Hỏi về cách đấu loa Bi-amp của Receiver Denon AVC
Discussion in 'Dành cho thành viên mới' started by tranhung, 20/12/06.
  1. tranhung
    tranhung Advanced Member
    Sài Gòn
    Chào mọi người
    Xin cho hỏi về cách đấu dây Bi – Amp
    Mình đang dùng Receiver Denon AVC A1. Mình muốn nối Bi-amp cho loa Font nhưng chưa biết cách nối.
    Theo như Hình hướng dẫn dưới đây thì mình không biết “Hi“ là kênh A hay kênh B trên Receiver
    Mình thấy ngõ cắm loa Center ở Receiver có 4 cọc, vậy mình nối ra được 2 Center hay là cũng chỉ nối kiểu Bi-amp mà thôi ?
    5 Loa xem phim của mình đều nối được theo Bi-amp ( vì mình thấy có 4 cọc loa ) và 5 loa đều giống nhau.
    Xin cảm ơn mọi người
  2. haichutchit
    haichutchit Approved Member
    Saigon
    Có cách đấu Bi-Apm cho Denon AVR-3805
    Bạn thử tham khảo xem nhé
    Bi-amping the Denon AVR-3805 for 240 Watts for the Front Channels
    What? A $1200 receiver that gives you 2 x 120 watts for each front channel to the main speakers in a bi-amped configuration while still allowing 5.1 surround? Absolutely. Read on... Using unused "Surround Back" amps to bi-amp the main speakers was mentioned by Gene DellaSala in his review of the Denon AVR-5803 receiver and the same procedure holds true for the AVR-3805. Why let those unused surround back amplifiers go to waste if you are not utilizing either them or Zone 2 speakers? Here is the procedure to successfully bi-amp the Denon AVR-3805 and deliver additional power to your main speakers:
    Before telling you HOW to do it, there are some caveats about doing this specifically with the AVR-3805. First, If you set it up to bi-amp, please expect to do your SETUP manually rather than using the mic for the AUTO SETUP procedure. Next, we have seen some complaints of noise (hiss) from some people who have done the bi-amping with specifically the AVR-3805. Accordingly, Denon is not "officially" endorsing this practice on this specific model.
    That said, we encourage you to TRY the bi-amp setup and judge for yourself if you hear any objectionable increase in noise that negates the many advantages of bi-amping in general. The procedure below specifically connects the speakers LOW frequency to the Zone 3, while having the HIGH frequency connected to the FRONT speaker terminals. This may help to reduce any extra noise from the use of multi-zone from getting to the tweeters. The reason for choosing Zone 3 rather than Zone 2 is simply to still permit the use of a volume controlled zone 2 for genuine multi zone use, so long as an additional stereo amplifier is used. Additionally, because of details on the remote, it makes it slightly more difficult to accidentally alter some of the settings.
    1) Connect a SHORT stereo cable pair from [PRE OUT LEFT & RIGHT] and run it into the Red and White jacks labeled [VDP].
    2) DISCONNECT the SHORTING STRAPS from your bi-ampable speaker's terminals! This is whatever device the speaker manufacture has used to connect the two black terminals to each other, and the similar one used for the two red terminals. Failure to do this can quickly damage the amplifiers!
    3) Connect the HIGH FREQUENCY terminals of the speakers to the receiver's FRONT LEFT and RIGHT speaker terminals.
    4) Connect the speakers' LOW FREQUENCY terminals to the receiver's speaker terminals marked: [SURR BACK / MULTI ZONE]. These are to the far right, viewed from the back.
    5) Via step # 5.1 in OPTION SETUP, set P.AMP ASSIGN to ZONE 3. See page 43 of the owner's manual for detail.
    6) Via REMOTE (RC-969) press button that says [ZONE 2] until it changes to read [ZONE 3] with the bright bar above the ZONE 3 indication.
    7) Press [SOURCE ON] to turn on the ZONE 3 amplifiers.
