"Ai là người bí ẩn"- Carver CM-2002 ?
Discussion in 'Thiết bị khuếch đại' started by PKHAUDIO, 6/5/07.
  1. PKHAUDIO
    PKHAUDIO Advanced Member
    Q.11, TP.HCM
    có bác nào biết thông tin nào về cái Ampli Carver CM-2002 không ? Search trên mạng ko thấy thông tin thương mại và kỹ thuật nhiều về em này
    có một số Khoai tây trên mạng cũng đặt câu hỏi như tui bây giờ
    Thục hư CM-2002 này như thế nào ?
    CM-2002
    The preamplifier section combines essential "purist" features, such as a separate digital input and an integral D/A converter, with the convenience of remote control operation. The CM-2002 also features Carver's exclusive Advanced Sonic Holography™ processing for utterly lifelike sound field imaging. With a Carver preamplifier, a Carver power amplifier and a state-of-the-art signal processor combined in one precision chassis, the CM-2002 integrated amplifier should be seriously auditioned by every audiophile who can appreciate both performance and value.
    As Carver is famous for separates audio components (particularly high-performance power amplifiers), any integrated amplifier bearing the Carver name has extremely high standards to meet. Combining the latest in signal path technology with the muscle of pure Carver amplification, the CM-2002 integrated amplifier stands high above its class. This very conservatively rated 105 watts per channel amplifier has the current and voltage performance- and consequently the clarity- of some of the best separate designs.
    Sonic Holography™ for lifelike soundfield imaging
    Inputs for CD, Tuner, Aux, and 2 Tape Decks
    Headphone jack
    One Coaxial Digital input and internal D/A converter
    Dual analog lighted meters
    2 Tape record outputs
    Remote Control
    Preamplifier output loop
    Independent recording of any input, and tape dubbing
    Phono input with MM or MC style cartridge selector
    External processor input and output loop
    Speaker Mute
    Bass, Treble and loudness controls
    Motorized Volume Control
    The handles can be removed to make it 17 inches wide
    AC outlets
    Available in 120 V or 240 V versions 50/60 Hz
    Frequency Response: 20Hz -20kHz
    105 watts per channel 8ohm
    150 watts per channel 4ohm
    Separation: >70db @ 1 kHz
    THD: less than 0.08% at full power
  2. PKHAUDIO
    Q.11, TP.HCM
    Có một Khoai tây cũng đặt vấn đề về con CM-2002 như mình :
    (I tried posting in the Vintage section with no results so far so I'll try here)
    This is my first post here so hopefully I'm at the right place for some info. About 4 years ago I purchased a Carver CM-2002 intergrated amp from their website. (At the time I did not know that Bob Carver had left the company) This is the 105 watt per channel amp with phono section, hologram processing, and remote control. Through the years I have search for information about this amp on the Web but have come up almost with a blank! It's only been a couple of times that I've seen one being sold on Ebay. The amp is not even listed on Carver's website! Am I missing something? Am I, and my amp in the Twilight Zone? Now don't get me wrong - I've enjoyed this amp very much over the years. And that has been with only a (lowly) pair of Polk RT5 speakers, a Polk subwoofer, a Technics CD player (SL-PG100), and a vintage Pioneer PL 560 direct drive turntable (that's another story). I've recently upgraded the CD player to a Marantz CC4300 disc changer. I'm about to kick my system up a notch - this past Friday I ordered a pair of B&W Nautilus 805s. (Will be ordering some Sound Anchors this week!) My question is - am I only one of maybe five people who purchased this unit? Is there any other person on the planet that can share their experience with this amp? Now, I know that I'm just at the beginnings of upgrading my listening experience at home and will soon upgrade my interconnects (cheapies now), speaker wires (monster cable 16 gauge zip now) and hardware (another intergrated? Separates?). What I'd like to hear is other owner's view of this amp - if there are any!!! Thanks in advance
  3. alexmax
    alexmax Advanced Member
    Em chưa biết về em này nhưng theo em thi Carver là 1 thương hiệu không phải thuộc loại suât săc . trước đây em có dùng qua mấy đời Amp của Carver thì thấy chỉ hợp với những loa dễ đánh thôi mặt khác linh kiện bên trong thì thuộc loại cỏ chỉ đẹp về hình thức thôi .
    Mấy ý kiến riêng của em . Kinh !
  4. danlangven
    danlangven Advanced Member
    SG-HN
    E có chơi qua Pow Caver rồi, nên có vài nhận xét:
    - Hình thức đẹp, hơi lạnh lùng.
    - Nguồn to đùng, nặng.
    - Linh kiện bé, nhưng sắp xếp ngăn nắp và rất chuyên nghiệp.
    - Công suất khỏe.
    - Giá cả không cao, dễ mua.
    Chất tiếng: cũng lạnh lùng như hình thức, âm trầm kiểm soát được, trung tốt, dải cao hơi chói, tuy nhiên nếu phối Pre bán dẫn với Pow Caver sẽ ra 1 chất giọng khỏe, hơi lạnh, và không tình cảm, thiếu sự ngọt ngào và truyền cảm của nhạc cụ hoặc 1 giọng ca nào đó, âm hình không rõ nét lắm, tuy vậy để đánh những loa độ nhạy thấp và không đắt tiền thì Caver cũng là 1 nhãn hiệu đáng để quan tâm.
    Em phối với Pre đèn thì cải thiện được 1 chút về âm hình, sự rung động của nhạc cụ, giọng ca được cải thiện, tuy vậy bass hơi yếu đi 1 chút.
    Con CM-2002 hình như bác "sói cô đơn" có chơi qua, xin bác có vài ý kiến!
  5. titduthu
    titduthu Approved Member
    có bác nào xài qua thương hiệu này chưa:
    http://www.sunfire.com/
    không biết có liên quan gì đến Carver không?
  6. Baoanh_Hue
    Baoanh_Hue Advanced Member
    phá Tam Giang
    Hãng SUNFIRE đã mua lại Carver rồi.
    Thân,
