Các bác đã thử cái DAC kit này chưa? không biết chất thế nào, 24bit/96kHz, em rất muốn chạy Dual hoặc nhiều con cho nó giống mấy em DAC đỉnh cao :lol: : Dual DAC AD1955+AD1896 + HDAM x 3 pairs (Balance / Analog L&R output) with HDAM DAC KIT DIY 1. DAC AD1955 2.0 with HDAM x 3 pairs analog output A. Dual AD1955 DAC’s chip 24BIT / 96KHz Audio Decoder with balanced and analog L&R output B. Optimum Performance for Differential Current Output 1. AD1955 is the highest Bit Stream and External Digital Filter Interface chip has Stereo Audio DAC system. 2. AD1955 has a advantages of high-dynamic, with an excellent sampling 1 bit linearity and low distortion rate performance of both the strengths of an integrated, complementary roles to achieve a new generation of high-end audio signal processing DAC. C. Circuit structure: 1. Input : SPDIF ( Coaxial ) 2. Output : balanced and analog L & R 3. Digital signal demodulation receiver buffer 26/32 + DIR9001 digital receiver 4. AD1896A handles the up-sampling rate 256fs, 512fs, and 768fs with 16 bits, 18 bits, 20 bits and 24 bits switchable 5. Dual AD1955 chips handle the L & R channel separately 6. 3 pairs of HDAM (Hyper Dynamic Amplifier Module) for output analog stage 7. Power stage : Two stage regulation for the digital section Two group of regulation for the L & R analog section separately 8. High grade of components are used, - Toshiba transistors, JFET for regulation section - Dale resistors - Fast recovery with low resistance diode and ELNA audio capacitors for power regulation - high grade capacitor for de-coupling and filtering D. Power Supply: 0-9V*2 / 1.0A & 18V-0-18V*2 / 0.8A E. PCB size: 295mm x 180mm x 2mm thinkness double side with gold plated
Đang bán ở đây: http://cgi.ebay.com/Dual-DAC-AD1955-AD1 ... 148wt_1296 Thấy linh kiện cũng tương đối, định mua về mần thử mà thấy xuất xứ Tung Của không biết chất âm ra sao. Đang thèm 1 dự án dual DAC với chip support 24/192 mà chưa thấy :lol:
Món này có hay hơn được mấy con AV Receiver hàng 2nd đem ra làm DAC/Pre không các bác? Cũng là SS, cũng 192khz over sampling. Khác gì nhau đâu?
Hihi, đúng thế ah, nếu em mua sẽ làm phương án tube output trường hợp em ấy hát bét quá, nhưng trước tiên phải cho nó nguyên bản để xem chất âm nó ra sao. Em sẽ so sánh với cái DAC hiện có, nếu bằng hoặc hơn thì e để nguyên xơi nhạc hi-res 24/192. Em cũng tù mù chất âm của em này nên nghe ngóng thiên hạ xem sao :lol: Lướt 1 vòng thấy DAC gấu xài AD1955 dual hay 8 con khá nhiều và cũng khá đắt đỏ.
search google thì em thấy có bài này khá hay liên quan tới HDAM http://lampizator.eu/LAMPIZATOR/FETISHI ... zator.html
