Nhân dịp năm mới chúc các Bác Audiophile mới hay cũ đều an khang thịnh vượng, phát tài phát lộc, kiếm được đồ chơi ưng ý. Sau hơn 1 năm gắn bó với Rogue KT 88 và B&W CDM 7NT, em quyết định chuyện ngược lại Solid state, em mới thừa hưởng lại 1 cặp Aerial Acoustic 7B, bây giờ kiếm amplifier, có bác nào đã hoặc từng chơi qua cặp này cho em xin vài ý kiến. Em đang dự tính kiếm Mcintosh MC7270, MA6900, MC Levinson 23 hoặc 27, Krell KVA 400xi. Cám ơn các Bác nhiều... Chúc các Bác vui vẻ...
The Aerial Model 7B is a high-performance 3-way column speaker designed for the discriminating listener. It performs well in either high quality music or theater systems. For critical music listeners it provides accurate tonal balance, precise imaging, tight bass, and excellent transparency. For home theater use, it also provides high power handling and wide dynamic range. The Model 7B's compact size, narrow width, and extensive internal bracing reduce cabinet coloration to mini-monitor levels. Three 2" thick walls, tight tolerances, and several constrained-layer damping blocks further reduce cabinet coloration. In addition the midrange driver is mounted in a separate wool-filled chamber. The Model 7B continues the design philosophy of other Aerial speakers. Its twin long-throw woofers were developed specially for the 7B. They employ large vented magnets, 40 mm diameter coils,and cast frames. Bass is quick, dynamic, and deep. The critical midrange is handled by an unshielded version of the highly acclaimed Model CC3 midrange driver. Midrange is well resolved and natural. The tweeter is Aerial's exclusive, highly refined 10T tweeter. It provides detailed, transparent, extended highs without acoustic signature. The bi-wirable networks are built on two separate glass epoxy circuit boards using precision components and high quality wiring. All cabinets are carefully produced in mirror-imaged pairs using the finest veneers finished to a very high standard. In addition the veneers are book-matched for symmetry on each side. The finish quality is exceptionally high. The optional floor stand is recommended for tighter bass on wood floors as well as for increased stability. SPECIFICATIONS Frequency Response: 35 Hz to 22 kHz ± 2 dB, -6 dB at 30 Hz Sensitivity: 86 dB at 2.83 Vrms and 1.0 meter on axis Impedance : 6 Ω nominal, 4 Ω minimum, low reactance Power Requirements: 50 to 350 watts (8 Ω rating) recommended Woofers: Two 7.1" (180 mm) cast magnesium alloy frame drivers Damped bilaminate composite cones Large vented magnet structures with long-stroke coils Midrange 5" (125 mm) cast magnesium alloy frame driver Damped bilaminate composite cone Vented magnet structure with linear stroke coil Tweeter 1.0" (25 mm) precision titanium dome Large magnet structure with deep rear chamber Flared pole vent and 5 surrounding vents Crossover 400 Hz and 2.7 kHz at 24 dB per octave Independent filter assemblies on glass-epoxy PCBs High-purity copper wiring and silver solder Premium passive components Cabinet Minimum resonance 1" and 2" MDF walls Extensive internal bracing. Tongue and groove joints Mirror-imaged matched pairs in architectural veneers Connections Four gold-plated binding posts with copper jumpers Bi-wire and bi-amp capable Optional Bases Rigid 14 lb sand-filled steel bases with spikes Dimensions: HWD 43.0 x 8.5 x 15.5" (1092 x 216 x 394 mm) Weight Each: 95 lbs (43 kg). 120 lbs (55 kg) packed
Em thấy các Audiophile trên thế giới đưa ra nhận xét như sau: Nếu bạn là người yêu nhạc hãy chọn McIntosh. Còn nếu bạn là người yêu âm thanh hãy chọn Mark Levinson, Krell, Pass Lab. Âm thanh McIntosh không quá chính xác mà thiên về nhạc tính còn Mark Levinson, Krell, Pass Lab thì lại thiên về thứ âm thanh chính xác phù hợp để nghe tham chiếu. Tùy vào gu nghe của mỗi người mà có lựa chọn thích hợp bác ạ.
Em lại có cảm giác ngược lại: Mark Levinson cho âm thanh mềm mại và nhiều nhạc tính hơn McIntosh, nhưng về không gian - âm hình và độ động thì McIntosh rất ấn tượng. Cả hai chú này nghe tiếng bass đều rất hay, trung dày, trong trẻo, ấm áp, còn treble thế nào em quên béng mất rồi ;- ) Còn một điểm chung nữa là đắt lòi. Bác Altecta7 có đôi Aerial Acoustic đẹp quá, dòng loa này nổi tiếng lắm dưng ở ta hiếm quá. Chất tiếng nó thế nào hở bác?
Báo cáo các Bác, em vẫn chưa mua được amp để chơi, hiện giờ đang chờ ý kiến các Bác. Cặp Aerial 7B này cũng khá nổi tiếng, được biết đến là đều cả 3 dải, dùng tốt cho cả stereo và Home thearter, khá nặng 43kg/1c. Em đang nghe ngóng xem có cơ hội nào tốt không, Mark Levinson No.23 (200w/c), Mcintosh MC 252(250w/c), Krell KVA 400xi (200w/c), Pass labs 250,...MONG CÁC BÁC CHO EM Ý KIẾN. Cám ơn các Bác nhiều
Ghép review của Stereophile cho cặp loa này là Bryston 7B-ST SS amp, và ampli đèn là Sonic Frontiers Power 2, link: http://www.stereophile.com/floorloudspe ... ndex3.html Nếu chọn MC 252 thì cũng nên kiếm Pre Mcintosh cho đỡ lăn tăn về phối trở kháng phù hợp. PassLab cũng thế, ghép với Pre Pass. ML No.23 không biết tình trạng ra sao (cổ, cũ ) ? Theo cá nhân nếu phù hợp khả năng, em sẽ ghép với cặp Edge G8+, link: http://cls.audiogon.com/cgi-bin/cls.pl? ... 1206940877 ghép với Pre Edge G1, link: http://cls.audiogon.com/cgi-bin/cls.pl? ... 1207243225
Aerial hiện tại được ghép với 1 cặp Bel Canto eVo2 Gen II, stereo nhưng em đấu bridge thành mono block 400w/chanel, chưa mua được Pre nên em đấu tạm với Marantz PM 94, Dây loa Kimber Kable 8TC đấu bi-wire, Dây tín hiệu Zu Audio, đầu CD Wadia 23, Sony SACD 777ES. Nhận xét: Cảm giác amp hơi quá khỏe so với loa cho nên bass lan tỏa không tụ lại như nghe với subwoofer, tạo cảm giác không có bass, trung và treble rõ ràng, hơi khô lạnh (Có lẽ đặc trưng của dòng Digital Amplifier của Bel canto). Em đang nghiên cứu preamp, đang nhắm Sonic frontiers Line 1 tube pre hoặc dòng Class A của Nenson Pass (Threshold, Pass labs, Forte...) Hiện có thêm cặp Aerial 5B.
