Linh kiện làm DAC danh sách CD Player và DAC chip ACOUSTIC RESEARCH CD-07 -> SAA7220 ACCUPHASE DP65 -> 8x PCM1702 (4/ch) ACCUPHASE DP85 -> AD1853 ACCUPHASE DP90 -> PCM63 ADC CD 250XR -> PCM54 AKAI CD37 -> PCM67P AKAI CD55 -> AD1856 AKAI CD57 -> PCM67P-J AKAI CD69 -> PCM63 AKAI CD73 -> PCM56 AKAI CD93 -> PCM56 AKAI CD-M839 -> PCM56 ALBA CD420 -> PCM54 ALCHEMIST NEXUS APD32A -> 2x TDA1549 AMC CD60 -> PCM1716 AMC CD8A -> MN6474 (Technics MASH) AMC CD8B -> PCM1716 ANTHEM CD1 -> PCM1702 ARCAM ALPHA 5 -> TDA1541 ARCAM ALPHA 5 PLUS -> TDA1541A ARCAM ALPHA 6 -> SM5864 ARCAM ALPHA 7 -> PCM1710 ARCAM ALPHA 7SE -> PCM1716 ARCAM ALPHA 8 -> SM5864AP ARCAM ALPHA 9 -> dCS RingDAC ARCAM CD72 -> PCM1716 ARCAM CD92 -> dCS RingDAC ARCAM DELTA 70.2 -> TDA1541AS1 (single crown) ARCAM DELTA 270 -> PCM69 ARCAM DELTA BOX 5 -> PCM67 ARYE CX-7 -> PCM1738 ARYE D-1 -> PCM1704 AUDIO ALCHEMY ENGINE v3.0 -> AD1862 AUDIO ANALOGUE MAESTRO -> AD1855 AUDIO INNOVATIONS ALTO -> PCM1716 AUDIO NOTE CD-1 -> PCM1710 AUDIO NOTE CD-2 -> AD1865 AUDIO NOTE DAC-3 -> PCM63 AUDIO RESEARCH CD1 -> SAA7341 AUDIOLAB 8000 CD -> CS4329 AVI SC2000MC -> PCM63 BLAUPUNKT CP2650 -> PCM54 BLAUPUNKT CP2990 -> PCM56P CAMBRIDGE AUDIO CD1 -> TDA1541 CAMBRIDGE AUDIO CD2 -> 4x TDA1541 CAMBRIDGE AUDIO CD3 -> TDA1541A CAMBRIDGE AUDIO CD4SE -> CS4327 CAMBRIDGE AUDIO CD6 -> TDA1305T CAMBRIDGE AUDIO D500 -> CS4327 CARVER SD/A 450 -> MN6474 C.E.C. 530CD2 -> Y3015 C.E.C. 680CD -> LC7881 CONDOR CD950 -> YM3020 COPLAND CDA277 -> PCM63 COPLAND CDA288 -> PCM63-K CROWN CD2111R -> LC7881 CYRUS CD7 -> PCM1716 CYRUS dAD1 -> TDA1311 CYRUS dAD3 -> TDA1305 CYRUS dAD3Q -> AD1861 CYRUS dAD7 -> AD1861 DENON DA-500 -> PCM1702 DENON DCD-435 -> PCM1716E DENON DCD-480 -> PCM61 DENON DCD-485 -> PCM1735 DENON DCD-500 -> PCM54 DENON DCD-580 -> PCM67P DENON DCD-590 -> PCM61 DENON DCD-615 -> PCM61P DENON DCD-635 -> PCM61P DENON DCD-650F -> PCM1700P DENON DCD-655 -> PCM1702 DENON DCD-660 -> 2x PCM61 DENON DCD-680 -> PCM69A DENON DCD-685 -> PCM1702 DENON DCD-690 -> PCM61 DENON DCD-695 -> PCM61 DENON DCD-700 -> PCM54HP DENON DCD-725 -> PCM61P-L DENON DCD-735 -> PCM61 DENON DCD-755AR -> PCM1702 DENON DCD-800 -> PCM54 DENON DCD-820 -> PCM56 DENON DCD-890 -> PCM61P DENON DCD-920 -> PCM61 DENON DCD-980 -> PCM61P DENON DCD-1015 -> PCM61P DENON DCD-1100 -> PCM53JP-V DENON DCD-1400 -> PCM56 DENON DCD-1420 -> PCM54HP DENON DCD-1450AR -> PCM1702 DENON DCD-1460 -> PCM61P DENON DCD-1500 -> PCM54HP-K DENON DCD-1500mk2 -> PCM56P-J DENON DCD-1520 -> PCM64 DENON DCD-1530 -> PCM61 DENON DCD-1550R -> PCM61 DENON DCD-1550AR -> PCM61P DENON DCD-1560 -> PCM1701 DENON DCD-1650R -> PCM1702 DENON DCD-1800 -> PCM53 DENON DCD-2560 -> 4x AD1862 DENON DCD-2700 -> 4x PCM1702J DENON DCD-S10/3000 -> PCM1702J DENON DCD-3300 -> PCM56P-K DENON DCD-3520 -> PCM64 DENON DCD-3560 -> PCM58P-K DENON DCD-S1 -> PCM1702 DENON DCM-280 -> PCM1748 DENON RCD-100 -> PCM1710 DENON UCD-F10 -> PCM61 DIORA CD-502 -> TDA1543 DUAL CD130 -> CX20017 DUAL CD20 -> PCM53 EXPOSURE CD -> TDA1545A EZO FOG STAGE3 -> AD1853 FISCHER AD935 -> LC7881 FISCHER Z1 -> PCM58 GRUNDIG CD103 -> LC7881 GRUNDIG CD9000 -> TDA1541A HARMAN KARDON HD200 -> YM3020 HARMAN KARDON HD500 -> PCM53 HARMAN KARDON HD710 -> MN6474 HARMAN KARDON HD720 -> PCM1710 HARMAN KARDON HD730 -> SAA7350 HARMAN KARDON HD740 -> PCM1702U HARMAN KARDON HD760 -> PCM1702 HARMAN KARDON HD7225 -> MN6474 HARMAN KARDON HD7300 -> PCM61 HARMAN KARDON HD7325 -> MN6474 HARMAN KARDON HD7525 -> PCM61P HELIOS MODEL1S -> CS4328 (36 bit, ETNA) HELIOS MODEL2S -> CS4328 (36 bit, ETNA) HELIOS MODEL3S -> CS4328 (36 bit, ETNA) HELIOS STARGATE -> CS4328 (36 bit, ETNA) HEYBROOK SIGNATURE -> PCM67 HIGH TECH GOLDLINE CX904 -> YM3020 JVC XL V22 -> PCM54 JVC XL V221 -> LC7881 JVC XL V250BK -> PCM56 JVC XL V311BK -> MN6471 JVC XL V464 -> MN35500 JVC XL V1100 -> PCM54 KENWOOD DP47 -> TD6720N KENWOOD DP460 -> TD6709N KENWOOD DP850 -> CX20152 KENWOOD DP-880SG -> PCM56P KENWOOD DP1080 -> LC78620E KENWOOD DP1100D -> CX20152 KENWOOD DP1510 -> PCM56 KENWOOD DP2000 -> CX20152 KENWOOD DP2010 -> PCM56P KENWOOD DP2080 -> LC78620E (LC78820) KENWOOD DP3080 -> SM5864 KENWOOD DP4090 -> KAN03 KENWOOD DP5020 -> PCM1701P KENWOOD DP5090 -> MN35502 JVC KENWOOD DP7002 -> PCM1702 KENWOOD DP7030 -> CXD2552 KENWOOD DP7060 -> TDA1547 KENWOOD DP7090 -> 8x PCM1702 KOREA CHINA CD 022 -> KDA0316LN KOREA HCD 630 -> Y3015 KRELL KAV280 -> PCM1704 LINN GENKI -> PCM1723 LUXMAN D 102 -> TD6709N LUXMAN D 103 -> PCM1701 LUXMAN D 112 -> 1x PCM56 (s/h) LUXMAN D2 92 -> LC7881 MARANTZ CD7 -> TDA1541AS2 (double crown) MARANTZ CD10 -> TDA1547 MARANTZ CD11LE -> TDA1547 MARANTZ CD11mkII -> TDA1547 MARANTZ CD14 -> TDA1547 MARANTZ CD15 -> TDA1547 MARANTZ CD16D -> TDA1547 MARANTZ CD17mkII -> TDA1547 MARANTZ CD19 -> SM5872 MARANTZ CD38 -> TDA1545 MARANTZ CD40 -> TDA1541A MARANTZ CD42 -> SAA7350 MARANTZ CD43 -> SM5872BS MARANTZ CD45 -> TDA1540 MARANTZ CD48 -> TDA1549 MARANTZ CD50 -> TDA1541 MARANTZ CD52 -> SAA7321GP MARANTZ CD52SE -> SAA7350 MARANTZ CD53 -> SM5872BS MARANTZ CD56 -> TDA1541 MARANTZ CD60 -> TDA1541A MARANTZ CD63 -> SM5872BS MARANTZ CD63mkII -> SM5872 MARANTZ CD63mkII KI -> SM5872 MARANTZ CD63SE -> SM5872BS MARANTZ CD65 -> TDA1541 MARANTZ CD65mkII -> TDA1541A MARANTZ CD67 -> SM5872 MARANTZ CD67SE -> SM5872 MARANTZ CD67mkII OSE -> SM5872 MARANTZ CD72 -> SAA7350 MARANTZ CD72mkII SE -> TDA1547 MARANTZ CD73 -> 2x TDA1540 MARANTZ CD74 -> 2x TDA1540 MARANTZ CD80 -> TDA1541 MARANTZ CD84 -> TDA1540 MARANTZ CD85 -> TDA1541 MARANTZ CD94 -> TDA1541A MARANTZ CD94mkII -> 2x TDA1541AS1 (single crown) MARANTZ CD4000 -> TDA1545 MARANTZ CD5000 -> TDA1549 MARANTZ CD6000 -> SM5872 MARANTZ CD6000KI -> SM5872 MARANTZ CD6000OSE -> 2x SM5872 MARK LEVINSON No. 36 -> PCM1702 (PCM1704) MARK LEVINSON No. 390S -> AD1853 MERIDIAN 508 -> CS4329 MICROMEGA LEADER -> SAA7321GP MICROMEGA LOGIC -> SAA7321 MICROMEGA PREMIUM18 -> CS4327 MICROMEGA STAGE2 -> SAA7321GP MICROMEGA STAGE6 -> TDA1305 MISSION dAC5 -> TDA1547 MISSION dAD3 -> TDA1305 MISSION PCM4000 -> TDA1541 MITSUBISHI DP109 -> PCM56 MITSUBISHI MC5100 -> PCM56 MUSICAL FIDELITY A2 -> YDC103 MUSICAL FIDELITY DIGILOG -> TDA1541 MUSICAL FIDELITY E60 -> YDC103 MUSICAL FIDELITY E624 -> PCM1716 MUSICAL FIDELITY Tri-Vista -> PCM1738 MUSICAL FIDELITY X-Ray -> PCM1716 MYRYAD T-10 -> CS4327 MYRYAD T-20 -> CS4327 MYRYAD MC100 -> CXD2565 NAD 502 -> MN6474AM NAD 510 -> SAA7350 NAD 512 -> MN6474 NAD 522 -> PCM1710 NAD C541i -> PCM1710 NAD 5100 -> PCM56 NAD 5325 -> LC7881 NAD 5425 -> MN6471M NAD C520 -> PCM1710 NAD S500 -> CS4390 NAIM AUDIO CD1 -> TDA1541 NAIM AUDIO CD2 -> TDA1541 NAIM AUDIO CD3 -> TDA1541 NAIM AUDIO CD3.5 -> TDA1305 NAIM AUDIO CD5 -> TDA1305 NAIM