Loa B&W DM 500
Discussion in 'Loa' started by bicd, 19/3/06.
  1. bicd
    bicd New Member
    xin các sư phụ giúp , số là anh cũa đệ mang từ mỹ về 1 cặp B&W bookseo series 500. tem sau để là loudspeakers DM 560 MADE IN ENGLAND . 1 bass 1tắc mấy đó, 1 trep . cho đệ hõi nó có hay không , đánh với amply nào nhge hay , giá trị cũa nó thế nào. xin cám ơn nhiều lắm . SO^!NG MA :oops: KHO^NG CÓ A^M NHẠC CHÁN LĂM :?: :idea:
    linhzip123 likes this.
  2. Rumbeng
    Rumbeng Advanced Member
    P.Phú Mỹ Q.7 - TP HCM
    Em chưa nghe , thôi góp vài dòng góp nhặt vậy :
    DM560
    Stand-mount/Bookshelf loudspeaker system
    Product Summary
    The two way front vented system encompasses the same design technology of the DM550
    with its rigid one-piece baffle construction, but offers a noticeable extended bass – thanks to
    a bigger 8in bass/midrange driver and increased enclosure size.
    Technical highlights
    B&W's Tweeter technology ensures that the sound remains focused and time sensitive and
    that the stereo image is presented with unparalleled three dimensional accuracy.
    The cabinets feature a specially designed high density front baffle which achieves almost
    Matrix-like stability in strengthening overall enclosure construction. The bevel edges of the front
    moulding reduce diffraction and improve dispersion.
    The crossover components use heavy gauge wire throughout and new drivers guarantee not
    only high reliability but ensure that top specifications are met.
    Drive Units 1 x 26mm high-frequency with Sensitivity 90dB spl(2.83V 1m)
    aluminium dome, 26mm coil on Nominal Impedance 8 ohms
    aluminium dome former, wound with Power Handling 10W – 75W into 8 ohms on
    polymide resin and heat cured unclipped programme
    1 x 200mm bass/midrange with Dimensions Height: 490mm Width: 236mm
    composite short fibre cone, 26mm coil Depth: 302mm
    on high temperature former, wound with Finish Black ash or walnut vinyl
    Frequency Response 65Hz – 20kHz ± 2.5dB on reference
    axis
    B&W Loudspeakers Ltd reserves the right to amend details of the specifications without notice in line with technical developments. E & OE. All trademarks acknowledged.
    http://www.bwspeakers.com
  3. bicd
    bicd New Member
    cám ơn bạn RUMBENG nhiều lắm , sao mình đánh với LUXMAN LV 430 nghe ko có hay, xin hõi các sư huynh chĩ giúp , mình nên ghép với amply nào thì ok , :!: :?: :idea: lúc trước mình có, mua 1 c on CD LUXMAN 103U , mình thích âm thanh của con này lắm ,đánh chi tiết chậm rải mà chấc chắn ,đem khuya mà nghe con này với nhạc trịnh thì mê lắm , theo nhận xét nghiệp dư cũa em thì như vậy ko biết có đúng ko . xin cá sư phụ cho em chút ý kiến , em đả bán nó rồi , bởi nó hư cơ ko chạy họt dĩa ra , rồi chúng bạn mình chê , mình nãn nên đành bán nó đi , bây giờ mình muốn kiếm lại 1 cái dẹp hơn ko biết là ỡ đâu có , giá là bao nhiêu , xin các sư phụ cho em quyền trợ giúp và hãy chọn giá đúng ... :wink: :wink: :wink:
  4. misterVu
    misterVu Advanced Member
    Bác nghe có lâu chưa mà đã thấy không hay rồi ? Thông thường loa và máy khi mới kết hợp
    nghe không hay, sau một thời gian thì tiếng mới tốt được.
  5. minhtan
    minhtan Advanced Member
    Cần Thơ, Việt Nam
    Hi Bác!
    Mình có xài cái DM 550 : 1 bass + 1 trebe.
    => cái này mình đánh với Harman 880 => nghe được nhiều thể loại nhạc : nghe hòa tấu rất hay.
    Or Bác ghép thử với Nad 302 : nghe nhạc có tíết tấu chậm rất đã : bass mềm dể nghe.
    Than
  6. tai_lech
    tai_lech Advanced Member
    B&W là âm thanh thế hệ mới bass, tre sáng còn ampli LM chỉ chơi với loa cổ thôi, các tai già bảo âm thanh LM bẩn lắm đi với loa cổ nghe nhac cổ chấp nhận tam bác ạ, em đã nghe thử LM 58 với loa tannoy rồi như kiểu mặc quần đùi với áo sơmi ý bác ạ . có điều kiện chơi accuphase, không thì Denon mới đúng chất bác ạ
  7. CADIC1008
    CADIC1008 Advanced Member
    Bác có món gì cần bán ạ?
  8. phonghidro
    phonghidro Approved Member
    Bạn ơi, bạn ghép với amply nào rồi, mình cũng có một em như thế đang định kiếm em để ghép. Thanks.
  9. Nhat Tan
    Nhat Tan Advanced Member
    Mình cũng có cặp loa này, ghép với denon nghe tiếng ù ù, có cảm giác không thoát tiếng, bass đánh không ngắn mà cứ lùng bùng. Vậy xin các bác có kinh nghiệm chỉ cho em với, nên ghép với amply nào là hợp, chảng hạn như amply Châu Âu hay amply Mỹ...xin cảm ơn các bác.
  10. thaiaudio28062012
    thaiaudio28062012 Approved Member
    con này chỉ có con Nad 7150 đánh là ra hết tiếng , bass tròn gọn dứt khoát, còn trung âm thì khỏi bàn , tuy nhiên cần kiếm cặp dây loa ngon là ổn vì ông Nad kén dây lắm
  11. bimoyong
    bimoyong New Member
    Mình thì ghép với Rotel RA-980BX. Ngon bổ rẻ.
