Giúp đỡ về loa cho DENON PMA 6.5l
Discussion in 'Dành cho thành viên mới' started by hoangvu87ht, 22/11/15.
  1. hoangvu87ht
    hoangvu87ht New Member
    Nhờ mọi người tu vấn giúp em loa cho âm ly denon pma 6.5l
    Em thích nghe nhạc vàng.
    Output power 40W+40W (6 ohms, 1kHz)
    Practical use maximum except take-off (EIAJ) 55W+55W (6ohms)
    Speaker load impedance 6ohm-16ohm
    <Preamplifier part>
    Input sensitivity/impedance Phono MM: 2.5mV/47kohm
    Line: 150mV/47kohm
    Output power Rec out:150mV
    RIAA deflection 20Hz-20kHz±0.5dB
    <Synthesis>
    Signal to noise ratio Phono MM: 80dB (at the time of a 5mV input)
    Line:95dB(Source direct on)
    Power supply voltage AC100V, 50Hz/60Hz