AUDIO CDI -> TDA1541AS1 (single crown) NAIM AUDIO CDS11 -> PCM1702K NAKAMICHI CD PLAYER 1 -> PCM1700P NAKAMICHI CD PLAYER 4 -> AD1864N NAKAMICHI MB 4 -> LC78840 NAKAMICHI MB 5 -> LC78840 NAKAMICHI CDP 2E -> TDA1541A NAKAMICHI OMS 1E -> PCM56 NAKAMICHI OMS 4E -> PCM54 NAKAMICHI OMS 5E -> TDA1540 NAKAMICHI OMS 7E -> PCM54 NEC CD610 -> PCM54 ONKYO DX-704 -> MN6472 (Technics MASH) ONKYO DX-6430 -> YM3020 ONKYO DX-6470 -> PCM56 ONKYO DX-6550 Integra -> TC9219 (ONKYO 8D-3170-1) ONKYO DX-6570 -> PCM58 ONKYO DX-6620 -> LC7881 ONKYO DX-6850 Integra -> 2x SM5861 ONKYO DX-7011 -> TC9237 ONKYO DX-7211 -> SM5874 ONKYO DX-7333 -> TC9268P ONKYO DX-7500 -> ONKYO 8S-3380-1 ONKYO DX-7711 Integra -> 2x SM5864AP ONKYO DX-7911 Integra -> 2x SM5864AP ORELLE CD100 -> TDA1541 PARASOUND CD M839 -> PCM56 PARASOUND C/DP1000 -> PCM67 PHILIPS CD-80 -> TDA1541 PHILIPS CD-85M -> TDA1541 PHILIPS CD-94M -> TDA1541 PHILIPS CD-100 -> TDA1540 PHILIPS CD-101 -> TDA1540 PHILIPS CD-104 -> TDA1540 PHILIPS CD-200 -> TDA1540 PHILIPS CD-202 -> TDA1540 PHILIPS CD-204 -> TDA1540 PHILIPS CD-210 -> TDA1543 PHILIPS CD-300 -> 2x TDA1540 PHILIPS CD-303 -> 2x TDA1540 PHILIPS CD-304 -> TDA1540 PHILIPS CD-304 MkII -> TDA1541 PHILIPS CD-350 -> TDA1541 PHILIPS CD-380 -> TDA1543 PHILIPS CD-460 -> TDA1541 PHILIPS CD-465 -> TDA1541 PHILIPS CD-471 -> TDA1541 PHILIPS CD-472 -> TDA1541 PHILIPS CD-473 -> TDA1541 PHILIPS CD-480 -> TDA1543 PHILIPS CD-482 -> TDA1543 PHILIPS CD-581 -> TDA1541 PHILIPS CD-582 -> TDA1541 PHILIPS CD-604 -> TDA1543 PHILIPS CD-610 -> TDA1541 PHILIPS CD-614 -> TDA1543 PHILIPS CD-615 -> TDA1543 PHILIPS CD-620 -> TDA1541 PHILIPS CD-624 -> SAA7323 PHILIPS CD-630 -> TDA1541 PHILIPS CD-634 -> SAA7321 PHILIPS CD-640 -> TDA1541 PHILIPS CD-650 -> TDA1541 PHILIPS CD-670 -> TDA1541 PHILIPS CD-721 -> TDA1545A PHILIPS CD-723 -> TDA1545 PHILIPS CD-750 -> SAA7350 (vagy TDA1549) PHILIPS CD-751 -> TDA1549 PHILIPS CD-753 -> TDA1549 PHILIPS CD-782 -> TDA1541 PHILIPS CD-820 -> TDA1541A PHILIPS CD-850 -> TDA1541 PHILIPS CD-880 -> TDA1541AS1 (single crown) PHILIPS CD-910 -> SAA7341GP PHILIPS CD-911 -> SAA7341GP PHILIPS CD-930 -> SAA7350 PHILIPS CD-931 -> SAA7350 PHILIPS CD-950 -> TDA1547 PHILIPS CD-951 -> TDA1547 PHILIPS CD-960 -> TDA1541 PHILIPS CDR-950 -> AD1855 PHILIPS LHH-100 -> TDA1547 PHILIPS LHH-500 -> TDA1547 PHILIPS LHH-600 -> TDA1547 PHILIPS LHH-800 -> TDA1547 PHILIPS LHH-1000 -> TDA1541 PHILIPS MAGNAVOX CDB-560 -> TDA1541 PHILIPS MAGNAVOX CDB-650 -> TDA1541 PINK TRIANGLE NUMERAL -> TDA1305T PIONEER DV-717 -> PE8001A PIONEER PD-52 -> PD2028 PIONEER PD-75 -> PD2028A (vagy PD2028B) PIONEER PD-77 -> PD2028B PIONEER PD-93 -> PD2028A PIONEER PD-95 -> PD2028A (vagy PD2028B) PIONEER PD-204 -> PD2026B PIONEER PD-4500 -> PCM1700 PIONEER PD-4550 -> PCM1700P PIONEER PD-5100 -> PD0034 PIONEER PD-5300 -> PCM56 PIONEER PD-5700 -> PD2026A PIONEER PD-7300 -> PCM58P PIONEER PD-7700 -> PD2026A PIONEER PD-8500 -> PCM63P PIONEER PD-9300 -> PCM58 PIONEER PD-9700 -> PD2028A PIONEER PDR-04 -> AKM4321 PIONEER PDR-609 -> PCM1716 PIONEER PDR-W739 -> PCM1716 PIONEER PDR-W839 -> PCM1716 PIONEER PD-S06 -> PCM1702J PIONEER PD-S502 -> PD2026B PIONEER PD-S505 -> PD2029A PIONEER PD-S507 -> PE8001A PIONEER PD-S605 -> PD2029A PIONEER PD-S703 -> PD2029A PIONEER PD-S707 -> PE8001A PIONEER PD-S801 -> PD2028 PIONEER PD-S802 -> PD2028B PIONEER