Xin tư vấn ampli sansui AU-V7000
Discussion in 'Thiết bị khuếch đại' started by LikeDIY, 15/5/06.
  1. LikeDIY
    LikeDIY Approved Member
    Vừa rồi tôi có dịp qua chợ gò Châu Đốc ôm về Ampli sansui AU_V7000 (Dolby prologic) còn khá mới. Bên trong tụ và các con vít vàng choé còn các Jack S-VHS vá RCA thì toàn màu vàng . Nói chung còn khá mới, Xin các bác biết cho em biết về chất âm amply nầy và phối ghép ra sao? Xin cảm ơn!
  2. ngtatliem
    ngtatliem Advanced Member
    C.S.J
    Chào Bác,
    Gửi Bác thông số của nó đây, cố gắng luyện tiếng Anh nha! Thông cảm cho em vì em không có bản tiếng Việt :lol:
    SANSUI AU-V7000
    \ 99,800 (1990 June sale)
    So far the AV amplifier which pursues the high quality of sound without you show the audio technology which is cultivated, presuming upon visual.
    Quality of sound is designated as important topic, five power amplifiers are made discrete constitution.
    It has succeeded in raising the [saraundo] effect more by distributing the front/the rear to ideal power balance.
    Front L/R, as for center identical power, 100W×3ch of identical quality, the rear it makes 5 amplifier systems of 50W×2ch, it makes sound field reappearance possible as the decoder for business by loading the Dolby [purorojitsuku] [saraundo] processor which has the same function.
    The power source section makes A/V independent source in order to remove the mutual interference of the audio signal and the visual signal where character differs, adopts the trance and the large-sized heat sink of the new design.
    In addition you consider, in one one of part, such as audio private condenser and high speed diode and furthermore effective copper bis to vibration absorption have improved the quality of power source.
    The bus (bass), [toreburu] (the treble), mid- (mediant) becoming independent, adjusting possibility has loaded triple tone control.
    Because it corresponds to also the software where channel balance has deteriorated with the scene, decoding which always is stabilized is done automatically, automatic input balance is loaded.
    In order to start making the sound field space like the concert hole and the like, up-to-date floating [dejitarudeirei] is loaded. In addition, it is possible to make the [saraundo] space, not only the professional logic corresponding software, vis-a-vis the 2ch software.
    With the 5/10msec. step be able to control the delay time to longest 100msec., for example when it plays back with “stadium mode”, by the fact that the delay time is set optimumly, playback of the sound field kind of space which it can happen to be present just in that place becomes possible.
    4 modes [saraundo] which makes the sound field playback with Dolby [purorojitsuku] possible is equipped.
    Normal mode when the small-sized speaker is used for center, distributing the signal below 100Hz to front L/R, reproduces bass.
    As for wide mode in center as front L/R when the speaker of the same quality is used, it is [saraundomodo] which shows the volume of professional logic.
    With the mode which phantom mode depends on 4 speakers the front and the rear and plays back, the signal of center it distributes to front L/R equally.
    Dolby 3 stereo mode in case the front 3ch which does not use the rear speaker mixes the rear signal to front L/R, can obtain the effect which is close to [saraundo].
    [saraundo] mode is loaded other than professional logic. This, 8 systematic 6 lines are controlled simultaneously the function which is made the rich sound field impression of having the extent with [saraundo] due to floating [dejitarudeirei], the 2ch stereo source is.
    With matrix mode, 2ch is output that way from the front, echo is output from the rear.
    As for hole mode, the sound field which has depth and the extent impression due to the rich reverberation which sets the concert hole is feature.
    Stadium mode the scale impression of the live concert and the sport event of the wide space and, reproduces the force of the kind of sound which is wrapped.
    With natural mode the sound field which the very, has natural extent in the rich source of the reverberation component is made.
    Input of 10 systems of total of image 5 system and audio 5 system of S terminal correspondence is equipped.
    While doing the dubbing of video, it loads the dubbing function in parallel A/V where the tape dubbing of CD is possible.
    In addition, image of the source which differs and the AV mixed video recording playback function which can combine sound are loaded.
    The simple [otomodo] [tesutoton] circuit of adjustment is equipped.
    This while going around each channel automatically, adding with the function which you adjust, loads the manual mode which is adopted for also the equipment for business, output level and it is possible by locking the test tone of the channel which it chooses optionally at one time, to adjust the timbre accurately.
    Function selection, volume adjustment and [saraundo] mode set etc can be operated programmable remote control (RS-1260) standard have equipped simply from power source ON/OFF.
    Rating of type Type AV [saraundoanpu]
    < Audio section >
    Utility installed capacity (EIAJ and 6Ω) Front: 100W+100W
    Center: 100W
    Rear: 50W+50W
    Frequency characteristic Phono MM: 20Hz~20kHz and ±0.3dB
    Line: 10Hz~100kHz, +0 -3dB
    SN ratio Phono MM: Above 72dB
    Line: Above 90dB
    Tone control Bass maximum change quantity: ±10dB (50Hz)
    Mid maximum change quantity: ±6dB (1kHz)
    Treble maximum change quantity: ±10dB (15kHz)
    Input sensitivity/impedance (1kHz) Phono MM: 2.5mV/47kΩ
    Line: 150mV/47kΩ
    Phono maximum permissible amount MM (THD 0.1%): 140mv
    < Video section >
    Frequency characteristic 5Hz~10MHz, +0 -3dB
    SN ratio Above 60dB
    < Synthesis >
    Rated electric power consumption 245W
    External size Width 466× height 163× depth 441mm
    Weight 16.2kg
  3. tonken
    tonken Advanced Member
    bac mua no gia bao nhieu vay ! con nay ngoai NTao em hoi no bao 2,3 trieu day ! gia vay co hop ly khong vay bac em cung dang muon 1 em no
  4. LikeDIY
    Cảm ơn bác ngtatliem, Tonken
    Em đã xem thông tin bác gửi hay quá. Em thấy bác thích hãng SANSUI mà em cũng thích nó nữa. Mà bác ơi, Bác có tìm được tài liệu hướng dẫn sử dụng của nó không em tìm hoài mà không thấy.
    Giá con nầy em mua ở Châu Đốc là 2Tr. Vậy thì em thấy ra NTảo mua sướng hơn vi em vác về bằng xe máy muốn nát cặp đùi của em.
    Các bác nào có kinh nghiệm sử dụng về Ampli sansui mà đặt biệt là AU-V7000 vui lòng cho em biết cảm ơn!
    * Bạn LikeDIY chỉ cần nhấn phím Trả lời để post bài . Không nhấn "Bài mới " -> mở chủ đề mới .- Capricornus
  5. tonken
    Con này bên trong xài 10 sò than được chia cho các kênh F, R C ngày trước mình ghép nó với loa Bose 301 nghe cũng đc lắm
