Tên mặt hàng: Loa ATC scm19 Tình trạng, mô tả: Loa đẹp như mới, hoạt động hoàn hảo, đầy đủ thùng xốp. Giá bán: 58.888.888 VNĐ Khu vực: Lĩnh Nam - HN Điện thoại: 09o2.191.166 Giao hàng: Tại nhà Ảnh chụp thực tế Thông tin thêm: SCM19 Overview New ATC designed and built 25mm soft dome HF unit with precision alloy wave guide. “SL” spec bass driver with 75mm integral soft dome. 9kg optimised short-coil/long gap motor assembly. In-house, hand-wound precision flat wire coil. Flat impedance curve allowing easy load for amplifiers. Veneered Finish Options – Cherry, Black Ash. Painted Finish Options – Satin Black, Satin White. 6 year warranty. “Superlative clarity; excellent phase coherence; sublime bass.” Hi-Fi Choice Magazine, September 2014 Specification Photography Reviews Documentation Partnering Electronics Awards Drivers: HF ATC 25mm Neodymium soft dome, Mid/LF ATC 150mm SL Matched Response: ±0.5dB Frequency Response (-6dB): 54Hz-22kHz Dispersion: ±80° Coherent Horizontal, ±10° Coherent Vertical Sensitivity: 85dB @ 1W @ 1metre Max SPL: 108dB Recommended Power Amplifier: 75 to 300 Watts Nominal Impedance: 8 Ohm Crossover Frequency: 2.5kHz Connectors: Binding Posts/4mm Plugs, bi-wire Cabinet Dimensions (HxWxD): 438 x 265 x 300mm / 17.24 x 10.43 x 11.81″ (grill adds 34mm to depth) Weight: 17.8kg
