Bán ampli đèn 2A3 SE hãng Audio Professor
Discussion in 'Amplifiers' started by Acuti, 13/6/19.
  1. Acuti
    Acuti Advanced Member
    Sài Gòn - Hà Nội
    Tên mặt hàng: Ampli Audio Professor 2a3 SE của chạy mạch 2a3 của Professor Morikawa
    Tình trạng, mô tả: Còn rất mới
    Giá bán: 37tr
    Khu vực: Sài Gòn
    Điện thoại: 0907.346688 (em 45t)
    Giao hàng: Thỏa thuận
    Thông tin thêm: Ampli sử dụng toàn bộ biến áp của hãng Hirata Tango, OPT hirata XE-20s (riêng cặp OPT Tango hirata hiện đã gần 20 củ vnđ) , các biến áp còn lại được Audio professor đặt hãng Tango làm riêng theo yêu cầu. Tụ nguồn Elnacerafine. Bóng RCA jan 2a3 gần như mới, bóng tiền 6Z-DH3A mitsushita, rca jan 5z3. đã nâng cấp tụ audionote kaisei 100uF/100V BP cho bóng cs.
    Amp chất lượng im phăng phắc không ù xì gì nhe.
    Các cụ quan tâm xem thông tin tiếng anh bên dưới ạ:
    Morikawa is Japanese master in tube amplifier research, he is author of many famous tube amplifier book, this amplifier was introduced in one of his best seller of serial book named "Audio tube amplifier". Amplifier use all Hirata TANGO transformer, output transformer is XE-20S, which use orient cutting core, same as X series transforme. Block condenser is Audio Professional which is order made from ELNA Cerafine, choke and grid choke, power transformer was Audio Professor Inc, which is special ordered made from Hirata Tango. Another parts are high quality and selected one as you can see in pictures. With XE-20S output transformer you can easily change tube to 300B, as well as PX25, DA30 with some modification. Output speaker terminal are 8,16ohm. Out put power is about 4-5W, 2A3 is working in class A. In this circus, 2A3 was driven by grid choke, which is working same as interstage transformer. It make the sound deeper and wider. It also protect your tube. The prestage is SRPP circus which used 6Z-DH3A tube. This tube is nearly same 76 tube, the outlooking is quite same.
    tranman and kienbloc like this.
  2. Acuti
    Sài Gòn - Hà Nội
    Em ở Bình Thạnh Sài gòn. Bác nào quan tâm sớm em sẽ có quà tặng 1 cặp tụ Black gate F cathode 100uF/25v upgrade cho đèn driver amp này. ; )
    vuthanh6 likes this.
  3. Nguyễn Xuân Hiến
    Nguyễn Xuân Hiến New Member
    Bác cho em ké tí em cần mua con DAC cocktail x45 màu bạc DT 0974758353 bác nào nâng cấp ơi em
  4. DUCGIANG
    DUCGIANG Advanced Member
    E này ghép với spendor bc 2 ko biết ntn B chủ nhỉ?
  5. Acuti
    Sài Gòn - Hà Nội
    dạ em chưa nghe spendor nên không biết bác ạ
  6. Trinhtung586
    Trinhtung586 New Member
    Em cũng đang kiếm 2a3 mà bác chủ ở xa quá
  7. Acuti
    Sài Gòn - Hà Nội
    cám ơn bác quan tâm.
  8. Mr Binh
    Mr Binh Approved Member
    Đang choi altec ma sao ban 2a3 bác
  9. Acuti
    Sài Gòn - Hà Nội
    tính sắp tới nâng cấp tí bác. Nếu k đi được thì vẫn nâng cấp. Hàng ngon đồ tốt mà bác :)
  10. Acuti
    Sài Gòn - Hà Nội
    Lên cho chiều thứ 5. Mời các bác bác quan tâm !
  11. haiken
    haiken Advanced Member
    Quan 3, TP Ho Chi Minh
    Amp này hay, tiếng chi tiết đều các dãi. Lúc trước amp này mình mua mới tinh, bây h không lẽ mua lại :)
    Acuti likes this.
  12. Acuti
    Sài Gòn - Hà Nội
    thì bây giờ vẫn mới tinh mà bác :)
    haiken likes this.
  13. anhtraichipheo
    anhtraichipheo Approved Member
    Ho Chi Minh
    Con này k nhầm thì bác này mua của em, và e mua con này của anh, haha
    Anh Đinh 123 and haiken like this.
  14. Acuti
    Sài Gòn - Hà Nội
    yes, thì nó đó. Đang chơi đồ gì bác ?
    anhtraichipheo likes this.
  15. kienbloc
    kienbloc Advanced Member
    Up phụ bác chủ , khi nào bác chủ bán xong, bác nào muốn chơi amply 2a3 kit japan ,bóng gấu thì LH em nhé, em cũng muốn chuyển qua 300B trải nghiệm!thanks
    Acuti likes this.
  16. mannhung
    mannhung Approved Member
    em cũng muốn thử 2a3 và thừa kis 300 b
      41,4 KB
    kienbloc likes this.
  17. anhtraichipheo
    Ho Chi Minh
    Bác muốn trải nghiệm 300b thì liên hệ em nhé, cặp bóng 300b western electric, xuất âm tango XE-60-3.5S bao gấu ạ, hihi
    CC0CF7B6-3D21-492E-A3CE-15F8FB98ECE2.jpeg 0D9278CB-CA64-4F34-AAE2-5431555A4DDF.jpeg 318E9398-FEC7-4E4C-9976-D22FCEB01561.jpeg 0D7AA67A-805E-4193-AC0F-D12CE1191105.jpeg
    kienbloc, panzer90 and haiken like this.
  18. anhtraichipheo
    Ho Chi Minh
    Vẫn đi lòng vòng bác ạ, hix
  19. Acuti
    Sài Gòn - Hà Nội
    bác anhtraichipheo khoe 300B thế này làm sao mình bán 2a3 nhỉ ???
  20. panzer90
    panzer90 Advanced Member
  21. Trinhtung586
    Em thì có kt88/6550 tango. Muốn giao lưu 2a3 hoặc 300b se. Có bác nào cần ko ạ 20190104_081344.jpg
  22. Acuti
    Sài Gòn - Hà Nội
    Lên cho ngày cuối tuần ! Các bác show hàng kinh quá. Em nó chắc chưa hết duyên rồi ;)
  23. Acuti
    Sài Gòn - Hà Nội
    Chào buổi tối đầu tuần !
  24. Acuti
    Sài Gòn - Hà Nội
    Giảm giá 36tr cho ngày thứ 3 !!!!
    Mời các bác quan tâm
  25. hugo
    hugo Advanced Member
    Gia Định Thành
    - Lại thay đổi ủn lên cho mau đi. Hàng ngon hii
