Bác nào chơi qua dòng này cho em chút thông tin về chất âm, thấy giá rẻ có 1,4 triệu nên em định bê về nghe nhưng không có đồ thử nên nhờ các bác tư vấn. Cảm ơn các bác!
This review is for the 760SE which cost £150 new in the early 90's. These Mission speakers will only be available second hand now, but would be worth a purchase if the price is right. I listened to the standard 760 in the shop after reading a five star magazine review & was so disappointed, lack of bass or treble - they just sounded boring!! The guy at the Hifi shop them suggested I listen to the SE variant & I was amazed at the difference. The most noticeable difference was the bass being far fuller & richer going incredibly deep for the size of the tiny enclosures. The sound as a whole was very impressive for the price so I bought them, along with some expensive 'Sonic-link' AST bi-wire speaker cable & took them home. At the time I had a Yamaha Amp, CD player, Tuner & later a Project turntable & Apollo speaker stands. I was really pleased with the sound & loved listening to any music through them - especially rock & acoustic music. They really did everything they should very well & for £150 they where an absolute steal!! I eventually upgraded to a pair of fantastic Mission 751's which took my Hifi in general to a totally different league & made the 760SE's sound a bit shut-in in comparison, but the 751's did cost over twice price so the side-by-side test was unfair to say the least!! I would recommend the Mission 760iSE to anyone who is setting up or venturing into hifi separates & can find a pair reasonably priced - you will not be disappointed. Highly recommended!! Bác đọc tạm goolge này xem có giúp gì đc không
cảm ơn bác! Hôm trưa nay em đã bê về đánh. Kết quả không tồi chút nào. Em đánh bằng: CDP arcam alpha 7 + Cyrus 2 = âm thanh khá tốt và trong tầm giá đó thì quá tốt.
Bác Nam ơi, cái của em là PSX-R bác ạ, em không nghỉ là lắp đc với Cyrus 2 đâu, chỉ lắp đc với Cyrus 3 trở lên thì phải.
Vâng, em tra Cyrus thì không thấy nhắc đến. Con số 2 lắp PSX từ 50W mà nâng lên được 70W? Em thấy đằng sau vỏ máy có cái cổng 3 chân gần giống công Balace bác ạ, ko hiểu có vừa không. Bác cho em vài dòng so sánh khi không lắp và khi lắp PSX a, thank bác!
Trong site của Cyrus có nói bác ạ, không dùng PSX-R cho Cyrus II được vì cấu tạo mạch nó khác. PSX giờ có lẽ cũng khó mua đấy. Còn em chưa thử so sánh có PSX-R và không có PSX-R. Với cái loa của em chắc cũng không khác nhiều, vì loa em bé dễ đánh không ý mà, khi nào gặp loa khó hơn mới rõ khác biệt, em nghĩ vậy.
Em không rõ tiếng Anh lắm nên đọc chỉ hiểu lơ mơ thôi. Trước em cũng tìm cục PSX này nhiều lần nhưng không có bán, qua tìm hiểu thì em được biết thực ra đây chỉ là bộ nguồn rời phức tạp bác ạ. Không biết đời cao hơn thì thế nào, dòng cổ của em thì phải nhổ 2 cầu chì ra để ngắt nguồn từ biến thế máy vào phần công suất và nối từ dòng từ PSX vào, còn phần tiền khuyến đại dùng nguồn máy. Lắp theo kiểu này sẽ nâng cao chất lượng, công lực của âm thanh lên. Đây là cách mà nhiều hãng Anh hay dùng, từ CDP đến Amp đều thế cả. Ví dụ như CDP của Arcam cũng có khe để nâng cấp ví dụ như 7 lên 7SE Trên VNAV có bác chơi Cyrus đời mới (6vs thì phải) đấy bác, nó chia ra 2 cổng low và Hi để nối bi-wire.
Cyrus 6 có lắp đc PSX-R đâu bác. Cái Cyrus III thì không rõ là cái PSX đảm nhiệm pre hay pow, còn Cyrus 8 thì nó đảm nhiệm pre bác ạ. Cyrus 2 của bác trông khác, còn con III của em thì không khác gì các con Cyrus đời sau về hình dáng. Lúc mua thì thằng bán nó đã cấu hình dùng chung rồi, nên em cũng không rõ về cách cấu hình dùng PSX-R. Lúc nào em sẽ thử nghe có và ko có PSX-R. Hiện giờ đang đợi ông bạn rình mua CD arcam rồi nghe 1 thể xem sao. Đã kiểm tra lại thông tin: không thể tháo PSX-R ra được vì máy đã configure để dùng PSX-R. Muốn dùng không có PSX-R thì phải tháo máy ra configure lại lằng nhằng.
