut finish Dimensions 30''H x 12 3/16''W x 12 1/2''D (30.89 x 31.75 x 76.2 cm) Weight 45 lbs (20.41 kg) per speaker
