  1. Truong27HD
    Truong27HD Advanced Member
    Hải Dương
    Tên mặt hàng: Rotel 980BX
    Tình trạng, mô tả: Hàng cũ còn sử dụng tốt
    Giá bán: 4.500.000 (đã giảm)
    Khu vực: Hải Dương
    Điện thoại: O945O22866
    Giao hàng: TQ
    Thông tin thêm: Pow đời cổ nên phần đầu chạy hẳn 03 cặp Blackgate thần thánh
    Specifications :
    Continuous Power Output.................120 watts per channel @ 8 ohms from 20-20,000Hz
    ..................with no more than 0.03% total harmonic distortion
    DIN Power Output............................220 watts per channel (1kHz, 4 ohms, 1% THD)
    Peak Current...................................80A (0.1 ohms, 10microseconds, 1 pulse)
    Bridged Power.................................360 watts(mono) @ 8 ohms from 20 to 20,000 Hz
    .................................with no more than 0.05% total harmonic distortion
    Total Harmonic Distortion..................No more than 0.03% (Continuous rated power output)
    ..................No more than 0.03% (Continuous 0.5 rated power output)
    ..................No more than 0.03% (1 watt per channel power output, 8 ohms)
    Intermodulation Distortion.................No more than 0.03% (Continuous rated power output)
    Output............................................Speaker 8 ohms nominal
    Damping Factor...............................1,000 (20 to 20,000 Hz, 8 ohms)
    Input Sensitivity/Impedance..............1.0V/33k ohms
    Frequency Response.......................4 to 100,000Hz, +0.5dB, -3.0dB
    Signal-to-Noise Ratio.......................120dB
    Power Requirement..........................120V/60Hz, 220V/50Hz, 240V/50Hz or 100V/50Hz to 60Hz
    Power Consumption.........................400 watts
    Dimensions(w x d x h)......................44 x 32.5 x 12 cm
    Weight............................................11kg
