Trên ebay có bán 2 em SHERBOURN PRE1-SHERBOURN CD1 mới giá chỉ 1/4 có bác nào biết qua em nó xin cho biết THKS
Hình như ít người chơi dòng này rồi. Mà Bác định ghép với gì thế ? Nhà em cũng đang chơi 1 con Pow 5 chanel của hãng này. Nghe đâu chuyên trị dòng B&W cứng đầu.
Cũng k biết ghép như thế nào chỉ muốn biết, có thể dùng trong phong ngũ SHERBOURN CD-1 Treat your CDs—and yourself—to the audiophile performance of our CD-1 CD player. Built to accurately and precisely decode digital audio from your disk collection, it offers both balanced and single-ended outputs on high-grade connectors, a rugged slot-loading mechanism. High reliability Toshiba slot load CD engine Machined aluminum remote control standard Balanced (XLR) single-ended (RCA) audio outputs Balanced AES/EBU (XLR), optical, and RCA digital outputs Rear panel trigger input and output ports 1-year warranty Types of media and data formats supported: Standard (Red Book) prerecorded audio CDs Standard audio CDs with HDCD™ encoded content CD-R media with standard audio CD content CD or CD-R media with MP3 content (single flat directory structure) Red Book (standard) layer of hybrid (dual layer) SACDs CD loading mechanism: Toshiba slot-load CD engine Front panel controls and indicators: Pushbutton with indicator LEDs, blue VFD status display Remote control: Infrared, solid machined aluminum Output level: 2 V RMS Frequency response: 20 Hz - 20 kHz +/- 0.1 dB Channel separation: >= 95 dB @ 1 kHz Signal to noise ratio (S/N): > 100 dB (A weighted) THD: <= 0.01% @ 0 dB, 1 kHz Phase linearity: 30 degrees Digital to analog conversion: High-performance multibit Delta-Sigma (Analog Devices AD 1955) 8x oversampling "Data Directed Scrambling" for high jitter immunity "Perfect Differential Linearity Restoration" for reduced idle tones and lower noise Analog output filter: -3 dB @ 80 kHz Analog outputs: Balanced audio (XLR), unbalanced audio (RCA) Digital outputs: Optical (Toslink), XLR (AES/EBU), coaxial (RCA) Trigger and control: Trigger input (1/8"), trigger output (1/8") Weight: Weight: 17.5 lbs / 8 kg (unboxed) Dimensions: SHERBOURN PRE1 rbourn PRE-1: REMOTE CONTROLLED STEREO PREAMPLIFIER Sherbourn PRE-1_Front Sherbourn PRE-1_rear click image/s to enlarge image 2U (3.5 inch/8.9 cm High) Rack Mountable Chassis with an elegant 17.7 inch/45 cm Wide sculptured front panel that houses a complete set of control switches including those for treble and bass control. Seven precision stereo inputs, Balanced XLR and RCA Unbalanced connectors, phono input with moving magnet or moving coil capability, tape monitor loop, high quality performance via micro-processor controlled pure audio signal path, variable Low-Pass/High-Pass filters, -12dB/Octave Slope, headphone output, bass management, stereo/mono switching, 12 Volt trigger and two-way RS-232 controllability. Rackmount ears are available for a small extra charge • 2U (3.5 inch/8.9 cm High) Rack Mountable • Chassis with an elegant 17.7 inch/45 cm Wide sculptured front panel • Complete set of control switches including those for treble and bass control • Seven precision stereo inputs • Balanced XLR and RCA Unbalanced connectors • Phono input with moving magnet or moving coil capability • Tape monitor loop • High quality performance via micro-processor controlled pure audio signal path variable Low-Pass/High-Pass filters • -12dB/Octave Slope • Headphone output • Bass management • Stereo/mono switching • 12 Volt trigger and two-way RS-232 controllability • Rack-mount ears are available for a small extra charge • Weight in carton is 8 kg RRP: $1199
