Conrad Johnson PRE-CD Solid State Model: DF1
Discussion in 'Digital - Computer' started by JB Vintage Audio, 3/12/21.
  1. JB Vintage Audio
    JB Vintage Audio Advanced Member
    Tên mặt hàng: PRE-CD Solid State Conrad Johnson, Model: DF1
    Tình trạng, mô tả: used & rare
    Giá bán: 35,000,000
    Khu vực: TP HCM
    Điện thoại: 0902180088
    Giao hàng: Toàn quốc
    (Ảnh chụp thực tế)
    Thông tin thêm: PRE-CD Solid State Conrad Johnson, Model: DF1
    tiếng em nghe CŨNG ĐƯỢC, mua 1 lần được 2 trong 1
    PRE và CD khỏi tốn dây
    ae cho offer nha, em nặng chừng 8Kg / Thank you ae
    JB checked SOLD item usaudiomart 2021 + phí chuyển về VN 1 chặng nữa,
    https://www.usaudiomart.com/details...ine-preamplifier-excellent-working-condition/
    ____________________________________________________
    The DF1 combined a superb line stage preamplifier with and integral CD transport.
    An infrared wireless remote control was included. The DF1 could be used as a stand-alone CD player or as a unit combining the preamp and CD functions in a single chassis.
    The DF1 was known for conrad-johnson’s superior imaging, depth, and soundstaging.
    CD Player:
    The DF1 CD mechanism uses a single laser beam that does not require alignment. The 176.4Khz sampling rate and noise shaping circuitry yield 16 bit resolution, and allow gentle filtering well above the audio frequency band. Digital to Analog converters are employed to eliminate phase shift between channels and avoid switching glitches.
    Preamp Stage:
    Unlike most CD players that use IC’s in the line stage, the DF1 uses discrete FET analog circuits with separate discrete regulated power supplies—circuits which have proven reliability and superior soundstaging and imaging.
    The DF1 uses the highest quality component parts. Precision tin-oxide resistors, polypropylene capacitors and polystyrene capacitors and premium quality controls are used throughout the DF1.
    __________________________________________________________
    Specifications:
    Line Stage:
    Gain: 26dB
    Maximum Output: 5V
    Frequency Response: band-pass 5Hx to more than 100Khz
    Hum and Noise: better than 82dB below 1.0V output
    Distortion: less than 0.25% THD at rated output
    CD Player (Direct Out):
    Output: 1.1V
    Frequency Response: 5Hz to 19Khz +0.5dB
    Hum & Noise: better than 85dB below 1.0V
    D/A Conversion: 16 bit resolution through 176.4kHz sampling, digital filtering
    Mechanical:
    19” Wide X 3 ¾” High X 12” Deep
    Weight 19 lbs.
  2. New-long2005
    New-long2005 Advanced Member
    Thấy Conrad Johnson là em úp phụ!
    JB Vintage Audio likes this.
  3. thongnga
    thongnga Advanced Member
    Lâu lắm không thấy anh Cương lên sóng.
    Anh sang mỹ rùi ạ.
