  1. hq2578
    hq2578 Advanced Member
    Tên mặt hàng: Proceed PDP2 DAC Mark Levinson
    Tình trạng, mô tả: Máy cũ theo thời gian, còn hoạt động tốt các chức năng.
    Khu vực: Kim Mã, Hà Nội
    Điện thoại: O904O57825
    Giao hàng: TQ
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Thông tin thêm: Các bác tham khảo thêm thông tin kỹ thuật ạ:
    INNER SOUNDELECTRONIC SERVICEProceed PDP2 DAC Digital Audio ConverterMadrigal Mark Levinson PDP-2Specifications (COPIED FROM PROCEED WEBSITE/PDP3 manual) ■ Frequency response: 10 Hz - 20 kHz +0dB, -0.2dB ■ Total harmonic distortion (THD): 0.004% @ 1 kHz, 0dB ■ Dynamic range: 104dB (or better) ■ Signal-to-noise ratio: 107dB ■ Channel separation: 120dB ■ Intermodulation distortion (SMPTE IMD): 0.008% ■ Digital-to-analog conversion: Two precision 20-bit DACs ■ Filtering: 8x oversampling digital filter Analog filter, linear phase to 40 kHz ■ Low-level linearity: Deviation unmeasurable to below -70dB, approximately +1.0dB below -90dB (undithered, ref 0dB @ 1kHz) ■ Output impedance: <1Ω ■ Mains voltage: 120 V U.S. service ■ Mains frequency: 50/60 Hz ■ Power consumption: 25W @ 120V, 60 Hz ■ Shipping weight: 22 lbs/9.98 kgOverall dimensions ■ Width: 8.4 in/214 mm ■ Height: 3.4 in/87 mm ■ Depth: 15.625 in/397 mm
    Hacoi likes this.