    Select [VDP] as the SOURCE for Zone 3. This is done by pressing the letters [VDP] which are directly under the CD indication, NOT the VDP which is directly under the MD indication. Note that this step is what causes the "ZONE 3" to always play the VDP input, which is in turn, the signal from the Left and Right FRONT PRE OUTS of the main zone. Voila!
    9) With the remote still in the ZONE 3 mode, press the VOL ^ up button while watching the front panel of the AVR-3805. Bring it up to read 00 as a starting point. Later in the process you will come back to this and adjust to your own taste for spectral balance of the front speakers. (More, later).
    10) Next, put the remote back to the AMP mode, so the word AMP is underlined by the bright bar. You can now do any other setup steps you need and use the receiver as you normally would.
    Anything you select to listen to will have its output for the front L&R go directly to the speaker terminals marked Front L&R and ALSO go out the L&R PRE OUT jacks which ultimately get to the SURR BACK / MULTI speaker terminals. Therefore, the CONTENT of the FRONT L&R speaker terminals is identical to the content of the SURR BACK / MULTI speaker terminals.
    Once setup this way, you never touch the ZONE 3 again since the main zone is in control of everything.....one exception...
    The ZONE 3 volume will adjust ONLY the level to the LOW FREQUENCY part of the speaker, whereas the MASTER VOLUME (main zone) will control ALL channels INCLUDING the LOW FREQUENCY part of the speaker. Therefore the ZONE 3 Volume, step number 9 in the list above, actually adjusts the RATIO of Lows to Highs in the speaker. If you want a bit heaver sound, bring ZONE 3 volume up a bit. If you want a bit brighter sound, take ZONE 3 volume down a bit. Some "Audiophiles" worry they won't know what setting is "Correct", but "REAL" audiophiles trust their own ears above all! One of the very powerful ADVANTAGES of the Bi-Amp setup this way is your ability to control the spectral balance of the speaker with this specific adjustment.
    Notes: It would have been nice if the channel trim for the Zone 2/3 level control had +/-0.5dB precision as did all of the other channel trims of this receiver. However, we found +2dB adjustment to provide near unity gain with the main amplifiers. During this configuration I also wondered what would happen if the CD input were accidentally selected by mistake, causing the main channel preamp outputs to be suddenly routed to themselves (feedback). Not to worry, Zone 2/3 does not allow the same source to be sent simultaneously to the main speaker outputs so feedback is impossible - at least with regards to this configuration method.
    Be sure to remove the jumpers on the back of the main speakers and then connect a set of wires from the "Front" channels of the receiver to the highs section of each of your front speakers and a set of wires from the "Multi Zone 2" channels of the receiver to the lows of your front speakers. Voila! You now paid only $1200 for a receiver that gives you 3dB of additional headroom in the form of 2 x 120watts per channel to your main speakers where you need it the most.
  3. wave_alfa
    wave_alfa Advanced Member
    Nếu bác có user manual bằng tiếng Anh thì bác hãy đọc kỹ trang 98 và trang 100 thì bác sẽ nối được biamp (hay b-wired) cho cả 5 loa (FL, FR, C, SL, SR), còn Surround Back thì không nối được bi-wired, bác nối thế này:
    - Speaker systems ở đằng sau AVC-A1 bác sẽ thấy có 5 cặp bên trái và 5 cặp bên phải để nối đến loa được đánh dấu từ 1 đến 5.
    - Front: Bác đấu cặp 1 đến HIGH của loa Front và cặp số 4 đến LOW của loa Front theo đúng trái (L) và phải (R)
    - Center: Bác đấu cặp số 2 bên trái (L) đến HIGH của loa Center và cặp số 2 bên phải (R) đến LOW của loa Center.
    - Surround: Bác đấu cặp 3 đến HIGH của loa Surround và cặp số 5 đến LOW của loa Surround theo đúng trái (L) và phải (R).
    Chú ý: bác PHẢI nhớ tháo cái miếng bằng kim loại nối giữa LOW và HIGH trên loa của bác ra trước khi đấu dây nhợ vào nhé.
    Như vậy là bác đấu xong bi-wired rồi đấy.
