Tư vấn cho em với : Toshiba 32A3500
Discussion in 'Màn hình/Máy chiếu' started by mrzhongvn, 27/8/09.
  1. mrzhongvn
    mrzhongvn Approved Member
    Em đang định mua con này, hàng xài rồi, giá 5tr8. Các bác cho em biết panel của con này là gì, mấy bit, tần số quyét là bao nhiêu ? Em cảm ơn nhiều
  2. tai_trau
    tai_trau Moderator
    Những thông tin về các mặt hàng điện tử gia dụng là khá phổ biến, bác có thể tự tham khảo trên google.
    Ví dụ chiếc TV bác hỏi, em tra trong vòng 5 giây thì thấy thông số như sau:
    Toshiba 32A3500 - Features:
    32" Wide Screen Multi-System LCD TV
    Toshiba Regza 32A3500 Multi System LCD TV Multisystem Multi-system Multi Standard.
    NTSC/PAL/SECAM Color System
    Watch any signal on this TV!
    NTSC M, PAL BG/PAL I/Secam BG, DK/ PAL DK TV tuners
    32" Wide Screen Active Matrix TFT ASV (Advanced Super View) LCD Panel
    TFT low reflection coating and PC input
    REGZA HD Panel (16:9). 1366 x 768 resolution.
    800:1 contrast ratio.
    Brightness 500cd-m2.
    8ms response speed.
    178º viewing angle.
    Meta Brain Pro. 3D colour management. Comb filter.
    HDMI input. SRS WOW sound system. Jet slit speaker system.
    Dual component Video Inputs
    XGA RGB PC terminal. WXGA 16:9 Panel
    Swivel Stand (15 Degrees Left and Right)
    World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!
    32-inch “Magic Square Algorithm” LCD TV with PC input and HDMI
    World-Wide NTSC/PAL BG/PAL I/Secam BG, DK/ PAL DK TV tuners enables you to plug your cable
    TV line right into the TV and start watching. Or connect a Satellite receiver or cable box.
    Widescreen 16 X 9 Format
    800:1 contrast ratio provides incredible images whether you're watching dark or bright scenes!
    500cd/m2 High Brightness
    Meta Brain Pro
    3D Colour Management
    HDMI INPUT
    60,000-Hour Lamp Life
    1.07 Billion Colors (1,024 Tones)
    1/60 second Real Speed Progressive
    1366 X 768 Pixels
    6.22 Million Pixels Over-sampling and Scaling System
    Real digital picture
    New Digital Platform
    Real speed Progressive Scan
    Over Sampling Scaling
    Nicam Stereo receiver
    15ms High Response Rate
    170o Wide Viewing Angle
    30 degree Horizontal Swivel Table Stand
    BBE High Definition Sound
    Toshiba's LCD backlight life is long enough to give you viewing pleasure for many years.
    Image Inverter for Custom Installations
    allows you to invert the image upside-down or "mirror" image if you need to hang it in an unconventional manner.
    170º/170º Viewing Angles are so wide you can view Liquid Crystal Televisions from anywhere in the room!
    Lamp Life: 60,000 hours
    Viewing Angles: 170ºH / 170º V
    Audio System: 2.5W + 2.5W
    HD Ready - 1366 x 768
    PC input
    HDMI input for HDTV
    RF input for PAL, NTSC and Me-secam
    2 Component Input (Y/Pr/Pb )
    S-Video Input
    Composite (AV) Video Input
    Composite (AV) Video Output
    Power Consumption AC: 65W
    Audio Output: RCA: L/R x 1
    ENERGY STAR® Compliant
    World-wide Dual Voltage 110-240 volts 50-60 hertz
    Dimension (w/ stand) - 660 x 535 x 275mm (W x H x D)
    Dimension (w/o stand) - 660 x 484 x 117mm (W x H x D)
    Weight without Table Stand: 26 lbs.
    Weight with Table Stand: 32
  3. mrzhongvn
    Ý em muốn hỏi là giá đó có ổn không so với thời điểm hiện tại. Còm bảo hành khoảng 3 tháng. Vì một số máy giờ mới cũng tầm 6,5tr trở lại
  4. tai_trau
    tai_trau Moderator
    Ơ, rõ ràng là em thấy bác hỏi về thông số kỹ thuật mà.
    Còn giá thì em chịu, em mà mua TV cũ, thì tất nhiên là 4 triệu thì khoái hơn là 5 triệu.
  5. zadops
    zadops Approved Member
    sao bác không thử qua chiếc Toshiba 32AV550E, em vừa mới mua, 6.990.000 VNĐ, tặng kèm quạt sạc trị giá 990.000, bảo hành 24 tháng