PD-S901 -> PD2028B PIONEER PD-S904 -> PD2028B PRIMARE D20 -> AKM4324 PRIMARE D302 -> 4x PCM1702 PROCEED PCD2 -> PCM58P PROTON AC423 -> LC78820 PROTON AC424 -> TDA1311A QUAD66 -> TDA1541A QUAD77 -> CS4328 REGA PLANET -> PCM1710U REVOX B225 -> TDA1540 REVOX B226 -> TDA1541 REVOX C221 -> SAA7310 ROKSAN ATTESSA DP3P -> CS4328 ROKSAN CASPIAN -> TDA1305 ROTEL RCD-02 -> PCM1732 ROTEL DCM-9PRO -> PCM63 ROTEL RCD-855 -> TDA1541 ROTEL RCD-856BX -> SAA7323 ROTEL RCD-865BX -> SAA7323 ROTEL RCD-945AX -> SAA7341GP T ROTEL RCD-955 -> TDA1541 ROTEL RCD-961 -> PCM1732U ROTEL RCD-965BX -> SAA7323GP T ROTEL RCD-970BX -> TDA1305T ROTEL RCD-971 -> PCM63 ROTEL RCD-975 -> TDA1305T ROTEL RCD-991 -> PCM63P ROTEL RCD-1070 -> PCM1732 SANSUI CD V1000 -> PCM56 SANYO CP489 -> LC7881 SEG CD200 -> YM3020 SHARP DX112 -> IR 3K16BM SHARP DX650 -> LC7880 SHERWOOD CD1 -> TDA1547 SHERWOOD CD1060C -> D6372 CX SHERWOOD CD1160R -> PCM56 SHERWOOD CD1192R -> YM4113B SHERWOOD CDC2000C -> µPD6376 SHERWOOD CDC2010RC -> µPD6376 SHERWOOD CD4030R -> SAA7350BS SIMAUDIO MOON ECLIPSE -> 4x PCM1704K SONIC FRONTIERS SFCD1 -> UltraAnalog D20400A SONY CDP-40 -> 1x PCM54 (s/h) SONY CDP-101 -> CX20017 SONY CDP-222ES -> PCM56P J SONY CDP-222ESD -> 1x TDA1541 SONY CDP-227ESD -> TDA1541 SONY CDP-228ESD -> PCM58P SONY CDP-302ES -> CX20152 SONY CDP-303ESII -> CX20152 SONY CDP-333ESA -> CXD2562 SONY CDP-333ESD -> TDA1541 SONY CDP-333ESJ -> CXD2562 SONY CDP-337ESD -> TDA1541 SONY CDP-497 -> CXD2561 SONY CDP-501ES -> CX20017 SONY CDP-502 -> PCM54 SONY CDP-502ES -> CX20152 SONY CDP-520ESII -> CX20152 SONY CDP-552 -> PCM54 SONY CDP-553ESD -> PCM53JP-V K SONY CDP-555ESA -> CXD2562 SONY CDP-555ESD -> TDA1541A SONY CDP-555ESJ -> CXD2562 SONY CDP-557ESD -> PCM58P SONY CDP-620 -> PCM54 SONY CDP-650 -> PCM54 SONY CDP-701ES -> CX20017 SONY CDP-707ESD -> PCM58P SONY CDP-777ESA -> CXD2562Q SONY CDP-M95 new -> TDA1541 SONY CDP-MS1 -> CXD8594 + CXA8042AS SONY CDP-R3 + DAS-R1a -> CXD2552Q + CXD2552 SONY CDP-X229ES -> CXD2562Q SONY CDP-X3000 -> CXD2562Q + CXA8042AS SONY CDP-X303ES -> CXD2562Q SONY CDP-X5000 -> CXD2562 + CXA8042 SONY CDP-X505ES -> CXD2562Q SONY CDP-X33ES -> CXD2552Q SONY CDP-X55ES -> CXD2552 SONY CDP-X777ES -> CXD2552BQ SONY CDP-X779ES -> CXD2562 SONY CDP-X77ES -> CXD2552 SONY CDP-X7ESD -> PCM58P S SONY CDP-X900 -> CXA8042 SONY CDP-XA30ES -> CXD2562Q + CXA8042AS SONY CDP-XA50ES -> CXA8042AS SONY CDP-XA55ES -> CXD8594Q + CXA8042S SONY CDP-XA5ES -> CXD2562Q + CXA8042AS SONY CDP-XA7ES -> CXD2562 + CXA8042AS SONY CDP-XB920 -> CXD8715 + CXA8355 SONY CDP-XB720E -> CXD8735N SONY CDP-XB930 -> CXD8735N SONY CDP-XE300 -> CXD8567 SONY CDP-XE330 -> CXD2529Q SONY CDP-XE900 -> CXD8505 + CXA8055 SONY DAS-R1 -> 2x TDA1541AS1 (single crown) SOUND WAVE CD1100 -> LC7881 SUDGEN OPTIMA -> TDA1543 SUDGEN SDA-1 -> TDA1541 SUDGEN SDT-1 -> TDA1541AS1 (single crown) T+A CD1210R -> SM5864AP TAG McLAREN CD20R -> CS4329 TALK ELECTRONICS THUNDER 3 -> CS4390 TASCAM CD201 -> MN6474 TEAC CPD3450SE -> YDC103 TEAC PD155mk2 -> Y3015 TEAC PD160 -> TC9218F TEAC PD365 -> YM7121B TEAC VRDS 7 -> SAA7350 TEAC VRDS 8 -> PCM1702 TEAC VRDS 9 -> PCM1702 TEAC VRDS 10SE -> TDA1547 TEAC VRDS 25 -> AD1862J TEAC ZD5000 -> PCM53 TECHNICS SL-P1 -> PCM53 TECHNICS SL-P2 -> PCM53 TECHNICS SL-P110 -> PCM54HP TECHNICS SL-P120K E -> PCM54HP TECHNICS SL-P272A -> MN6474 TECHNICS