    Chúc bác đấu thành công.
  4. tranhung
    Sài Gòn
    Xin cảm ơn 2 anh
    Tối nay về em sẽ nối thử như hướng dẫn.
    Một lần nữa xin cảm ơn
    Trần Hùng
  5. tranhung
    Sài Gòn
    Dạ, mấy hôm nay em phải đi xa nên chưa làm được. Tối nay em sẽ thử xem sao.
    To wave_alfa: Dạ em không có quyển hưỡng dẫn của nó anh ạ. Nếu anh có anh có thể Scan mấy trang hưỡng dẫn cho em được không ?
    Cảm ơn nhiều ạ
  6. wave_alfa
  7. tranhung
    Sài Gòn
    Chào anh wave_alfa
    Chiều qua em đã nối như anh hướng dẫn. Nhưng khi nghe thử thì thực sự em cũng không biết là nó có hay hơn không nữa, vì xem phim âm thanh nó cứ ầm ầm, nhưng em vẫn nối dây như cách anh hướng dẫn.
    Em đã vào địa chỉ website anh cho nhưng không có model AVC A1 anh à, nếu anh có manual của AVC A1 anh mail cho em với nhé: địa chỉ mail của em: tranhung_h@yahoo.com
    Cảm ơn anh rất nhiều
  8. wave_alfa
    Bi-wired chủ yếu là nối cho Front để nghe nhạc. Chứ xem phim nó cứ đùng đùng, chéo chéo thì không thể nhận ra và theo cá nhân em là không cần thiết nối bi-wired.
    Em đã gửi mail cho bác. Do file lớn (15MB), nên em split ra thành 2 files gửi 2 lần.
  9. jmlab_926
    jmlab_926 Advanced Member
    như này đâu phải là 2 amp bác nhỉ
    chỉ là bi-wire thôi hay sao ý , em tọc mạch tý
  10. haichutchit
    Saigon
    Bạn Hùng ơi,
    Ban đấu như vậy là Bi-wire thôi
    Nhưng mục đích của bạn la đấu Bi- Amp mà
    Nếu bạn chụp được cái hình phía sau của AVC - A1 để mình xem có thể giúp được gì cho bạn
  11. tranhung
    Sài Gòn
    To: wave_alfa: Cảm ơn anh nhiều, Em đã nhận được E-mail của anh gửi, nhưng em chỉ thấy mới có 1 e-mail có file manual thôi, còn files thứ 2 thì không thấy, chắc mấy hôm nay mạng tại VN bị trục trặc nên em chưa nhận được. Xin cảm ơn anh
    To: haichutchit: Hôm chủ nhật vừa rồi em đã dùng thử máy điện thoại để chụp nhưng không được rõ anh à. ( tự em dùng con O2 Atom Exec chỉ có 2MB nên hình tệ lắm ) Để hôm nào em mượn máy chụp về chụp cho rõ. Cảm ơn anh nhiều
    Cả
  12. khanh_zui
    khanh_zui Approved Member
    HIZ HIZ em đào mộ lên chút. Bác nào setup rồi giúp em với. Em mới tập tành tậu em Denon 3805 mà không thể nào setup được vì người ta đưa em nhầm cái DENON RC-971 mà chả hiểu sao cái đèn nó mờ tịt à nhìn mờ hết cả mắt hzhz. Có làm cách nào đấu BI_AMP mà không dùng điều khiển không các bác nhỉ :((
  13. khanh_zui
    hzhz có bác nào giúp em với. Em sài Denon 3805 làm giống như bạn nước ngoài này nói rồi mà không được hhzzhzhz
    Thực ra mình đấu BI- AMP là dùng 2 cọc Sur BACK/Mutil zone coi như là phát nhạc cho đôi loa khác để ở phòng khác => cho vào 2 loa FON thì nó vẫn phải phát chứ nhỉ sao em không cho nó chạy được nhỉ. Mặc dù lúc đầu cho chạy 7 stereo thì nó vẫn phát bình thường chứ :((
