A bookshelf loudspeaker (or bookshelf speaker) is a compact loudspeaker, generally sold for consumer-grade home audio applications as part of a shelf stereo pair or home theater package, that is compact in size and intended to be placed on a raised surface, e.g. a bookshelf. [edit] History At one time, high quality home loudspeakers were exclusively large and floor-standing, whereas small speakers had an exclusive reputation of low price and low audio quality. However, beginning in the 1960s, some manufacturers began making more expensive, compact high fidelity speakers.[1] Edgar Villchur, who along with partner Henry Kloss founded Acoustic Research, is generally credited with inventing bookshelf speakers.[2] His key innovation was an acoustic suspension design, by which the woofer and other drivers were in separately enclosed chambers that could be made stiff and much smaller than the earlier ported designs.[2] Advent, now defunct, was another early manufacturer.[3] Certain market and technical issues have contributed to the widespread adoption of bookshelf speakers in the 1990s and beyond. Technical improvements and less expensive mass-production technologies have made high-quality bookshelf speakers affordable for most audio enthusiasts. Rapid improvements in amplifiers, digital signal processors and other components has improved the sound quality of low to mid-level home audio systems, which creates a stronger need for adequate speakers. Home theater systems are increasingly popular, and their multi-channel audio requires five or more speakers rather than the two speakers of earlier stereo systems. For cost and practical reasons the most common setup is satellite speakers, typically bookshelf speakers for the side, back, and sometimes the front and center channels, rather than larger speakers for each channel. Finally, most home theater and many musical home audio applications, began in the late 1990s to incorporate separately-enclosed subwoofers to handle deep bass. Human perception of low-frequency sound is relatively non-directional, so a single subwoofer is usually sufficient and may be placed anywhere. This frees up the other speakers to omit the lower end of the frequency spectrum. Without the relatively heavy, bulky, and expensive low bass drivers, the speakers can be made smaller. ................................................................................... Một loa kệ sách (hoặc loa kệ sách) là một loa nhỏ gọn , thường được bán cho người tiêu dùng cấp âm thanh nhà các ứng dụng như là một phần của một âm thanh stereo hạn sử dụng cặp hoặc rạp hát gia đình trọn gói, đó là kích thước nhỏ gọn và dự định sẽ được đặt trên bề mặt cao, ví dụ như một kệ sách . [ sửa ] Lịch sử Tại một thời gian, chất lượng cao loa phóng thanh nhà độc quyền lớn và sàn đứng, trong khi loa nhỏ đã có một danh tiếng độc quyền của các mức giá thấp và chất lượng âm thanh thấp. Tuy nhiên, bắt đầu vào những năm 1960, một số nhà sản xuất bắt đầu đắt hơn, nhỏ gọn, độ trung thực cao loa. [1] Edgar Villchur, cùng với đối tác Henry Kloss thành lập nghiên cứu Acoustic , thường được ghi với loa kệ sách phát minh ra. [2] sự đổi mới quan trọng của ông là thiết kế một hệ thống treo âm thanh mà loa trầm và trình điều khiển khác trong các phòng riêng biệt kèm theo có thể được thực hiện cứng và nhỏ hơn nhiều so với thiết kế trước đó được chuyển. [2] Mùa Vọng, bây giờ không còn tồn tại, là một nhà sản xuất sớm. [3] Một số thị trường và các vấn đề kỹ thuật đã góp phần vào việc chấp nhận rộng rãi của loa kệ sách trong những năm 1990 và xa hơn nữa. Cải tiến kỹ thuật và công nghệ sản xuất hàng loạt ít tốn kém đã làm cho loa kệ sách chất lượng cao giá cả phải chăng cho những người đam mê âm thanh nhất. Cải tiến nhanh chóng trong các bộ khuếch đại , bộ xử lý tín hiệu kỹ thuật số và các thành phần khác đã được cải thiện chất lượng âm thanh thấp giữa cấp hệ thống âm thanh gia đình, tạo ra một nhu cầu mạnh mẽ hơn cho các loa đầy đủ. Trang chủ nhà hát hệ thống đang ngày càng phổ biến, và đa kênh âm thanh của họ đòi hỏi 5 hoặc nhiều loa chứ không phải là hai loa của hệ thống âm thanh nổi trước đó . Đối với các lý do về chi phí và thực tế thiết lập phổ biến nhất là các loa vệ tinh, thông thường loa kệ sách bên cạnh, trở lại, và đôi khi mặt trước và kênh trung tâm , chứ không phải là loa lớn hơn cho mỗi kênh. Cuối cùng, hầu hết các rạp hát và các ứng dụng âm nhạc nhiều âm thanh nhà, bắt đầu vào cuối những năm 1990 để kết hợp loa siêu trầm riêng, kèm theo để xử lý âm bass sâu . Con người nhận thức của âm thanh tần số thấp là tương đối không định hướng, do đó, một loa siêu trầm duy nhất thường là đủ và có thể được đặt bất cứ nơi nào. Điều này giải phóng các loa khác để bỏ qua phần cuối của phổ tần số thấp hơn . Nếu không có âm bass thấp trình điều khiển tương đối nặng, cồng kềnh và đắt tiền , các loa có thể được làm nhỏ hơn.