SL-P770 -> 2x PCM56P + 2x PCM56P-J TECHNICS SL-P990 -> 4x PCM56P-J TECHNICS SL-P1200 -> PCM54HP TECHNICS SL-PG480A -> MN662713 TECHNICS SL-PJ28A -> MN6477 TECHNICS SL-PS670D -> MN6474 TECHNICS SL-PS700 -> MN6474 TECHNICS SL-PS770A -> MN64733 THETA DSP -> PCM67 THOMSON LAD300 -> TD6720N THULE CD100 -> CS4303 THULE SPIRIT -> PCM1715U TOSHIBA XR40 -> TD6705AP UHER UCD-210 -> LC7882 UNIVERSUM CD4682 -> PCM56 USHER CD-100 -> PCM1732 WADIA 23 -> AD1865 WADIA 850 -> PCM1702 WADIA 860 -> 4x PCM1702 WADIA 861 -> 4x PCM1704 YAMAHA CD-2 -> PCM53 YAMAHA CD-3 -> PCM53 YAMAHA CD-2000 -> PCM54HP YAMAHA CDX-3 -> PCM54 YAMAHA CDX-410 -> PCM56 YAMAHA CDX-420 -> PCM56 YAMAHA CDX-470 -> YDC103 YAMAHA CDX-480 -> MN66271 YAMAHA CDX-490 -> MN66271R YAMAHA CDX-580 -> YAC514 YAMAHA CDX-590 -> YAC514 YAMAHA CDX-593 -> YAC514 YAMAHA CDX-700 -> PCM56 YAMAHA CDX-810 -> 2x PCM56J YAMAHA CDX-880 -> YAC514 YAMAHA CDX-890 -> YAC514 YAMAHA CDX-893 -> YAC514 YAMAHA CDX-900 -> PCM56 YAMAHA CDX-993 -> YAC514F YAMAHA CDX-1100 -> PCM56 YAMAHA CDX-2020 -> PCM58
nỮA Accuphase DP-90 16.9344 Akai CD-9 16.9344 Akai CD-69 16.9344 Akai CD-79 16.9344 Anthem CD1 33.8688 Arcam 70.2 11.2896 Arcam 70.3 11.2896 Arcam 170.3 11.2896 Arcam Alpha 11.2896 Arcam Alpha Plus 11.2896 Arcam Alpha 5 11.2896 Arcam Alpha 5 Plus 11.2896 Arcam Alpha 6 22.5792 Arcam Alpha 7 16.9344 Arcam Alpha 9 16.9344 Arcam Delta 11.2896 Arcam Delta 270 16.9344 Audio Note CDT-Zero 16.9344 Audiocom Super DVD-001 22.5792 Audiocom Super DVD-002 22.5792 Audiomeca Mephisto 11.2896 AVM Evolution CD1 16.9344 AVM DAC 1.2 16.9344 AVM DAC 2 16.9344 Cambridge CD3 11.2896 Cambridge CD4 16.9344 Cambridge CD6 11.2896 Cambridge Discmagic 1 16.9344 Cary Audio CD-301 16.9344 Cary Audio CD-302 16.9344 CDM-12 Pro (Philips Mech) 8.4672 CEC TL-1 16.9344 CEC TL-2X 16.9344 CEC TL-5100 16.9344 Copland CDA-288 16.9344 Creek CD-43 16.9344 Denon DA-500 16.9344 Denon DCD-70 16.9344 Denon DCD-725 16.9344 Denon DCD-860 16.9344 Denon DCD-980 16.9344 Denon DCD-1015 16.9344 Denon DCD-1500 8.4672 Denon DCD-1500-11 16.9344 Denon DCD-1520 16.9344 Denon DCD-1550R 16.9344 Denon DCD-1560 16.9344 Denon DCD-2560 16.9344 Denon DCD-2700 16.9344 Denon DCD-3000 16.9344 Denon DCD-3300 16.9344 Denon DCD-3520 16.9344 Denon DCD-3560 16.9344 Denon DCD-S1 16.9344 Denon DCD-S10 16.9344 Denon DCD-UCD-F10 16.9344 Denon DVD-5000 27.000 & 33.8688 DPA Enlightenment DAC DX-32 16.9344 (Sync O/P) Einstein 16.9344 Elektor DAC 10/92 16.9344 Grundig CD-3 11.2896 Grundig CDP-100 16.9344 Harman/Kardon HK-7725 16.9344 Harman/Kardon HD-730 16.9344 Heart CD-6000 16.9344 Holfi Xara 16.9344 Holfi Xara SE 16.9344 JVC XLN-1050TN 16.9344 Kenwood DP-3300D 16.9344 Kenwood DP-5090 16.9344 Kenwood DP-7020 16.9344 Kenwood DP-7030 45.1584 Kenwood DP-7060 16.9344 Kenwood DP-7090 16.9344 Kenwood DPX-9010 16.9344 Kenwood L-1000D 67.7376 Kenwood L-D1 16.9344 Linn Mimik 16.9344 Marantz CC-4300 16.9344 Marantz CD-10 11.2896 Marantz CD-11 11.2896 Marantz CD-12 11.2896 Marantz CD-14 33.8688 Marantz CD-15 33.8688 Marantz CD-16 33.8688 Marantz CD-17 16.9344 Marantz CD-17 KI 16.9344 Marantz CD-17 Mk2 33.8688 Marantz CD-19 16.9344 Marantz CD-43 16.9344 Marantz CD-52 11.2896 Marantz CD-52 SE 11.2896 Marantz CD-53 16.9344 Marantz CD-56 11.2896 Marantz CD-63 16.9344 Marantz CD-63 SE 16.9344 Marantz CD-67 16.9344 Marantz CD-67 OSE 16.9344 