đúng là pow digital Hybrid nặng 35 pound amp chạy class a 150w hát cả ngày cũng o nóng mà lổ thông hơi rất nhỏ Specifications: Solid state two ch. Hybrid Class A power amplifier with Class D switching output stage. Inputs: 1 RCA and 1 XLR Power output: 150Wpc into 8 ohms, 225Wpc into 4 ohms, 275Wpc into 2 ohms. Voltage gain: 24dB Dimensions: 17" W by 4.5" H by 14" D. Weight: 35 lbs.
bác nao hay tiếng anh xin dịch giùm thk All of a sudden on the fifth day the HCA 2 really came in and I mean really came into its own, in a big way. The soundstage, depth, transparency and the delicate layering in of the instruments were just mesmerizing to say the least. I can't remember being this impressed since the Mark Levinson ML 2 mono blocks came on the scene some 30 years ago and thats an experience still firmly etched in my mind to this day. But here is a new kid on the block so-to-speak that is so very near the signature of pure Class A output amps,without the heat, the weight, the increased power bill and all else that convential Class A amps have. While the HCA 2 cannot compete with the very best of Class A amps, its overall signature is well within 98 percent of the pure Class A counterparts. So close in fact, that I can easily live with this unit for the foreseeable future. Because what it may lack here and there it more than makes up for in so many other areas of overall performance. I have had the PS Audio HCA 2 powered on 24/7 for several weeks now and zero glitches or flaws have been encountered. Truly plug, play and enjoy straight out of the gate.
Cái này tuy chưa thấy qua nhưng nhìn hình dáng và máy có lổ thông hơi bé xíu thì chắc chắn là class D rồi, chỉ có class D mới nhỏ gọn công suất lớn thôi, class AB còn chưa được nhỏ gọn như vậy nữa là, hơn nữa 8 ohms mà 150W là khủng lắm rồi
Đả đưa em về và nghe em hát và em hát cũng rất hay.Tìm trên mạng cũng nhiều người khen,và em nó đúng là class A.Em nó là DIGITAL AMP làm năm 2002 giá là 1695.00$ em mua lại 600.00$ Đồ PS có cái nào nhẹ tiền khg các bác?
Có thể em này của bác nghe nhỏ sẽ là ClassA, nếu vặn to thì nó chuyển sang ClassD. Giống oto động cơ xăng và điện. Mấy em Krell hay PassLab ClassA 150W nó phải to bằng 2 em này.
PS Audio HCA-2 thiết kế đơn giản nhưng đẹp. Rất nhạy cảm với ground loop, cho nên em phải ngắt chân mass dây nguồn ra, không thì ù. Mặt lưng nhìn bộ jack WBT là thấy thích rồi... Bên trong PS Audio HCA-2 là một bộ nguồn linear với biến áp lớn. Bộ tụ khá tốt, và có thể thay bằng tụ xịn hơn nữa như Philips hay Mundorf để cải thiện thêm chất âm. Các tụ nhỏ hơn phía cụm xử lý tín hiệu cũng có thể thay được. Em thấy các bạn Âu Mỹ có làm nên làm theo. Kết quả tốt. Đời sau của nó lại dùng nguồn switching - đó có thể là lý do có bác nói rằng dù có bản GCC-250 nhưng nghe HCA-2 vẫn tình cảm hơn. Chất tiếng thật đặc biệt, nghe dễ chịu, có cá tính riêng. Điều khiển âm trầm rất tốt. Em bán rồi nhưng vẫn tiếc, vì thực sự nó kêu hay hơn cái amp em mua mắc hơn Thêm một góc nghiêng nữa nhìn cho vui
