Em kính chào các bác. Em mạo muội xin nhờ các bác tư vấn giúp chọn Receiver nào ghép hợp với bộ loa Harman Kardon HKTS 30BQ ạ. Em cám ơn cả nhà ạ. Thông số loa như sau: https://www.harmanaudio.com/harman-kardon/HKTS+30.html GENERAL SPECIFICATIONS: System frequency response 45Hz – 20kHz; AUDIO SPECIFICATIONS: Satellite Nominal Impedance 8 ohms nominal Frequency Response 45Hz – 20kHz (-6dB) Satellite Sensitivity 86dB @ 2.83V/1 meter Speaker Sensitivity 86dB @ 2.83V/1 meter Speaker Maximum Recommended Amplifier Power 10 ~ 120 watts Subwoofer Maximum Recommended Amplifier Power 200 watts RMS Speaker Nominal Impedance 8 ohms nominal SYSTEM SPECIFICATIONS: Satellite Maximum Recommended Amplifier Power 10 ~ 120 watts SUBWOOFER SPECIFICATIONS: Subwoofer External Trigger Input Voltage 3 ~ 30 volts AC/DC Subwoofer Input Rating AC 100–120V, 50/60 Hz, 200W or AC 220–240V, 50/60 Hz, 200W SPEAKER SPECIFICATIONS: Speaker Midrange Transducer Dual 3" (75mm) drivers, video-shielded Speaker Tweeter One 3/4" (19mm) dome, video-shielded DIMENSIONS: Satellite Width (mm) 110 Satellite Height (mm) 299 Speaker Width (in) 10-11/32 Subwoofer Weight (lb) 19.8 Satellite Weight (lb) 3.3 Subwoofer Depth (in) 10-1/2 Subwoofer Weight (kg) 9 Satellite Depth (in) 3-15/32 Subwoofer Height (mm) 353 Subwoofer Height (in) 13-29/32 Speaker Height (in) 4-11/32 Speaker Weight (kg) 1.45 Speaker Weight (lb) 3.2 Speaker Height (mm) 110 Subwoofer Depth (mm) 267 Speaker Depth (mm) 88 Speaker Width (mm) 272 Satellite Weight (kg) 1.5 Satellite Width (in) 4-11/32 Satelitte Depth (mm) 88 Speaker Depth (in) 3-15/32 Subwoofer Width (mm) 267 Satellite Height (in) 11-25/32 Subwoofer Width (in) 10-1/2 SATELLITE SPEAKER SPECIFICATIONS: Satellite Midrange Transducer Dual 3" (75mm) drivers, video-shielded
