Goto Unit - Thành viên mới trong hệ thống.
Thảo luận trong 'Giới thiệu hệ thống Nghe-Nhìn của thành viên' bắt đầu bởi giahy, 8/3/09.
  1. hiend-to-end
    hiend-to-end Advanced Member
    Tham gia ngày:
    25/9/06
    1.121
    Đã được thích:
    16
    Nơi ở:
    HANOI
    Anh HETE có thể tham khảo gia phả của M7 dưới đây nhé
    --Kondo san's M7 started as a solid-state (!) preamp. The "M" stood for German "Meister".
    --The first tubed M7 preamps were marketed jointly with Peter Qvortrup as Audio Note, before the UK-Japan split. The line-only version employed 6X4 rectification and a single 5687 was used for signal amplification, and this is the circuit most often seen on the internet. Note that this was quite influential for its time, single-handedly reviving use of the 5687.
    --The first tubed full-function preamps, also marketed as Audio Note, incorporated an MM phonostage and used 6072 in both the phono and line stages. Circuit of this is also ubiquitous on the internet (an example of a 1991 versionhere). It is interesting to note that that onto the next generation Kondo has largely maintained different topology in their line-only and full-function preamps.
    --In 2000, the M7 line was revamped. The label now became M7 IIk. All retained the use of 6X4 as rectifier. But now the line-only version used2x 5687 and 2x 12AT7; the full-function version used 2x 5751 and 2x 5687; a stand-alone phono preamp version was introduced, which used2x 5751 and 2x 12AU7. A signature version offered better tubes and material.
    --The latest revision came some time after Kondo san's death in 2006 (and I think it is "current"; though there is talk of the discontinuation of the entire M7 line) . Use of the 6X4 as rectifier has been retained. But now, the line-only version uses only 2x 12AU7; the full-function version uses 2x 12AX7 and 2x 12AU7; the stand-alone phono preamp uses 2x 12AX7 and 2x 12AU7. Looking at the tube complements, personally I see simplification from previous generations. M7 phono and M7 linestage belong to this period. KSL-M7 ...
    -- Kondo moved away from use of the 5687 because digital replay has improved vastly, and no longer needs the service of the mellower 5687.[/quote]
    Cảm ơn thaiduong nhiều!
    HT
    PeterPan thích bài này.
  2. giahy
    giahy Advanced Member
    Tham gia ngày:
    22/10/07
    1.983
    Đã được thích:
    30
    Không phải đâu T.iu. Nó rất nhiều phiên bản. Trước đây mình đã xài qua tới 2 phiên bản Silver Sound lận. Mà bóng bánh chả cái nào giống cái nào t.iu ạ.
  3. giahy
    Tham gia ngày:
    22/10/07
    1.983
    Đã được thích:
    30
    Sao T.iu có vẻ sính ngoại thế nhỉ? Mình viết quá trời bằng tiếng Việt t.iu chẳng thèm tin. thaiduong viết ba lăng nhăng mấy câu tiếng Anh, t.iu cảm ơn rối rít. :D
  4. hiend-to-end
    Tham gia ngày:
    25/9/06
    1.121
    Đã được thích:
    16
    Nơi ở:
    HANOI
    Hhehehe, em nghe đồn khoai tây nó tốt hơn khoai ta, mọi nhẽ, T.iu đồng ý không? :D
  5. Củ Mì
    Củ Mì Advanced Member
    Tham gia ngày:
    1/12/11
    1.358
    Đã được thích:
    58
    Sao T.iu có vẻ sính ngoại thế nhỉ? Mình viết quá trời bằng tiếng Việt t.iu chẳng thèm tin. thaiduong viết ba lăng nhăng mấy câu tiếng Anh, t.iu cảm ơn rối rít. :D[/quote]
    Hhehehe, em nghe đồn khoai tây nó tốt hơn khoai ta, mọi nhẽ, T.iu đồng ý không? :D[/quote]
    Anh HETE cho em hỏi khoai mì tây có ngon hơn củ mì ta không , nếu có để em đổi nick thành " Củ Mì Tây " cho nó oai. :lol: :lol:
  6. giahy
    Tham gia ngày:
    22/10/07
    1.983
    Đã được thích:
    30
    Anh Hete chả biết Củ Mì là gì đâu bác ơi. :D
  7. giahy
    Tham gia ngày:
    22/10/07
    1.983
    Đã được thích:
    30
    Tiu chủ yếu chơi đĩa nhựa, vậy đã có mấy món phụ kiện này chưa?
