Xin tư vấn DAC Benchmark DAC1-HDR
Discussion in 'Nguồn phát Digital' started by allyouneed, 23/11/10.
  1. allyouneed
    allyouneed Advanced Member
    Em đang tìm hiểu em DAC này, bác nào biết về em nó hoặc đang dùng qua thì cho em tý comments nhé.
    Giá sách của em nó là $1.895 - mà đô thì lại đang lên :(
    Performance Specifications:
    • Digital Input Sample Rate Range: 28 to 195 kHz
    • THD+N: -107 dB, 0.00045% (w/ -3 dBFS input)
    • SNR - A-weighted: 116 dB (w/ 0 dBFS = +20 to +29 dBu)
    • Maximum Amplitude of Jitter- Induced Sidebands
    • Maximum Amplitude of AC line related hum & noise: < -126 dB
    • Headphone amp output impedance: 0.01 Ω
    • Headphone amp output-level range (@ 0 dBFS into 60-Ω load): 21 dB
    • Headphone amp THD+N: -107 dB, 0.00045% (w/ -3 dBFS input)
    Features:
    • IR remote control with adjustable ‘Dim’ and ‘Soft-Mute’
    • High-Dynamic Range Volume Control w/ custom-built, motor-driven Alps volume pot
    • Six Stereo Inputs: Analog RCA, USB, TOSLINK optical, and three digital coaxial
    • Utilizes 24-bit, 192-kHz DAC1 D/A conversion system
    • Benchmark’s phase-accurate UltraLock™ technology provides total jitter immunity
    • AdvancedUSB™ computer audio interface for native 24-bit / 96-kHz USB audio
    • Compatible with Windows Vista/XP/2000 and Mac OS X without driver installation
    • State-of-the-art LM4562 high-current, lowdistortion opamps in critical analog circuits
    • Stereo outputs: XLR balanced, RCA unbalanced, HPA2™ headphone jacks
    • Built-in HPA2™ headphone amplifier - 0-Ohm, high-output, two output jacks
    • HPA2™ headphone amplifier hasselectable gain ranges to match headphone sensitivity
    • Left-most headphone jack mutes XLR and RCA outputs (this feature is defeatable)
    • On/Off button and rotary source selector
    • “Calibrated/Variable” switch determines gain control for main analog outputs
    • Internal trim-pots control gain of XLR and RCA outputs (in “Calibrated” mode)
    • Selectable, low-impedance attenuators (0, 10, 20, or 30 db) on XLR outputs
    http://benchmarkmedia.com/system1/di...erter/dac1-hdr
  2. Lil' Knight
    Lil' Knight Advanced Member
    HCMC
    giá này em thấy còn nhiều con đáng xài hơn. :oops:
    tiếng em DAC-1 này tùy gu người thôi chứ em thì không thích mấy, quá thiên về tiếng kiểu studio, 3 dải đều làm flat quá nên chi tiết thì rất nhiều nhưng mid thì khô khan, không ngọt ngào gì cho lắm. dải cao nhiều đoạn khá là gắt + bén nên nghe lâu có khi lại mệt tai. Thêm 1 điều nữa là em DAC-1 này qua mấy đời upgrade cũng không thêm gì đặc sắc, chỉ có giá là tăng lên liên tục.
    tầm giá này em thấy có 2 con đáng mua là Wyred 4 Sound DAC-1 http://www.wyred4sound.com/webapps/site ... upid=18157 và North Star dac32 http://www.northstar.it/english/Dac_USB32.html.
    2 em này 1 em tiếng chi tiết y như em Benchmark (Wyred) nhưng không khô khan, gắt gỏng bằng, 1 em thì ngọt ngào ấm áp (dac32).
  3. allyouneed
    Đúng là em thấy một số đ/c nước ngoài cũng nhắc đến Wyred 4 Sound DAC-1 khi so sánh với Benchmark DAC1-HDR. Ngoài ra họ còn hay đối chiếu DAC1 này với:
    - Lavry DA
    - PS Audio DL III
    Em không chắc là đã xem được hết review của họ nhưng thấy đa số nghiêng về DAC1. :mrgreen:
  4. Lil' Knight
    HCMC
    Lavry thì bây giờ đã ra DA11, con PS DLIII đó bây giờ discontinued rồi bác ơi :lol:
  5. allyouneed
    Em thấy hình như ở VN ít người chơi những dòng DAC mới hay sao ý?