Marantz CD-72 11.2896 Marantz CD-72 SE 11.2896 Marantz CD-80 11.2896 Marantz CD-85 11.2896 Marantz CD-93 16.9344 Marantz CD-94 11.2896 Marantz CD-6000 16.9344 Marantz CD-6000 SE 16.9344 Marantz CD-6000 OSE 16.9344 Marantz SA-1 33.8688 Marantz SA-14 33.8688 Meridian 200 11.2896 Meridian 206 16.9344 Meridian 500 11.2896 Meridian 506 11.2896 Meridian 508 Mk1 11.2896 Meridian 602 11.2896 Meridian 800 27 Micro Mega Drive 1 33.8688 Micro Mega Leader 11.2896 Micro Mega Stage 1 33.8688 Micro Mega Stage 2 33.8688 Micro Mega Stage 3 33.8688 Micro Mega Stage 5 11.2896 Micro Mega Stage 6 33.8688 Mission CDM-2 11.2896 Mission Cyrus DAD-3 33.8688 Mission Cyrus DAD-3Q 33.8688 Mission DAC-5 18.432 Mission PCM 7000 11.2896 Musical Fidelity Elektra 16.9344 Myryad MC-100 16.9344 NAD 501 33.8688 NAD 504 33.8688 NAD C-521 16.9344 NAD C-540 16.9344 NAD C-541i 16.9344 NAD 5000 33.8688 NAD 5425 33.8688 NAD S-500 8.467 Naim CD-3 11.2896 Naim CD-3.5 16.9344 Naim CD-5 16.9344 Onix CD-33 11.2896 Naim CDS 11.2896 Naim CDX 16.9344 Naim NA CD-3 16.9344 Onix CD-33 11.2896 Onix CD-33 11.2896 Onkyo DX-704 33.8688 Onkyo DX-7500 16.9344 Onkyo DX-7511 16.9344 Onkyo DX-7911 16.9344 Orelle XTC CDT-1 LE 11.2896 Parasound CDP-1000 16.9344 Philips CD-723 8.4672 Philips CD-850 11.2896 Philips CD-880 11.2896 Philips DVD-963SA 33.8688 Pink Triangle Numeral 33.8688 Pioneer DV-525 13.824 Pioneer DV-533K 27 Pioneer DV-747A 27 Pioneer PD-52 16.9344 Pioneer PD-75 16.9344 Pioneer PD-91 16.9344 Pioneer PD-93 16.9344 Pioneer PD-95 16.9344 Pioneer PD-5700 16.9344 Pioneer PD-6700 16.9344 Pioneer PD-9700 16.9344 Pioneer PDR-04 16.9344 Pioneer PD-S06 16.9344 Pioneer PD-S503 16.9344 Pioneer PD-S504 16.9344 Pioneer PD-S505 16.9344 Pioneer PD-S507 16.9344 Pioneer PD-S605 16.9344 Pioneer PD-S707 16.9344 Pioneer PD-S801 16.9344 Pioneer PD-S901 16.9344 Pioneer PD-S904 16.9344 Proceed PCD-2 11.2896 PS Audio Lambda 11.2896 Quad CD-66 11.2896 Quad CD-67 11.2896 Radford 11.2896 Rega Jupiter 11.2896 Rega Planet 16.9344 Rega Planet 2000 16.9344 Restek Concret 11.2896 Roksan Attesa 16.9344 Roksan Kandy 16.9344 Roksan Transport 16.9344 Rotel RCD-945 AX 16.9344 Rotel RCD-951 16.9344 Rotel RCD-965 BX 11.2896 Rotel RCD-965 LE 11.2896 Rotel RCD-970 BX 11.2896 Rotel RCD-971 16.9344 Rotel RCD-975 11.2896 Rotel RCD-980 11.2896 Rotel RCD-990 11.2896 Rotel RCD-991 16.9344 Rotel RCD-1070 16.9344 Rotel RDD-980 11.2896 Rotel RH-CD10 16.9344 Sanyo CPM-2403 16.9344 Sony CDP-67 16.9344 Sony CDP-222 ESD 16.9344 Sony CDP-228 ESD 16.9344 Sony CDP-337 ESD 16.9344 Sony CDP-338 ESD 16.9344 Sony CDP-497 22.5792 Sony CDP-515 ES 45.1584 Sony CDP-555 ES 16.9344 Sony CDP-557 ES 16.9344 Sony CDP-715/E 45.1584 Sony CDP-761 45.1584 Sony CDP-X7 ESD 16.9344 Sony CDP-X55 ES 45.1584 Sony CDP-X77 ES 45.1584 Sony CDP-X202 E 16.9344 Sony CDP-X222 ES 45.1584 Sony CDP-X229 ES 45.1584 Sony CDP-X303 ES 45.1584 Sony CDP-X505 ES 45.1584 Sony CDP-X555 ES 16.9344 Sony CDP-X7 ES 16.9344 Sony CDP-X707 ES 45.1584 Sony CDP-X777 ES 45.1584 Sony CDP-X779 ES 45.1584 Sony CDP-X5000 45.1584 Sony CDP-XA2ES 45.1584 Sony CDP-XA5 ES 45.1584 Sony CDP-XA7 ES 45.1584 Sony CDP-XA30 ES 45.1584 Sony CDP-XA50 ES 45.1584 Sony CDP-XB920 45.1584 Sony CDP-XB930 45.1584 Sony CDP-XB940 45.1584 Sony CDP-XE900 45.1584 Sony DVP-S735D 27 Sony SCD-1 45.1584 Sony SCD-777ES 45.1584 Sugden CD-98 12 