em xin mở hàng với bộ mà em ... sắp mua: PECIFICATIONS (HF306) ARE FOR BOTH CHANNELS !! Frequency HF306: 10-80000Hz within 1dB Tubes: 2xEF86 Pre / Amp ECC82 Tone ECC81 Cathode Tracer 7121 Indication Lamp Power Cell SR250B75 Output Level 0,55 Volts (550 mV) Distortion Total distortion by 0,55 Volt Output and 1000 Hz: 0,17% Sensitivity Taperecorder (I):450 mV Radio Tuner (II): 150mV Crystal Pickup (III):65 mV Magneto-Dynamic Pickup(IV):8,5 mV Distortion Noise Level -40 dB with 0,55 Volts Output Input Impedance Taperecorder (I):3,2MOhm Radio Tuner (II):2,2 M Ohm Crystal Pickup (III):1 M Ohm Magneto-Dynamic Pickup (IV):68KOhm Output Impedance 200 Ohm Cathode Tracer Output ca.200 Ohm (Not Critical) Tone 20Hz Maximum Power for 1000Hz+14dB 1000 Hz-19 dB Tone 20000 Hz Maximum Power for 1000Hz+14dB 1000 Hz-15 dB Correction Magneto-Dynamics Input R.I.A.A Characteristics Fuse 100 mA delay by 220 Volts 200 mA delay by 127 Volts Alternating Current 220 or 127Volts-50 Hz Power Consumption ca.17 Watts Dimensions 28cm/11"(W) x 10.5cm/4.1"(H) x 24.0cm/9.4"(D). There are 4 inputswitches to make a choise for radio tuner, taperecorder and turntable with crystal- or mag- netic-dynamic pickup, whereby correction is nearby R.I.A.A characteristics. There are 4 different high- or low tone-settings. Also an output for alternate current available for the End amplifiers. Modern, nor- malized contact jacks (I.E.C) for turntables and tuner; round jack (D.I.N) for taperecorders in- and output. The amplifier has his own powersource. Hum potmeters for both channels each. The cathode tracer for the end amplifiers is not critical with 200 ohm. An output switch with 4 possibilities has build in for several mono-and stereo choises. Specifications (HF309) Mono Blocks. Frequency 10-100000Hz within 1dB 10-190000 Hz within 3dB Tubes ECC83 - Fase- and Pre/Amp EL84-(2x)Balance EZ81-Rectifier Output Level Nominal:10 Watts Max. by 1 % Distortion: 13,8 Watts Power characteristics by 1% disturbing and atleast 10 Watts Power straight ca.38 Hz-20000 Hz Distortion Total distortion at 10 Watts Power to speaker: 40Hz:0,55 % 1000Hz:0,12 % 10000Hz:0,3 % Sensitivity Input for 10 Watts to speakers: 0,55 Volts Disturbing Level Hum / Noise to 10 Watts: -80 dB Input Impedance 1 Mega-Ohm Output Impedance 7 and 14 Ohm Speakers Philips 5200M, AD 4200M, AD 4000D, 9710M Fuse 400 mA delay by 220 Volts 800 mA delay by 127 Volts Alternating Current 220 or 127 Volts Power Consumption ca.65 Watts Dimensions 12.5cm/49.2"(w) x 16.0cm/63"(h) x 20.0/78.7"(d)
Mạo muội thưa với bác ttanh một chút : mấy cái tụ đen có vòng màu đỏ vàng của cái Marants tới giờ nầy rỉ nhiều lắm đấy bác. Mấy cái tụ hóa vỏ nhôm túm một đầu có cái cũng tự khô. Muốn "ngon" thì bác thay bằng mớ Jensen và các tụ hóa Cerafine.
Khiếp quá, Bác T Anh cho đấu giá mới là xó bếp thôi nhỉ? Mới thế đã khủng nay lại show hàng, thèm quá đi mất. Hôm nào hàng của Bác từ Nam ra nhỉ? Em muốn lên tận mắt mới được.
các bác yêu đồ vintage đâu hết cả rồi? show hàng đê cho anh em thưởng lãm với à quên, em tạm định nghĩa đồ "vintage" ngắn gọn như thế này nhé: là đồ có tuổi nhiều hơn tuổi của mình (cái này trừ vợ nhé, vợ thì chắc chắn là đồ vintage rồi, kể cả ít tuổi hơn mình)