    Em để ý DAC1-HDR vì cả cái volume (+ remote) của em nó (chức năng Pre). Có DAC nào tương tự như vậy ko bác nhỉ :D
  6. Lil' Knight
    HCMC
    cái Wyred DAC-2 http://www.wyred4sound.com/webapps/...view.html?pid=457975&b_id=&find_groupid=18157 có đấy bác. Wyred DAC nó có 2 version (DAC-1 và DAC-2), 1 cái không có volume, 1 cái có, tính năng y hệt con HDR nhưng công nghệ + specs thì cao hơn.
    con này nó xài con ESS Sabre 9018. em có dịp dùng qua 1 cái DAC xài con chip này, cho tới bây giờ em vẫn xem nó là DAC hay nhất em từng xài qua.
  7. allyouneed
    Cảm ơn bác Hiệp sỹ. Wyred DAC-2 này hay quá, hình thức cũng đẹp. Rổ giá thì đỡ hơn DAC1 (1500<1895) :D
    Em này ko có cổng cho headphone bác nhỉ (tức là không phải headphone amp)? Nhưng ngược lại có AES, I2S.
  8. Lil' Knight
    HCMC
    nó không có headamp bác ơi. bí quá bác có thể tự làm 1 cọng 6.3mm/3.5mm cái -> 2x RCA/XLR cắm đằng sau rồi xài volume của em này làm headamp luôn :lol:
    phần headamp của cái DAC-1 cũng không có gì đặc sắc đâu bác. tiếng mỏng lét + bass cũng không tight + deep cho lắm.
  9. allyouneed
    Hì, bác Hiệp sỹ biết nhiều thứ thế :D Tiện em hỏi luôn: đã bao giờ bác thử sử dụng cả 2 giải mã: 1 của CDP & 1 của DAC rời chưa nhỉ?
    Về lý thuyết thì em hiểu là có thể được và có thể làm chất âm hay hơn (em nói có thể vì em thấy một số CDP - trong đó có 1 số rất gấu tích hợp >2 giải mã). Tuy nhiên sử dụng cùng lúc cả giải mã của CDP & DAC rời thì em ko chắc có làm tiếng hay hơn được ko???
    Em hỏi thế cũng 1 phần vì em nhìn trong phần inputs của DAC1 có đường analog in :mrgreen:
  10. Lil' Knight
    HCMC
    ý bác là xài 2 DAC cùng 1 lúc? nếu vậy thì em chưa thử (cũng chưa thấy ai làm kiểu này). cái CDP bác nói là cái nào vậy nhỉ?
    em là bác thì 1 là đầu tư 1 cái CDP thật gấu, 2 là kiếm 1 cái CDP khá thôi làm transport, còn nhiêu đầu tư cho DAC ngoài, có thể thay đổi khẩu vị về sau.
  11. allyouneed
    Em đang dùng CA 740C bác ạ, em này dùng 2 em Wolfson WM8740 24-bit DACs. Cảm nhận của em là chi tiết nhưng hơi thiếu độ hài hòa và có vẻ thiên sáng.
    Em thấy nhiều bác nói DAC giúp cải thiện chất âm. Hơn nữa, lại cũng chơi HTPC nên mới tính nâng cấp, bổ sung DAC rời gấu 1 chút, đặng sau này chỉ việc thanh lý 740C rồi tậu CD-transport ngon là xong. :mrgreen:
    Bình thường thì khi có DAC mới, 740C sẽ trở thành transport, nhưng em lại tiếc cái DAC Wolfson của em này. Vì vậy em tham mới tính nối analog out từ 740C đưa vào analog in của DAC1 (ảnh phía trên) rồi mới qua ampli-loa (theo kiểu càng nhiều DAC chắc càng tốt :mrgreen: Em cũng chưa thấy ai làm như em, nên càng muốn thử... :lol:
  12. Thich Tum Lum
    Thich Tum Lum Advanced Member
    Thế còn Stello DA100 Signature DAC sao mấy bác ? em cũng đang quan tâm em này. Thấy ông Mark Levinson cũng chơi em này :D
  13. Thich Tum Lum
    PS DLIII vẫn còn bán trên mạng mà bác ! http://home-audio.audioadvisor.com/audio/Dac
  14. Audiothienha
    Audiothienha Shop
