Tên mặt hàng: MYTEK Stereo 192-DSD DAC Tình trạng, mô tả: 8/10 Khu vực: Bình Thuận Điện thoại: 0983.670.270 Giao hàng: Ship Em bán MYTEK Stereo 192-DSD DAC - Máy rất đẹp hoạt động hoàn hảo, đầy đủ manual, box zin bị hư đã bỏ - Điên 230v Cám ơn AE đã xem tin! - Em đóng gói rất tốt bằng xốp chóng va đập AE ở xa yên tâm. —————————- Features - 32 bit ESS Sabre DAC (8 mono to 2 stereo configuration) •Native 192kHz PCM and DSDx128 conversion •Ultra-low jitter (10 pico second) internal clock generator •Internally up-sample and eliminate jitter from PCM to •192kHz/24bit prior to conversion (can be disabled)Sharp and Slow PCM Filters; 50kHz/60kHz/70kHz •DSD FiltersTransparent Analog or Digital stepped volume control •with Bypass for the purest signal pathIndependent control of Main Outs and Headphones •High Current, High Slew Rate ultra low distortion •500mA audiophile headphone ampAES/EBU, S/PDIF, Toslink, ADAT digital inputs •FireWire400, USB2.0, USB1.1 computer interface •Analog input or SDIF input •Wordclock In/Out •Apple and RC 5 remote control compatible •115/230V switchable linear power supply ———————- Inputs - USB 1.1 – Driver-less, plug-n-play computer input that islimited to 96kHz. - USB 2.0 – Hi-speed computer input that is capable of 192kHzand DSD playback. Use of this input requires driversinstalled on the computer. - FireWire – Hi-speed computer input that is capable of 192kHz and DSD playback. Use of this input requires driversinstalled on the computer. - S/PDIF – Coaxial S/PDIF input capable of receiving PCMdata up to 192kHz.AES/EBU – Professional digital input capable of receivingPCM data up to 192kHz. - Toslink – Optical S/PDIF input capable of receiving PCMdata up to 192kHz.ADAT – Optical ADAT input capable of receiving PCM dataup to 96kHz. - Signal originates from Channel 1-2 only.Analog – Unbalanced RCA analog input that can bypass thevolume control or be routed through it. Available on the Preversion only.SDIF – Professional DSD input capable of receiving DSD64xand DSD128x formats. Mastering version only.Up-samplingThe unit has the capability to up-sample all PCM data to192kHz sampling rate. This provides an analog bandwidth of100kHz. With up-sampling enabled, it will automatically up-sample PCM data. It will automatically turn off for DSD data
