Bán ampli đèn 2a3 SE hãng Audio Professor
Discussion in 'Amplifiers' started by anhtraichipheo, 28/6/18.
  1. anhtraichipheo
    anhtraichipheo Approved Member
    Ho Chi Minh
    Tên mặt hàng: Ampli 2a3 SE của Audio Professor chạy mạch 2a3 của kỹ sư đại tài người nhật Morikawa
    Tình trạng, mô tả: đã sử dụng còn rất mới, trước em mua của 1 bác trên vnav ạ
    Giá bán: đã bán
    Khu vực: HCM
    Điện thoại: 0909181300 - Sơn 34t
    Giao hàng: thoả thuận
    02B360B2-D2F7-4FB7-B726-A0E4BD23A31D.jpeg E6EE4BC9-6782-4044-B130-02553EB04E00.jpeg B14CF3F7-FE44-48BD-AEC4-5AF4EC2A2329.jpeg 5D7BE886-0750-45D2-B60F-BA230E7B1D7B.jpeg 3327A95F-40FB-4D30-A5A8-434F681E40C5.jpeg 05A811B8-709C-4CF2-B46F-77234B4D55A2.jpeg 47F20DF2-9631-4081-AB6D-8E618C360866.jpeg 47D4FE7D-2E1E-4399-A0EF-23EAA1B7D836.jpeg 9CBBE4DA-71A1-403A-9334-E11C4C92BEF5.jpeg
    Thông tin thêm: Ampli sử dụng toàn bộ biến áp của hãng Hirata Tango, biến áp xuất ấp XE-20s, các biến áp còn lại được Audio professor đặt hãng Tango làm riêng theo yêu cầu, bóng RCA jan 2a3 gần như mới, bóng tiền 6Z-DH3A mitsushita, rca jan 5z3.
    Các bác tham khảo thông tin tiếng anh bên dưới ạ:
    Morikawa is Japanese master in tube amplifier research, he is author of many famous tube amplifier book, this amplifier was introduced in one of his best seller of serial book named "Audio tube amplifier". Amplifier use all Hirata TANGO transformer, output transformer is XE-20S, which use orient cutting core, same as X series transforme. Block condenser is Audio Professional which is order made from ELNA Cerafine, choke and grid choke, power transformer was Audio Professor Inc, which is special ordered made from Hirata Tango. Another parts are high quality and selected one as you can see in pictures. With XE-20S output transformer you can easily change tube to 300B, as well as PX25, DA30 with some modification. Output speaker terminal are 8,16ohm. Out put power is about 4-5W, 2A3 is working in class A. In this circus, 2A3 was driven by grid choke, which is working same as interstage transformer. It make the sound deeper and wider. It also protect your tube. The prestage is SRPP circus which used 6Z-DH3A tube. This tube is nearly same 76 tube, the outlooking is quite same.
  2. thanhmev
    thanhmev Approved Member
    Ampli này đang ghép với loa gì em ?
  3. anhtraichipheo
    Ho Chi Minh
    E đang ghép với cặp University 315C series 200 anh.Ampli đã bán rồi anh ạ, thanks a quan tâm
