Mình còn thừa vài ống Arctic Silver 5 loại 12gr..không biết có bác nào cần dùng để hỗ trợ tản nhiệt cho đồ chơi không. Bác nào quan tâm alo mình nhé 0903954496 --> Nguyên (HCM) Cảm ơn Contains 99.9% pure silver: Arctic Silver 5 uses three unique shapes and sizes of pure silver particles to maximize particle-to-particle contact area and thermal transfer. High-Density: Arctic Silver 5 contains over 88% thermally Conductive filler by weight. In addition to micronized silver, Arctic Silver 5 also contains sub-micron zinc oxide, aluminum oxide and boron nitride particles. These thermally-enhanced ceramic particles improve the compound's performance and long-term stability. Controlled Triple-Phase Viscosity: Arctic Silver 5 does not contain any silicone. The suspension fluid is a proprietary mixture of advanced polysynthetic oils that work together to provide three distinctive functional phases. As it comes from the tube, Arctic Silver 5's consistency is engineered for easy application. During the CPU's initial use, the compound thins out to enhance the filling of the microscopic valleys and ensure the best physical contact between the heatsink and the CPU core. Then the compound thickens slightly over the next 50 to 200 hours of use to its final consistency designed for long-term stability. (This should not be confused with conventional phase change pads that are pre-attached to many heatsinks. Those pads melt each time they get hot then re-solidify when they cool. The viscosity changes that Arctic Silver 5 goes through are much more subtle and ultimately much more effective.) Not Electrically Conductive: Arctic Silver 5 was formulated to conduct heat, not electricity. (While much safer than electrically conductive silver and copper greases, Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.) Absolute Stability: Arctic Silver 5 will not separate, run, migrate, or bleed. Compliancy: RoHS Compliant. http://www.arcticsilver.com/as5.htm
Hì Cài này mình thừa ra nên nhượng lại cho bác nào có nhu cầu thôi ! Giá 200K 1 ống..12gr ~ tương đương ~ 50 con CPU máy tính Nếu bán luôn thì sẽ rao trong khi phố chợ ..Mod thông cảm nhé.
Cái này ... THE BEST! Mấy ông mà thích ráp ampli bán dẫn SE như Ngũ A Lạp là phái lắm đây. Em xài cái này thường xuyên khuyết điểm của nó là độ cách điện nó không cao nên có 1 số ứng dụng không phù hợp. Nó còn 1 loại là chế tạo từ Carbon rất tốt tuy không bằng Artic Silver nhưng tốt hơn loại Silicon trắng thường dùng rất nhiều nên gần như là xài cho ứng dụng nào cũng được.
Em vẫn hay xài cái này, không biết chất lượng có khác với cái keo trong ống kia không, nhưng trọng lượng khoảng 1Kg nếu tính ra chắc cũng thoa được hơn 3000 con CPU, nếu bác nào có nhu cầu không nhiều thì chạy qua em múc về xài đỡ.
Nó đích thị là silicone đó bác, em thấy tụi Sony nó xài nên nghĩ mình DIY mà dùng silicone này thì có chất lượng tốt cỡ Sony là được rồi.... quan trọng nhất là miễn phí.
Mấy loại keo bác nói bây giờ không ai dùng nữa đâu, vì mất vệ sinh quá. Bây giờ người ta dùng tấm lót silicon có tẩm hợp chất dẫn nhiệt, cách điện tốt, chức năng lấp chổ trống để linh kiện tiếp xúc tốt với tấm giải nhiệt thì tấm lót silicon này good, CPU trong computer bây giờ cũng dùng loại tương tự như vậy đó bác . Còn cái vụ cách điện là do tấm lót chịu trách nhiệm chứ không do mỡ silicon này đâu
Về vấn đề vệ sinh và dễ dàng cho sx thì bác Ti phán đúng. Nhưng nói về thuần túy về tính truyền nhiệt thì cái Artic Silver này hơn hẳn mấy cái mỡi Silicone và tấm lót Silicone. Cái này em chắc chắn 100%. Dzê em xài đủ loại cho từng ứng dụng. Nếu cho giản tiện và yêu cầu không cần thiết thì tấm lót là ổn. Nhưng trong 1 số ứng dụng đặc biệt thì Artic silver hay 1 vài loại tương đương mới đạt yêu cầu. Một vài loại tấm lót loại tốt hơn không dùng Silicone mà dùng chất liệu khác và giá tiền cũng cao hơn. Đồng thời cái Artic Silver mắc hơn vài chục lần cái mỡ Silicone vì thế có muốn xài cũng phải hỏi cấp trên có duyệt hay không
Em hay dùng cái tuýp như xilanh baby ý, nhưng em thấy nó là mỡ đặc màu đồng, tên là Stars-612 heatsink compounds . các thông số em đọc đc là : Thermal conductivity: > 1.829Ư/m-k Thermal resistance : < 0.123 0c-in2/W 20% metal oxide compuond ... Em muốn hỏi cái chất trên dùng bôi sò +IC có cách điện tốt và truyền nhiệt tốt cỡ nào ạ ? Vì em thấy mấy Overclocker hay mua để OC nên em cũng mua về bôi thử cho CPU thấy rất tốt . Giá thì có 10k/ tuyp 1gram thôi . Nó dài hơn cái lọ này các bác ạ :