Theo em thì người ta quen gọi loa nhỏ nhỏ là Bookself (loa đặt trên giá sách) thôi chứ thực ra chẳng phải vậy, loa mà đặt trên giá sách thì hay làm sao được, loa nhỏ người ta làm chân cẳng nặng mấy chục kg đặt cách xa tường cả mét mà chẳng ăn thua, đặt trên giá sách thì phí cả loa ra. Chung quy là nhà sản xuất làm loa nhỏ lại để đỡ tốn diện tích, quan trọng là giải quyết được vấn đề bày trí nội thất, giá thành sẽ giảm đi so với loa cột cùng loại.
Kể cả em này cũng liệt vào hàng "búc seo" đó ah http://audio-database.com/JBL/speaker/4344-e.html Theo em hiểu Bookshelf là loa phải kê trên kệ "kệ sách" hoặc "giá", còn cái mà anh em mình hay gọi thành luật bất thành văn chỉ những loa nhỏ gọn, kê trên kệ
Em cũng biết Bookself là loa đặt trên giá sách! Nhưng cặp loa của em thì nó cứ đòi đứng trên chân loa sắt thì tiếng bass nó mới đỡ lùng bùng mới đau chứ!
book là sách shelf là kệ bookshelf là kệ sách loa bookshelf là chỉ những loa nhỏ có thể để được ở kệ sách. Tuy nhiên vẫn có 1 số em khá to cũng được liệt vào loại bookshelf như em JBL khổng lồ mà bác trên vừa đưa.
Loa bookself thực sự nó để trên kệ sách thật đấy. Xem mấy catalogue loa bookself nó để ngay trên kệ sách...
Thì bác cứ hiểu là loa ngắn so với loa cột, và ko phải là loa tranh, loa vi tính chứ cứ dịch từ làm gì. Tiếng Pháp thì là loa bibliotheque. Bibliotheque có nghia là giá sách, thư viện .
Ko nhảm đâu bác. Tùy vào cách hiểu thôi. Theo em hiểu thì loa BS là loại loa có thể đặt ở bất kì vị trí nào. :lol:
Loa nào chả thế cứ gì BS, đặt đâu cũng được, có chăng là nghe không hay thôi. Bác BWM thử quay mặt loa BS vào tường, nằm xuống đất hay đặt lên nóc tủ nghe xem thế nào
book là sách , shelf là ngăn sách ghép ngược theo tiếng anh là : ngăn sách đặt vào cuốn sách bác à , hoặc là cuốn sách đặt vào ngăn sách...hihi
Thực tế thì để đâu cũng nghe thấy am thanh, tuy nhiên em thấy nếu loa đặt ngang tầm tai & được ngồi giữa 2 loa nghe thì cảm nhận được hết vẻ đẹp của âm thanh
Ơ... book là sách, shelf là cái giá... bookshelf là giá sách. Loa để trên giá sách nghe thế nào được nhỉ :mrgreen:
cái topic này đúng là nhảm nhí , cái này bác chủ phải tự tìm hiểu chứ , thông tin trên này thiếu ghì ,cái ghì quá khó mới phải lập topic chứ , bác này post chắc để câu bài đây
Em là lính mới tò te xin kính chào các bác! Em mới gia nhập diễn đàn ta ngày hôm nay nên không được lập thớt xin tư vấn, em mượn nhà bác này xin được hỏi ý kiến các bạn ạ. Nhà em hiện mới có đôi loa Infinity alpha 50, âm li Harman Kadon AVR 2550, em muốn mua thêm cặp bookshelf, 1 loa trung tâm, 1 loa sub thì mua loại gì cho phù hợp ạ? Em cảm ơn các bác rất nhiều!