Cho e ra nhập thêm thành viên của Cyrus III bác nhé. E mới tậu được 1 em nhưng chưa kịp phối ghép. Có gì em nhờ các bác chỉ giáo giùm nha thân
vừa rồi tháo ra vệ sinh, lắp máy vào thì con Cyrus cỏ của em nó phát sáng vài gây rồi bốc khói. Các bác biết chỗ nào có Cyrus bán chỉ em với, lâu lâu không được nghe lại thèm. Thank bác!
:mrgreen: chất âm của Cyrus thì rất điềm đạm, rõ ràng... giá như tiếng bass nó gọn gàng, sâu một tí nữa thì hay quá :roll:
Tối qua em về lọ mọ chạy rà được mấy bài thì vợ nó quấy đâm ra lại phải để đấy. Nhưng qua 2 track đầu tiên .em thấy ăn điển rùi bác ạ. Nhưng có một vấn đề là khi em tắt nguồn đằng trước sau đó tắt nguồn đằng sau, loa nó kêu cái bụp một cái, em vừa hoảng vừa sót ruột không biết mấy on của các bác có bị như thế không. Hàng này em sem nó không có rơ le đóng như hàng nhật phải ko ạ? Sốt ruột quá mong các bác chỉ giáo
Em thì chưa chơi con số 3, nhưng hình như tắt trước mặt là stanby chứ không phải Power vì thế nó bụp, à mà lúc đó bác có giảm Vol không ạ? Hihihihi... con số 2 em thấy có nhiều ý kiến hơn. Từ dòng số 3 Cyrus thiết kế cho người nước ngoài dùng thì phải vì người Anh bao giờ cũng dùng trái tay so với nhiều nước, như giao thông, rồi cả ô tô tay lái nghịch nữa... Amp thuần của Anh thì vol bao giờ cũng năm ở giữa hoặc bên trái, nút power bao giờ cũng nằm phải. cambrige audio, Arcam cũng vậy... :mrgreen:
Bác không cần tắt đằng sau đâu, chỉ tắt stanby đằng trước thôi. Đúng là khi tắt standby thì nó có tiếng bụp nhỏ ở loa, nhưng ko sao cả đâu. Với bộ của em thì em thấy hay hơn Arcam A80
Con số 2 thì em thấy, tắt công tắc Power thì nó cũng chỉ ngắt từ biến thế vào main chứ không phải ngắt từ đầu nguồn nên biến thế cu lúc nào cũng ngâm trong điện. Dòng mới của bác chắc là ngắt nguồn thật. Tuy nhiên, nguồn xuyến của dòng này thì khỏi phải suy nghĩ, bác có cắm điện cả năm nếu không hoạt động thì sờ tay vào vỏ vẫn mát. Lưu ý, không phải là cảm giác đâu nhé, bác kiếm cái dây nguồn khỏe ở nhiều cửa hàng bán đồ 2nd kèm theo máy thi thoảng cũng có dây nguồn tốt, có vỏ bọc chống nhiễu đấy (nếu mua hàng cho Audio thì càng tốt), rồi ổ cắm tiếp xúc tốt... cái này cũng ảnh hưởng đến tiếng trầm, trung trầm khá rõ.
Cám ơn các bác, Các bác nói thế em yên tâm rất nhiều. E đã nghe qua một số CD nói chung là chất âm đẹp, cân bằng, nghe rất mọng ở dải dải trung và cao. Tuy nhiên tiếng bass hơi nhẹ như bác nhat nam đã nói. Nhưng về tổng thể là tốt.E tả có vẻ nông dân mong các bác thông cảm Bác Toajp có cắm thêm PSX-R nó đảm nhiệm phần gì vậy bác. Chất âm có thay đổi nhiều không ạ? Mua con đó giờ khoảng bao nhiu bác nhỉ. Đã chơi rùi chỉ chết cái tội tham thôi bác ạ? Thân!
Phiền bác nào có Cyrus 2, nếu có thể vui lòng tháo vỏ máy của tra giúp em linh kiện hình dưới xem thông số nó như thế nào thế nào ạ - phần em khoanh tròn, đánh mũi tên (C 73) . Thông cảm vì em chụp tạm bằng điện thoại. Con của em hôm nọ chập bay luôn cả con này. Trăm sự nhờ các bác, mấy hôm nay em không có đồ nghe nên ra vào như người trên mây. Thank!
Em mua nó có sẵn rồi bác ạ, nên em không biết con PSX-R nó có tác dụng nhiều không. Nhưng trên mạng thì họ nói có tác dụng nhiều đấy ạ. Khi có thêm con PSX-R, toàn bộ phần power sẽ do con PSX-R cấp nguồn, nguồn cũ sẽ chỉ dùng cấp cho phần pre. Vì thế nghe thiên hạ nói chất âm sẽ đầy đặn hơn, mạnh mẽ hơn, và công suất cũng tăng lên chút. Em ngại configure lại để so sánh nên không biết cụ thể nó khác nhau thế nào. Giá con đó cũng không rẻ đâu bác ơi, chắc ở trong nước không có bán đâu.
