Rắn mới Sigma series: 3 Different Versions - SIGMA DIGITAL - SIGMA ANALOG - SIGMA HIGH-CURRENT http://shunyata.us/our-products/pwr-cab ... sigma_body
Hình như bác nhầm tí Shunyata vừa ra dòng Alpha gồm Digital, Analog và HC (High Current) và dòng Sigma. Dòng alpha chia ra 3 loại với mục đích sử dụng cho các thiết bị khác nhau. và dòng Sigma thiết kế cho thiết bị đòi hỏi dòng cực cao. Em thấy trên mạng họ đánh giá dòng mới Zitron Alpha digital cực tốt và giá cũng rất hợp lý , theo các bác trong audioshark thì các bác ấy cũng bị cắn hết cứu :mrgreen: http://audioshark.org/shunyata-research ... -2914.html http://www.shunyata.com/our-products/pwr-cables The XiTron Alpha Digital Power Cord was designed specifically to deal with the type of noise pollution that exits from the power supplies of digital type components and or switching type power supplies. Many people have now tried the cable and the reports back to us are very impressive. The XiTron circuit was originally designed to reduce dielectric absorption but we have expanded the circuits purpose and complexity to include noise reduction in the case of the power cable. If you go to our website, we have a before and after screen capture from a power analyzer showing the dramatic noise reduction capabilities of the cable. The cable does not fit into the hierarchy of our existing cable lines because it is a special purpose cable that was designed to solve a specific problem. And it fulfills that purpose quite well. If the specific component that you use the cable on fits the profile of a digital type device that outputs significant noise onto the power line - then, yes, the Alpha Digital PC will outperform one of our other cables - even the Anaconda. It works good on DACs, transports, clocks, USB converters, processors, scalars, computers, disc arrays, monitors etc. It will not outperform an Anaconda or Python on an analog component like an amplifier or preamplifier. Caelin Gabriel President Shunyata Research
Em không nhằm bác Chính xác là ΞTRON™ SERIES gồm 2 loại Alpha và Sigma, mỗi loại có 3 versions (Digital, Analog va HC) như em đã đề cập.
Em này sài cho pre phải không các bác? Em chưa rõ analog chỗ này nghĩa là gì, nhờ các bác chỉ giáo thêm ạ
vâng bác đi trước cả chính hãng. Hôm nay em đã thấy cập nhật thông tin hình ảnh trên website của hãng
Cụ Huyvu giải thích thế thì khó hiểu quá, em chả hiểu thử tìm hiểu câu trên xem có nghĩa gì, thì có vẻ là dây loại ANALOG này được sử dụng cho các thiết bị analog có sử dụng nguồn cấp điện chạy ổn định liên tục và giúp giảm độ ồn. Các cụ giỏi kỹ thuật chỉ giáo thêm giúp chúng em nhé. "A constant output voltage is required in many power supply applications, but the voltage provided by many energy sources will vary with changes in load impedance. Furthermore, when an unregulated DC power supply is the energy source, its output voltage will also vary with changing input voltage. To circumvent this, some power supplies use a linear voltage regulator to maintain the output voltage at a steady value, independent of fluctuations in input voltage and load impedance. Linear regulators can also reduce the magnitude of ripple and noise present appearing on the output voltage." (Wikipedia) HETE
Em nghĩ cái này họ viết cho rõ thôi chứ phần lớn thiết bị audio dùng nguồn linear mà. TÓm lại có 3 loại: digital: cho đồ digital front end: cdp, dac, .... analog: preamp, tuner, amp công suất thấp... HC: cho các thiết bị dùng dòng cao, công suất lớn: power amp, inter amp...
Cách giải thích của bác Jacky hợp lý và dễ hiểu, em đang ngắm em Shunyata Zitron Cobra cho Ampli McIntosh MA7000, các bác cao thủ cho lời khuyên, tks!
Các bác so sánh hộ em 2 dây này với, em định dùng cho Amp công suất: Dây Nguồn Shunyata Ztron Cobra, C15, dài 1.8m, dây tuyệt đẹp, full box, giá 16tr500vnd Dây Nguồn Shunyata Python CX, C15, dài 1.8m, dây tuyệt đẹp, full box, giá 16tr500vnd Tks cả nhà!
chào cả nhà e đang tim dây Dây Nguồn Shunyata Python CX, C15, dài 1.8m,và black mamba.bác nào nâng cấp hú e .thân
Chào các bác Em cũng vừa bị "rắn" Shunyata Python CX cắn cho một phát vào amply, cơ bản là xứng đáng. Đang đợi hồi phục công lực để cắn phát nữa vào CD. Chúc các bác sưu tầm được nhiều rắn chúa.
16 xiền bác S ạ. Hôm nào rảnh bác ghé em nghe S8 nhé. Em không mua được 300B PP nên lại giữ S8 bác ạ.
Chào bác phongph! Lâu lâu e mới vào foroom, e vấn còn và vừa đăng thông tin bên fan nordost như sau: Chào các bác fan Nordost! E cũng là fan ND được 2 năm có chơi dây sp từ blue haven đến red dawm nay là Frey ,những dây này đều mua của bác Trung shop Tran trung và bác Nam caliAudio Nay cần thanh lý bác nào có nhu cầu alo e nhé , giá chắc chắn sẽ thấp hơn mua của shop 10~15% (ngoài dây loa e còn thanh lý cả dây RCA purist và dây nguồn shuyata nữa ah.) số của e: 0975875668
Bác kdaudio còn em này ko? Chào bác Billnugen! Lâu lâu e mới vào foroom, e vấn còn và vừa đăng thông tin bên fan nordost như sau: Chào các bác fan Nordost! E cũng là fan ND được 2 năm có chơi dây sp từ blue haven đến red dawm nay là Frey ,những dây này đều mua của bác Trung shop Tran trung và bác Nam caliAudio Nay cần thanh lý bác nào có nhu cầu alo e nhé , giá chắc chắn sẽ thấp hơn mua của shop 10~15% (ngoài dây loa e còn thanh lý cả dây RCA purist và dây nguồn shuyata nữa ah.) số của e: 0975875668
Chào các bác. Em đang tính đầu tư thêm sợi Shunyata cho CD nhưng đang băn khoăn không biết nên chon loại tich hợp ( dùng cho tất cả các thiết bị) hay loại chỉ chuyên cho CD (loại có cát). Các bác chia sẻ cho em thêm tí kinh nghiệm với ? Tksc các bác.
Re: Dây Nguồn Shunyata F.C (Bị cắn một phát là hết cứu !!! Em may mắn được sở hữu một cặp rắn chúa. Con cái nhà em đang có bàu, mỗi lần đụng vào nó em thấy nó kêo. Tình cờ một hôm em thấy trong phong có thêm một con rắn nữa, nhìn đầu nó em thấy chữ Annacodra cxa. Không biết có phải là do đôi vợ chồng rắn chúa đẻ ra không. Lạ quá !!!
Chào các Bác .sau một thời gian dài tạm nghỉ audio vì lý do nhà cửa , phòng ốc . Giờ mọi chuyện đã song . Nay em muốn mua một sợi dây nguồn cho amp của em .cs amp ghi 2x500VA và tài chính em có thể từ 13>15tr mong các bác tư vấn cho mua loại nào cho phù hợp ah!vì em thấy hãng này rất nhiều loại dây.tks
Mình củng là fan của nhà rắn, mình còn dư 1 sợi anacoda vx đầu xám fullbox, 15t Anh em nào cần alo mình nhé, mình ở SG , 0903.810909, thanks
