Tên mặt hàng:tiêu đề Tình trạng, mô tả: used, còn rất mới, không 1 vết trầy. Gắn Macbook xem đá banh, phim hết thuốc, màn to vật vã, khá nặng. Tặng thêm 1 dây Thunderbolt-usb-c chính hãng apple. Giá bán: 6.5 triệu Khu vực: hcm Điện thoại: 0908501464 Giao hàng: chỉ hcm do máy rất nặng, và nobox Ảnh chụp thực tế Thông tin thêm:
Display Type: TFT LCD* Display Size: 27-Inch Details: This is a 27-inch glossy LED-backlit TFT active-matrix LCD with IPS technology and a viewable area of 27-inches. The optimum resolution is 2560x1440. It has a 178 degree horizontal and vertical viewing angle, a "typical" brightness of 375 cd/m2, contrast ratio of 1000:1, and a 12 ms response time. Optimum Resolution: 2560x1440 Max. Display Colors: 16.7 Million Viewing Angle: 178/178* Response Time: 12 ms Details: *178 degrees horizontal, 178 degrees vertical. Brightness: 375 cd/m2 Contrast Ratio: 1000:1 Details: Brightness and contrast ratio are "typical" for this display. DPI/PPI: 109 Dot/Pixel Pitch: N/A Built-in Audio: 2.1 Built-in Camera: Face Time HD Details: Built-in 2.1 speaker system pumps 49 watts. USB: 3 ( 2.0 ) Firewire: 1 (800) Details: Three powered USB 2.0 ports, one Firewire 800 port, one Gigabit Ethernet port (hub), and one Thunderbolt port as well as a built-in Thunderbolt cable and a built-in Mag Safe cable (85W). Supported Mac OS: X 10.6. 8* Power: 250W** Details: *This display requires a Mac with a Thunderbolt port running Mac OS X 10.6. 8 "Snow Leopard" or higher. **250W (while charging a Mac Book Pro), 100V to 240V AC, 50-60 Hz. Apple Order No: MC914LL/A Apple Subfamily: Thunderbolt Display Dimensions: 19.35 x 25.7 x 8.15 Average Weight: 23.5 lbs ( 10.8 kg) Details: Height by width by depth, ( 49.1 cm x 65 cm x 20.7 cm)