T+A CD-1200R 11.2896 T+A CD-1220R 11.2896 T+A CD-1400AC 11.2896 T+A CD-1500R 16.9344 & 33.8688 Tascam CD-RW4U 11.2896 Teac P500 16.9344 Teac P700 16.9344 Teac VRDS-7 16.9344 Teac VRDS-8 16.9344 Teac VRDS-9 16.9344 Teac VRDS-10 16.9344 Teac VRDS-25X 18.4320 & 16.9344 Teac R-10 (DAT) 11.2896 & 12.288 Teac T1 16.9344 Teac VRDS-T1 16.9344 Technics MASH 33.8688 Technics SL-P1200 16.9344 Technics SL-P2000 33.8688 Technics SL-PS620A 33.8688 Technics SL-PS670A 33.8688 Technics SL-PS840 33.8688 Theta Jade 16.9344 Thule CD-100 11.2896 Thule Spirit 16.9344 Woodside 11.2896 Yamaha CD-5050 16.9344 Yamaha CDX-580 16.9344 Yamaha CDX-590 16.9344 Yamaha CDX-593 16.9344 Yamaha CDX-880 16.9344 Yamaha CDX-890 16.9344 Yamaha CDX-893 16.9344 Yamaha CXD-930 33.8688 Yamaha CDX-1030 33.8688 Yamaha CDX-1120 16.9344 Yamaha CDX-2020 16.9344 YBA Audio Refinement 16.9344
Các bác cho hỏi, có đầu CD dùng 1 DAC, thông dụng là 2 DAC, nhưng có những đầu em thấy dùng 4 DAC. Đầu CD dùng nhiều DAC có hay hơn ít DAC không, và tại sao người ta phải dùng nhiều DAC thế nhỉ? Cảm ơn các bác.
Cái này giống như ô tô ấy bác ạ. Có loại 4 xy lanh, 6, 8, 12 xy lanh. Nhiều xy lanh hơn xe chạy khỏe hơn Tuy nhiên phải thiết kế hợp lý sao cho các xy lanh nó phối hợp nhịp nhàng với nhau nếu không là phản tác dụng. Bác có thể thấy máy ô tô các xy lanh có thể xếp theo kiểu chữ V hoặc xếp thẳng // với nhau. Chip DAC trong đầu CD cũng như vậy, có kiểu thiết kế // có kiểu kéo đẩy. Tuy nhiên chip DAC chỉ quyết định một phần nhỏ chất lượng âm thanh thôi mà còn nhiều thứ khác trong đầu CD cũng quan trọng không kém. Vì vậy không phải cứ đầu nhiều chip DAC là hay hơn đầu ít chíp.
Cảm ơn bác Planets, vẫn nghe bác Lotomo nói về bác. CDP của em không có trong danh sách trên, cứ mạnh dạn add vào LoD DA 404D -> AD1860x2
Cái sony 338ESD của em dùng 2 chip PCM58P nhưng em thấy chip này ít đầu trong danh sách sử dụng, tại sao thế nhỉ hay tại nó không tốt?
Với ý kiến cá nhân thì mình rất thích chip PCM58 với lý do chất giọng của chip này là khá tốt, âm thanh rất có cá tính và đặc trưng. Bass & Tweeter không bị căng mà khá trau chuốt, thanh mảnh. Mid dịu dàng, quyện, mượt và mềm. Đặc biệt hay khi nghe giọng nữ. 338ESD thuộc Series cuối cùng mà Sony sản xuất chạy chíp giải mã kiểu multi-bit !! Bản thân mình nghe X7ESD thuộc nhóm 338 này và rất thích, không thể bỏ được !!
Cảm ơn bác Quạ đã có review! Em cũng thấy thế nhưng không có dám nói vì mình non quá nói k có thuyết phục. Bản thân em mới chơi và mới chỉ dùng qua 3 đời CD nhưng 2 lần là cái 338 này và thấy em nó rất phù hợp với nghe vocal đặc biệt là giọng nữ như bác nhận xét nghe rất truyền cảm, rất tự nhiên! Các bác nào dùng đầu CD có kinh nghiệm về các DAC khác xin cho review luôn để xem bọn em đi sau ai thích chất âm, chất giọng nào lựa chọn cho phù hợp nhỉ!
Em đang khoái chất giọng PCM 54HP đây : treble tơi , mid ... hoành tráng - nam tính (tenor - basson - baritone - đâu ra đấy !) , bass sâu cung bậc rõ ràng - kô ù - ít đuôi ... :lol:
Bác cho em hỏi tí (vì em thiếu hiểu biết) Treble tơi , mid ... hoành tráng - nam tính , bass sâu cung bậc rõ ràng - kô ù - ít đuôi là do Chip giải mã hết hả các bác?? Vậy pre dỏm, amp dỏm, tube dỏm, loa dỏm, dây loa dỏm, dây tín hiệu dỏm thì tiếng nó có đuôi, ù, treble vón cục, mid hẹp và ẻo lả tính không ạ?? Vậy PCM 54HP giải quyết hết chứ??