Em xin thử -trích Thật bất ngờ, sau khi chạy rà 5 ngày, PS HCA-2 mới thực sự trở thành chính mình ở tầm cao mới. Có thể nói âm trường, độ sâu, độ trong suốt và sự phân lớp tinh tế của các nhạc cụ phải gọi là mê hoặc. Một cảm giác gợi lên khoảnh khắc ấn tượng khi tôi nghe bộ Mark Levinson ML 2 cất tiếng cách đây khoảng 30 năm. Trải nghiệm đó vẫn khắc sâu trong tâm trí tôi cho đến bây giờ. Đây có thể nói là một nhân tố mới bất ngờ, với dấu ấn âm thanh như amp Class A thuần túy, nhưng lại không tỏa nhiệt, nhẹ cân, làm giảm hóa đơn tiền điện và tất cả những thứ khác mà bộ khuếch đại Class A không có. Mặc dù PS HCA-2 so được với các ampli Class A loại xịn, nhưng màu âm tổng thể của nó nằm trong khoảng 98% so với các ampli Class A thuần túy. Trên thực tế, chất lượng này gần nhau đến mức tôi nghĩ mình có thể dễ dàng sống chung với em ấy liền thôi. Bởi vì những gì em nó có thể thiếu chút này chút kia so với thuần class A lại được bù bù đắp lại bằng nhiều điều khác của hiệu suất tổng thể. Tôi đã bật PS Audio HCA-2 24/7 trong vài tuần nay và không gặp trục trặc hoặc lỗi lầm nào. Đơn giản là cắm, bật nhạc và tận hưởng ngay khi ra bật công tắc. -hết trích
Cách đây ~ 2 Tháng, mình cũng ngó nghiêng e này, tuy nhiên cân nhắc qua lại giữa vài cái ampli cùng tầm tiền với mức giá shop đưa ra là 21 Tr thì đành bỏ qua...
PS Audio HCA-2 thiết kế đơn giản nhưng đẹp. Rất nhạy cảm với ground loop, cho nên em phải ngắt chân mass dây nguồn ra, không thì ù. Mặt lưng nhìn bộ jack WBT là thấy thích rồi... Bên trong PS Audio HCA-2 là một bộ nguồn linear với biến áp lớn. Bộ tụ khá tốt, và có thể thay bằng tụ xịn hơn nữa như Philips hay Mundorf để cải thiện thêm chất âm. Các tụ nhỏ hơn phía cụm xử lý tín hiệu cũng có thể thay được. Em thấy các bạn Âu Mỹ có làm nên làm theo. Kết quả tốt. Đời sau của nó lại dùng nguồn switching - đó có thể là lý do có bác nói rằng dù có bản GCC-250 nhưng nghe HCA-2 vẫn tình cảm hơn. Chất tiếng thật đặc biệt, nghe dễ chịu, có cá tính riêng. Điều khiển âm trầm rất tốt. Em bán rồi nhưng vẫn tiếc, vì thực sự nó kêu hay hơn cái amp em mua mắc hơn Thêm một góc nghiêng nữa nhìn cho vui View attachment 993374 [/QUOTE] Anh đã rước con preamp TCP-5 của Thivanlabs về ráp với em nó dùng và rất may không bị ground loop như em nói. Ấn tượng khi bật nhạc lên nghe là rất đã, nghe hay hơn rất nhiều amply đã dùng trước đây là UR Secondo hybrid. Hiện tại đang rất hài lòng với bộ phối ghép này.
Em cập nhật chút xíu là sau khoảng thời gian ngắn gả em nó đi, mua một con mới mắc hơn, sau đó gả em mới đi. Cuối cùng, đi xin xỏ năn nỉ anh chủ mới để ... mua lại. May gặp người dễ thương. Và thế là lại yên ổn được một khoảng thời gian dài Đúng là chất âm em này quyến rũ đặc biệt!
Đây là bộ ruột sau khi nâng cấp. Điểm hay ho của HCA-2 là bộ nguồn rất tốt, kể cả khi chưa nâng cấp. Em thấy ở mọi amp, phần điện nguồn luôn cần để ý đầu tiên. Biến áp HCA-2 to đùng. 750VA trong khi tiêu thụ chỉ có chút xíu. Công bố 150W 8ohm nhưng John Atkinson đo ra 170wpc 8ohm. Sub bass tốt.
