Marantz Hi-End Audiophile Test Demo (320k)
Discussion in 'Âm nhạc' started by decon, 17/10/06.
  1. decon
    decon Advanced Member
    [shadow=red]Marantz Hi-End Audiophile Test Demo [/shadow]
    Đây là đĩa SACD, file gốc lớn quá (hơn 702 Mb) nên em convert ra MP3 chất lượng cao cho AE nghe tạm, AE nào có nhu cầu thì em upload file gốc luôn. Các bài hát trong 1 file duy nhất :
    (01) Let's go get stoned
    (02) Traditional
    (03) Body and soul
    (04) Traditional
    (05) Pop enrelu
    (06) Tango - jalousie
    (07) On the air
    (08) Straat
    (09) Royal jubilee
    (10) Milonga del angels
    (11) Traditional
    (12) Water music gigue 1 en 2
    (13) A birthday hansel
    (14) Improvisation
    (15) Improvisation
    (16) 2nd string quartet opus 17 part 2 alegro molto Capriccioso
    Link :
    http://tryor.com/files/10435/Marantz_-_ ... Audio.html
    [shadow=red]Đánh giá :[/shadow]
    From the Cutting Room:
    This time Fritz came up with a total analo9ue ''wording and this meant rigging up the faithful Studier A80 disc-mastering recorder. After listening to the recording I decided it was obviously a good recording but regarding the age of the machine and speed used (7.5 inch/sec) it needed true mastering to get the best out of it A delicate touch of equalizing and a teeny weenie bit of compression did the job. I could feel musicality and emotion instead of a cold and analytical sound and this was essential to turn this into a great album. As far as I can tell it all worked out great.
    Maarten de Boer. Mastering engineer
    The original recording is all analogue semi live to 2 track direct. Only Schoeps microphones were set up for this session. Recorded with Siltech cables.
      10 KB
  2. decon
  3. lamdoi
    lamdoi Advanced Member
    Bay Area
    Hay quá, rất cám ơn bác decon đã tạo điều kiện cho em được thưởng thức.
  4. phamhuynh
    phamhuynh Advanced Member
    BR-VT
    Bác đã Upload chua mà sao em tìm trong cả 2 link không thấy đâu vậy Bác ?
    Hic ! Dốt nó cũng khổ thế đấy Bác ạ !
  5. phuong540000
    phuong540000 Advanced Member
    hà nội
    he...he....mấy bác đừng có tin nha.cụ này là giáo viên tin học đó
  6. phamhuynh
    BR-VT
    Hic ! Có "ai đánh" Bác đâu mà "......" vậy !
  7. HBTrung
    HBTrung Advanced Member
    Sài Gòn - Vũng Tàu
    Em cũng không download được Bác ạ, hay Bác cho xin link khác hoặc đưa lên vnav.net@gmail.com cho anh em down
  8. HST
    HST Advanced Member
    Tân Bình - HCMC
    cái link nầy works mà bác, các bác nhớ cuộn xuống phía dưới của trang sẽ thấy chữ: "Please wait 30 seconds", nhập code 4 con số vào, bấm "download the file".
    HST
  9. quyda
    quyda Advanced Member
    Sao bác decon kô dùng EAC rip ra file wav rồi nén bằng chuẩn lossless, như thế mỗi anh em đều có 1 bản copy hệt như của bác vậy;-)
  10. HBTrung
    Sài Gòn - Vũng Tàu
    Em cũng biết vậy ạ, nhưng nhập code vào toàn bị báo nhập sai code???
  11. decon
    File gốc của nó là wav dó bác, nhung lớn quá 702 mb em không biết upload lên đâu?
  12. mtbc
    mtbc Advanced Member
    Q3, Saigon
    ACE cứ dùng eMule search đúng cụm chữ trên thì ra ngay thôi. Chọn cái file.zip thì số nguồn available nhiều nhất. mtbc chỉ cần download 1 đêm là xong, mặc dù credit rank trong eMule thấp xỉn :)
  13. musicalbum4u
    musicalbum4u Approved Member
  14. gialong76
    gialong76 Advanced Member
    Bác ơi, đĩa này mua ở đâu thế? Tôi đến Audiophile nhưng không có, Bác chỉ với.
  15. Kiencon
    Kiencon Advanced Member
    301C Điện Biên Phủ nếu Bác ở SG.
