Bác nào đã dùng qua loa Center Klipsch KG 2.2V cho em xin ý kiến đánh giá với nhé. Đa tạ các Bác ! Thông số em nó đây ạ: SPECIFICATIONS * BUILT FROM: 1992 * BUILT UNTIL: 1994 * DIMENSIONS: 19.5" (49.5cm) x 9.25" (23.5cm) x 9.25" (23.5cm) * ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF) * ENCLOSURE TYPE: Bass reflex via rear-mounted port * FINISHES: Walnut Oil, Oak, Oil, Oak Clear, Finished Black * FREQUENCY RESPONSE: 50Hz-20kHz(+-)3dB * HIGH FREQUENCY HORN: Exponential Cone * NOMINAL IMPEDANCE: 8 ohms * POWER HANDLING: 75 watts maximum continuous (375 watts peak) * SENSITIVITY: 93dB @ 1watt/1meter * TWEETER: K-86-K 1" (2.54cm) Phenolic dome compression driver * WEIGHT: 23.5 lbs. (10.7kg) * WOOFER: Two K-1008-KV 6.5" (16.51cm) Injected Carbon Graphite cones. http://www.klipsch.com/kg-2-2v