To VQ_Audio, Mình thấy PCM54HP thường sử dụng trong 1 số đầu CD của Denon & Yamaha với những năm sản xuất cũng khá xa !! Và, qua nghe thử chút chút (ví dụ Denon DCD-1500) hay qua các nguồn thông tin khác nữa cho Yamaha CDX-2000 & Denon DCD-700 cộng với cảm giác cá nhân thì không thấy như vậy. Theo mình các đầu CD đó cho âm thanh/giọng tweeter sắc, mid dầy, khô & thô - xào xạc / (khá đặc trưng cho giọng trung nói chung của Yamaha - thể hiện được hình thức của giọng hát tốt song chưa thể hiện hết chiều sâu) / (nghe jazz khá - nhưng ít tình) & bass căng, đanh. Và các đầu CD đó có thiên hướng đưa trường âm tiến lên phía trước chút chút nên mới nghe thì thấy thích nhưng nghe lâu thì hơi mệt. Đây là cảm tính & nhận định cá nhân mình , có thể ở mỗi người là khác nhau - nhưng dù sao mình vẫn đưa ra để được cùng các bạn khác nữa suy ngẫm, trao đổi. To : hungbeo, Nói như vậy thì cũng hơi quá, các bạn ở đây có lẽ cùng đưa ra nhận định và ý kiến chủ quan của mình dựa trên cơ sở đối chứng !! Ví dụ như so sánh âm thanh của 2 đầu CD trên cùng 1 bộ giàn (có chất lượng tương đối tốt, ổn định) để có được nhận định như vậy. Còn để cho ra âm thanh hay thì cũng còn phụ thuộc vào nhiều yếu tố lắm chứ. Đôi khi chỉ cần đi sai 1 cặp dây AV thì âm thanh cũng đã tối mù & rối tung lên rồi. Vậy nên nói hay hay dở ở đây là cho giọng âm của đầu CD hay DAC trên cơ sở tự nhìn nhận, đánh giá & so sánh với các thiết bị khác thôi mà !!
Ô hay,sao gà chưa gáy mà cái bác Quạ này đã thức là thế nào nhỉ,không hiểu đêm qua có chuyện gì không ?
cho em hỏi đầu cd victor bên ngoài có ghi 20bitK2processing là chip gì dzậy các pác, nó có gì đặc piệt hông
Em bổ sung con CPD Harman Kardon HD970 em đang chơi. -DAC: 1 con Analog Device AD1955 (24bit-192kHz theo datasheet từ AD). -Opamp: 2 con TI OPA2134UA, 2 con AD275GS. -Clock: 24.576MHz Oscillator M3H 54FAD. -DSP: 32-bit Analog Devices Black Fin, đưa con DAC lên 24-bit/384kHz Đánh giá theo cảm nhận của riêng em: Tiết tấu cân bằng, kg nhanh mà cũng không chậm quá. Thể hiện các chi tiết trong bản nhạc rất tốt, nhất là các tiếng rung, tiếng xào xạc. Giàu nhạc tính, nghe ca sĩ hát thấy rất có hồn. Hơn hẳn các CD em đã dùng từ trước tới giờ. Cụ thể là Sony 555ESD, Denon 1650G, Marantz63 MKII, Marantz 67, Marantz 8260, Philips 925, Yamaha CDX-1020, Yamaha 2000, Kenwood 5090, Kenwood 7090. Sau quá trình nâng cấp vô cùng mệt mỏi và tốn kém thì chỉ có phần CDP là em hài lòng và tạm thời dừng ở con CDP này. Em thấy con Azur 840c thiết kế sau này cũng hơi giống giống, nhưng dùng đồ ngon hơn, cụ thể là tới 2 chip AD1955 và có luôn ngõ balance.
Bác phán chính xác ! em thích cái chất thô mộc gai góc ... nguyên sơ đó rồi thỉnh thoảng mang ra gọt giũa trang hoàng chút xíu cho thêm phần ... nịnh tai :lol:
em dang choi denon 1500 thay phe luon,mac du choi qua kha nhieu cd khac nhau rui.bac Qua cho e hoi con L-od DA 006 the nao?
To : pheulong, Lo-D là một cái tên khá ưa thích của QuajGiaf trong các thiết bị Audio của Nhật bản. Hiện tại ở nhà của QJ vẫn còn 02 chú CDP của Lo-D là : DA-800 & DA-1000. QJ chưa nghe DA-006 nhưng đã thấy DA-009 !! Và cho rằng DA-006 cũng khoảng gần DA-009 !! Có lẽ hai đời này của Lo-D có giá thành không cao và vì vậy nên hình thức và ruột gan cũng không phải dạng gồ ghề !! Tuy nhiên phải có lý do gì để QJ sở hữu 02 CDP của Lo-D này chứ !! Và vấn đề của nó là đặc trưng thanh âm mộc mạc, mềm mại, chậm rãi, có tình (mộc nhưng khô như Kyocera hay Yamaha). Chất âm của Lo-D khá hiền lành, chân thật !! Bạn không thể yêu cầu tính chi tiết cao cho 1 chiếc CDP đời cổ như vậy. Với giá cả (mình ước tính ho 1 chú DA-006 hay 009 vào khoảng 400 - 600 nghìn cho 1 chú với mắt mũi ngon sẽ là 1 lựa chọn khá thú vị !!
Em vừa lượm con CDP TEAC 1850 giá rẻ mở ra thấy linh kiện toàn loại thường. Bo mạch cực đơn giản dùng DAC PCM 1710 1bit. Không biết em DAC này như thế nào ạ? Chỉ vì em thấy nó mới quá nên mua về mod nhưng cũng chưa biết phải mod như thế nào cả, híc
Các bác cho em hỏi con Sansui anpha 707 với. Em thấy mạch con này làm khá kỹ, tụ Elna và Wima đỏ lại có thêm cổng ra Balance. Con này tiếng thế nào các bác?
