Chào các bác Sau khi xem Tây làm R2R DAC và ngồi càphe với mấy tay hay nghịch nhạc số.. chúng em lên lịch đặt hàng mua chung R2R DAc về lắp thử xem thế nào DIYAUDIO topic thảo luận: http://www.diyaudio.com/forums/vendors- ... 4-khz.html Lịch dự kiến ( updated) - Thời gian gom đơn hàng mua chung 11-5/3/2017 - Hàng có tại Đan mạch: 14/3 - Hàng về đến Việt nam khoảng 25/3/2017 - Phí ship hàng: chia đều Thông tin thêm Giá mua bản Soekris ApS dam1021-12 - REV 4 Standard Configuration: 0.01/0.02% resistor version Buy 1 for $290.00 each Buy 2 for $281.00 each Buy 5 for $272.00 each Buy 20 for $263.00 each Website : http://soekris.com/products/audio-products/dam1021.html Soekris ApS dam1021-12 - REV 4 The dam1021 is a DAC module based on a discrete R-2R sign magnitude DAC design, with FPGA based FIFO buffering/reclocking and custom digital filters, < 1 ps jitter clock generator, with 28 bit resolution so there is headroom, oversampling up to 3.072 Mhz. Up to 24 bit / 384 Khz input from SPDIF, I2S and USB (via USB to I2S interface board), with isolation on the I2S interface. The board is very flexible, with digital volume control and filter parameters that can be downloaded. The board is fully firmware upgradable over a simple serial connection, which enables new features later on. For now we plan to add digital crossover filters soon. The basis R-2R network has an output voltage of 1.4V RMS and output impedance of 625 ohm and can therefore drive a lot of things directly. There is also onboard balanced output drivers that can drive high impedance (>= 300 ohm) headphones directly. The power supply is also onboard, just add a 5W+ toroid transformer. Xem thêm: The Soekris R-2R DAC: Technical Details: https://hifiduino.wordpress.com/2015/01 ... -r-2r-dac/ Soekris dam 1021 R-2R DAC ILLUSTRATED GUIDE: https://hifiduino.wordpress.com/2015/03 ... ers-guide/ Bác nào máu thì đăng gấp ... Elegant, LiemDoan, PhanTran, Syen+++.... Danh sách đặt mua chung: 1. Syen++ 2. Scorpio 3. Mu 4. Goldenriver99 - đã chuyển TU 7triệu 5. Phan tran - đã chuyển TU 7triệu 6. Cafe 7. Planet 8. Elegant 9. Vancao 10. PGC2003 11. BachDuong 12.Thelinh 13. mrb26 14. liemdoanhn 15. tritridung - đã chuyển TU 7triệu 16. TQT 17. UyDo 18. Pointed 19. tranchung15 20. Dat_haui - đã chuyển TU 7triệu 21. chilathuvui 22. cutom - đã chuyển TU 7triệu 23. AND-Record.vn 24.Limk -đã chuyển TU 7triệu 25. Phan tran2 - đã chuyển TU 7triệu 26. listening2009 - đã chuyển TU 7triệu 27. -------------------- Với đơn hàng trên 20 chiếc chúng ta sẽ có giá USD 263... giảm giá trực tiếp còn USD245 Các bác chuyển tạm ứng 7 triệu Tài khoản : Vietcombank 0021000550773 Nguyen Duy Duc Ghi rõ giúp em " tennick_R2RDAC" .. ví dụ: Pointed_R2RDAC
Thấy Tây nó bảo là Input - Input SPDIF Up to 24 bit / 192 Khz - Input PCM I2S: Up to 24 bit / 384 Khz - Input DSD I2S: Up to DoP128 and DSD256 Output - SE 1.4V RMS, - Bal 2.8V RMS - Zout 640R
bác ở hcm hay hn, lúa gạo đặt ntn vậy bác? nghe tây bảo tiếng con này trung tính chắc cũng dễ phối đồ
Em ở HN ... lúa gạo ( tiền hàng+ shiping dự kiến) thì gom đủ trước ngày 25.2.. Thanh toán bằng thẻ tín dụng với bên bán hàng Hàng về chia tiền ship, thuế.. thực tế.. thừa trả lại, thiếu thu thêm
Hay quá. E cũng ham nhưng đang nghiên cứu thêm xem con này diy được cái gì không? Phần nguồn và phần output nếu không dùng những thứ có sẵn của nó thì có lựa chọn nào? Con này về sau có tích hợp được EQ để làm room correction không nhỉ?
Con này có thể nối với máy tính thông qua cổng serial để nạp filter Mod https://hifiduino.wordpress.com/2015/07 ... ding-vref/ https://hifiduino.wordpress.com/2015/02 ... -dac-mods/ https://hifiduino.wordpress.com/2015/06 ... more-mods/ DSP: filter: http://www.moredamfilters.info/ http://www.diyaudio.com/forums/digital- ... s-r2r.html https://hifiduino.wordpress.com/2015/04 ... -r-2r-dac/ http://www.dimdim.gr/tag/dac/ Manual : http://www.soekris.dk/download/dam1021/ ... 151005.pdf
1. Syen++ 2. Scorpio 3. Mu 4. Goldenriver99 5. PhanTran Bác Plannet đăng ký luôn đi, về nghĩ sau cũng được. Ít nhất là DIY được cái vỏ
Ông nào đầu trò thì chịu trách nhiệm nhé, từ A -Z http://www.head-fi.org/t/822033/vinshin ... -w-soekris
Em đú đởn theo cụ Xì cọp với cụ Xiên hê hê. 1. Syen++ 2. Scorpio 3. Mu 4. Goldenriver99 5. Phan tran 6. Cafe 7. Planets 8. Elegant + vỏ :lol:
Không có vỏ đâu ... lên siêu thị AV lô làm lô case taobao về cho nhanh (giống vụ B5 Active crossover) Túm được mấy côm cán ngon rồi PhanTran : IT là nghề của chàng .. nạp. sửa filter với lại lập trình lại code Planet: phân tích mạch, mốt mát Syen++: chuyên gia về điện 220V nguồn AC với lại relay Elegant: cổ động viên hay lưu trữ độc dược bảng A ... Có mấy thứ này cần bàn thêm để 15/3 là chạy được Phần nguồn nuôi - Nếu cấp AC cần biến áp 220V=> 7-8VAC - Nếu cấp DC: cần bo nắn sang +-7 -+-15VDC ( thấy Tây hay dùng cái bo LT3042 của Diyinhk) Phần input - USB giao tiếp có thể dùng XMOS hoặc Amanero .. sau đó đấu I2S sang - Cụ nào dùng với đầu CD chỉ cần đường Coxial thì bỏ qua phần USB Đầu phát transport : - PC hoặc MAC -Raspbery Pi / BBB /Odroid
Muốn mua đủ món thì đăng ký thế nào các bác ? Thế khi có đủ đồ lắp vào có phải cài đặt gì nữa không,các bác cho hỏi xxx chút nữa nhé,tks ?
Tết đi lễ được cô thương 1. Syen++ 2. Scorpio 3. Mu 4. Goldenriver99 5. Phan tran 6. Cafe 7. Planets 8. Elegant + vỏ 9. Vancao
Theo em hiểu thì hiện giờ mua chung bo mạch thôi. Cái này không cần diy nhiều đâu. Cần thêm cái biến áp nguồn, vỏ và các loại jack vào ra. Nếu dùng cổng usb thì có thể phải thêm module usb. Cái này em chưa đọc kỹ.