  8. hiend-to-end
    Tham gia ngày:
    25/9/06
    1.121
    Đã được thích:
    16
    Nơi ở:
    HANOI
  9. giahy
    Tham gia ngày:
    22/10/07
    1.983
    Đã được thích:
    30
    Hi hi, 1 cần, 1 kim thì không cần xài mấy cái này đâu. :D
  10. hiend-to-end
    Tham gia ngày:
    25/9/06
    1.121
    Đã được thích:
    16
    Nơi ở:
    HANOI
    Ối giời ôi thì ra lâu nay vẫn âm thầm lẩn trong núi luyện đan!
    Mấy em Thorens Reference đâu hết rồi T.iu? Có cho em nào trong số đó đi ở không vậy?
    HT
  11. hongcongdh
    hongcongdh Advanced Member
    Tham gia ngày:
    12/11/10
    2.641
    Đã được thích:
    Nơi ở:
    VNAV
    "Một Hà Nội ngây ngất nắng
    Một Hà Nội run run....... heo may!" :lol:
    hxhxx
  12. giahy
    Tham gia ngày:
    22/10/07
    1.983
    Đã được thích:
    30
    :D
  13. hiend-to-end
    Tham gia ngày:
    25/9/06
    1.121
    Đã được thích:
    16
    Nơi ở:
    HANOI
    Lâu lâu được ngắm thật thỏa lòng mong nhớ người tình trong mộng :)
    Khi nào định cho các em đi ở thì hú em một tiếng nhé. Tới giờ em đã tiết kiệm được đủ tiền mua ... 4 cái chân ... lùn của nàng zồi!
    HETE
  14. L.O.K
    L.O.K Advanced Member
    Tham gia ngày:
    16/2/08
    883
    Đã được thích:
    71
    Kondo giờ này lười quá, toàn dùng biến áp Tango, không phải biến áp tự cuốn nữa rồi :(
  15. giahy
    Tham gia ngày:
    22/10/07
    1.983
    Đã được thích:
    30
    Từ xưa giờ biến thế nguồn, choke vẫn đặt hàng của Tango, Kondo chỉ tự cuốn biến thế xuất âm thôi mà cụ.
  16. hongcongdh
    Tham gia ngày:
    12/11/10
    2.641
    Đã được thích:
    Nơi ở:
    VNAV
    Anh giahy có đánh giá gì về Mid Omega và Alluminum Bass của mấy dòng đời mới này ko? (cái anh nghe chắc Mid vẫn là Composite, em thấy khoai tây nó ca cái Omega mới dữ quá). Hỏi một số khoai ta thì nói nó mộc hơn đời cũ (vì tweeter la berry) trung âm lớp lang thì rõ hơn gốm.
    Anh có nhận xét gì ko? :D
  17. thaiduong
    thaiduong Advanced Member
    Tham gia ngày:
    14/9/08
    1.045
    Đã được thích:
    78
    Hehe thật ra là mấy anh khoai tây lại đi dịch từ forum của mấy anh xứ Đài đấy ạ :lol:
  18. thaiduong
    Tham gia ngày:
    14/9/08
    1.045
    Đã được thích:
    78
    Bass của DB9 đâu có phải bằng nhôm đâu cụ?? Cụ lăn tăn Omega làm gì, nếu cụ không ngại vụ "lâu lâu thay áo mới cho em 1 lần" thì cứ yên tâm xài củ gốm nhé :mrgreen:
  19. hongcongdh
    Tham gia ngày:
    12/11/10
    2.641
    Đã được thích:
    Nơi ở:
    VNAV
    Em đang nói DB9S dùng củ omega mới va bass allu ợ.
  20. quantrungyen
    quantrungyen Advanced Member
    Tham gia ngày:
    12/2/09
    861
    Đã được thích:
    40
    Hình như hôm nay là sinh nhật thứ 47 của bác C. Chúc Bác giữ mãi niềm đam mê với Audio và truyền đạt lại kinh nghiệm và sự hiểu biết của Bác cho chúng em nhé. :D
    Khai thác miễn phí chút.
  21. giahy
    Tham gia ngày:
    22/10/07
    1.983
    Đã được thích:
    30
    Cảm ơn bác.
    Hôm nay em tự thưởng sinh nhật mình bằng cặp đôi đầu bảng của Constellation Audio. :D
    Preamp Altair II và Poweramp mono Hercules II.
    Cảm nhận đầu tiên là . . . . choáng.
    Preamp Altair II có 2 “cục” với nguồn rời, thiết kế khá hầm hố, bắt mắt được gia công rất kỹ, tinh xảo và sang trọng. Với mục đích giảm thiểu nhiễu điện từ và chống rung động do tác động từ bên ngoài, vỏ của Altair được gia công từ nhôm khối rất dày, chỗ mỏng nhất cũng dày tới 8.2mm. Khi đưa máy lên kệ, cảm giác từ vỏ máy rất mát tay, mượt, nặng và chắc chắn. Bên trong cục nguồn trang bị 3 biến thế nguồn rời riêng biệt để cung cấp điện cho 2 kênh analog trái, phải và phần điều khiển. Phần pre Altair II với màn hình cảm ứng phía trước có giao diện đơn giản và thân thiện. Bên trong được thiết kế và sử dụng mạch balance dạng gương. Có thể hiểu đây là hai bảng mạch giống nhau hoàn toàn nhằm đảm bảo hai kênh đạt được sự cân bằng hoàn hảo cũng như giúp giảm thiểu tiếng ồn. Để giảm rung, toàn bộ mạch khuếch đại bên trong của Altair đều treo linh hoạt trên những bộ chân đế kiểu sandwich được ghép giữa 2 tấm kim loại với một lớp hợp chất polymer kẹp ở bên trong.
    Với Poweramp mono Hercules II, cảm nhận đầu tiên là quá to, quá lực lưỡng và cơ bắp đúng như tên gọi của thần sức mạnh. Ngắm nghía nó một hồi em tự hỏi: không biết Murali Murugasu, chủ tịch kiêm giám đốc điều hành Constellation có lấy trộm sữa của nàng Hera tưới vào máy hay không mà sao nó lại to đến thế? So với Hercules đời trước đặt đứng, chàng Hercules II này lại được đặt nằm ngang. Nhìn chuyên nghiệp, đẹp và tiện dụng hơn. Constellation cho biết, thiết kế mới này làm tăng hiệu xuất điện năng. Nguồn DC sạch và ổn định hơn do sử dụng tụ điện lớn hơn. Phần vỏ giống như Altair II, nó được gia công từ nhôm khối có trọng lượng lên tới 100kg một bên với hàng loạt lỗ đục tròn hai bên thành máy nhằm đảm bảo giải thoát nhiệt năng khi vận hành. Nặng, thật sự là quá nặng. Để đưa được cặp power cùng với thùng xốp của nó lên phòng nghe thật chẳng dễ dàng chút nào với 4-5 thanh niên đang ở độ tuổi bẻ gãy sừng Trâu. Theo em thấy, thủ phạm chính của trọng lượng khủng khiếp ở cặp power này chính là 2 cục biến thế đôi 3.000W cho mỗi khối mono. Constellation quá cẩn thận khi thiết kế một loạt lỗ ốc để cố định biến thế khi di chuyển. Nó làm em nhớ đến bộ ốc xiết định vị của mâm Thorens Presstige và Reference. Hai cục biến thế hình xuyến to kinh khủng này được treo chống rung và bọc chống nhiễu điện từ rất kỹ càng. Cũng theo Constellation, nhằm đạt được sự cân bằng hoàn hảo nên ngoài việc sử dụng thiết mạch balance dạng gương tương tự Altair II, mạch khuếch đại của Hercules II chỉ lấy một nửa tín hiệu (N) đầu ra của transistors thay vì lấy cả hai nửa (N và P) như các hãng khác vẫn thường làm. Em thực sự cũng không không hiểu chỗ này cho lắm. Nhưng có lẽ kiểu này trong bán dẫn cũng tương tự như cách khai thác 3 hay 5 cực ở bóng đèn điện tử 5 cực. Khi khai thác 3 cực thì chất lượng âm thanh tốt hơn 5 cực nhưng công xuất đầu ra lại nhỏ hơn. Có lẽ để giải quyết vấn đề công xuất nhưng vẫn phải đảm bảo được chất âm thuộc vào hạng tham chiếu nên Hercules II đã áp dụng phương pháp ghép nhiều module khuếch đại. Những module khuếch đại này thiết kế theo mạch single-ended với mỗi module có công suất 125W và tạo nên một mạch tổng với công suất lên tới 1.100W/8ohm, 1.500W/4omh và 2.000W/2omh. Vì cặp Kharma của em vẫn đang xài loa gốm nên em luôn tự nhủ bản thân, phải cẩn thận. Thật cẩn thận. Hết sức cẩn thận. Với công xuất khủng khiếp thế này, em nghĩ nó sẵn sàng thổi bay bất cứ cặp loa nào giống như thần Hercules chiến thắng những gã khổng lồ Gigantos. :D
    Thôi, hôm nay xin phép các bác tạm dừng tại đây, em đi nghe Altair II với Hercules II đây ạ.
    Ha Do Viet thích bài này.
  22. thaiduong
    Tham gia ngày:
    14/9/08
    1.045
    Đã được thích:
    78
    Em đã có dịp nghe cặp mono này ghép với Dynaudio Consequence LE. Do phòng nghe hơi nhỏ nên chưa phát huy hết được khả năng. Nhưng em dự là sẽ hợp với Kharma hơn là Memphisto đấy :)
  23. hiend-to-end
    Tham gia ngày:
    25/9/06
    1.121
    Đã được thích:
    16
    Nơi ở:
    HANOI
    Hera nàng hỡi, hãy bớt ít sữa tưới cho lão già Murali gì đó để dành phần tưới lên T.iu hiện đang ẩn dưới một thân hình khô rạc đã nhiều đêm trăn trở Gryphon và Colles! :D
    Hapi bithday to-you!
    (Cùng sinh tháng 3 mạng mộc như em roài! Thảo nào sống rất đa tình! :))))
  24. hiend-to-end
    Tham gia ngày:
    25/9/06
    1.121
    Đã được thích:
    16
    Nơi ở:
    HANOI
    Anh HETE cho em hỏi khoai mì tây có ngon hơn củ mì ta không , nếu có để em đổi nick thành " Củ Mì Tây " cho nó oai. :lol: [/quote]
    __________
    Em xin mạo muội tư vấn bác Củ Mì như vầy:
    Theo em bác Củ Mì nên đổi. Nhưng cũng ý kiến chủ quan của em thì bác phải có sự chấp thuận của bà xã trước, ngộ nhỡ bả nói: "xí, có vậy mà bày đặt!" :D
    (Em đùa vui nhân ngày sinh nhật đại gia tí nhé, mong bác đừng cảm phiền, ... nếu đúng! :D )
  25. quantrungyen
    Tham gia ngày:
    12/2/09
    861
    Đã được thích:
    40
    Bác C hôm nay lại có 1 sinh nhật vất vả đây, đầu tiên là xem Constellation có vật được Kharma không. Sau đó là xem có vật được Gryphon hay không. Và sau cùng là nó có vật được đôi tai khó tính của mình không nữa. Chậc...chậc...vất vả quá bác ạ
    Các file đính kèm:
Chia sẻ trang này
Đang tải...
