àh quên mất còn trị số linh kiện nữa chứ R1-15-16-21-22-17-18=1K R33=68R 5W Q1-2=BC550C R2=47K R35-36=6R8 1W Q3-4=BC560C R3-4=10M TR1=1K trimmer Q5=BC560C R5-6-13-14=1K2 TR2=1M trimmer Q6=BC550C R7-12=47R C1=2.2uF 63-100V MKT Q7-11=BD140 R8-9-10-11=22R C2=1nF 100V MKT Q8-9-10=BD139 R19=82R C3-4=2.7nF 100V MKT Q12=IRF9540 R20=22K C5=330pF ceramic or mylar Q13=IRF540 R23-26=56R C6-7=100uF 16V F1-2=Fuse 2.5A Fast R24=2K2 C8=1uF 100V MKT L1=see text [2] R25=560R C9-11-12=100nF 100V MKT J1= 2pin connector 2.54mm step R27-30=150R C10-13=470uF 63V R28-29-31-34=15R C14=33nF 100V MKT Q8-10-11-12-13 on Heatsink R32=150R 5W D1-2=LED RED 3mm [see text] [1] All the resistors is 1/4W 1% except quote differently
Thêm 1 chú class A của Nelson Pass đây 40W nóng khủng khiếp R1=10ohm R19-20 =0.68ohm /5W 5% T1-2=MPSL01 R2-16 =2.2Kohm R21 =10ohm /1W 5% T3=2N5248 - J204 - BF245C R3-9= 10Kohm C1=330 pF 100V 5% T4-5=MPSL01 R4-6 =330ohm C2-4=220 uF 16V T6=MPSL01 R5-11-12 =470ohm C3=39 pF 100V 5% T7=MPSL51 R7=680ohm C5-6=100nF 100V T8-9=PMD16K100 Lambda 2N6284 RCA R8-13= 100ohm C8-9=100nF 100V R10= 4.7Kohm C7-10=220 uF 63V T10-11=PMD17K100 Lambda 2N6287 RCA R14-15=68ohm D1-2-3=1N4148 R17-18 =0.68ohm / 5W 5% TR1=1k2 Trimmer ALL Resistors is 1% metal film
thêm 1 chú MOSFET cực kỳ simple. chú này mà oánh BTL cho SUBWOOFER cho home cinema thì khỏi phải chê PARTLIST C1 = 2,2 µF MKP, MKT 100 V C2 = 330 pF céramique 50 V C3 = 100 nF MKP, MKT 100 V C4 = 100 µF 40 V électro-chimique C5, C6 = 18 pF céramique 50 V C7 = 100 nF MKP, MKT 250 V R1, R3 = 47 K R2 = 2K2 R4, R5 = 3K9 R6 = 1 K R7 = 27 K R8, R9, R11 = 100 ohms R10 = 10 K R12, R13 = 470 ohms R14, R15 = 0.33 ohms 5 watts R16 = 10 ohms 3 watts T1, T2 = 2N5401, ZTX558, BC556B (attention au brochage différent - take care for pin layout) T3, T4 = BF470, MJE350, 2SB649 T5, T6 = BF469, MJE340, 2SD669 T7 = IRFP240, 2SK1530, 2SJ162, BUZ900DP, BUZ901DP (attention au brochage différent - take care for pin layout : GDS GSD) T8 = IRFP9240, 2SJ201, 2SK1058, BUZ905DP, BUZ906DP (attention au brochage différent - take care for pin layout : GDS GSD) P1 = 2K5 multitours (25 tours - 25 turns) F1, F2 = 3 A T
bác nào có nhu cầu diy mấy cái amplitren thì lên tiếng nhé. tí sẽ làm hộ cái pcb để các bác làm cho dễ. bác nào có cái shecma nào hay hay thì post ủng hộ tí nhé.
Ai máu chơi solid state classA, hãy cùng vào đây! A người quen đây rồi! Sản phẩm DIY class A của bạn bao giờ trình làng đây? Có cái hình nào chưa?
Em nữa nè, em khoái nhất là Class A của Passlab. Đã làm một cái Son Of Zen, tiếng nghe rất khá, chạy rất nóng, chưa làm được cái Pre. Không biết là cái hình chụp lúc trước đâu mất, chỉ còn cái hình nhỏ để làm Avatar thôi Rgds,
Bạn SOZ ráng chụp hình và post lên cho anh em làm thuốc kích thích mà làm với !!! Nếu mà hăng hái có khi Mod nào chuyển topic này sang DIY Solid là tha hồ mà phê ha !
Khổ quá, cái hình cũ không thấy đâu, còn cái hình nhỏ như sau thôi, để mai lấy máy ảnh về chụp và gửi lên khoe mới được
em đang định làm một cái sub , bác tívoi làm giúp em cái PCB nhé ! nói chung là mạch càng dễ làm càng tốt ! mà mấy cái trên sao bác ko gửi hình phần nguồn ? 8O
Trông cái mạch ta nhớ đến ngày xưa khi nhìn vào cái ampli của Nhật ,và thán phục Cái máy tính lật úp của bạn tí là Casio loại fraction đúng không ? Cái monitor hiệu Robo là cũng mới đây vậy là máy mạnh Vậy bác sử dụng phần mềm vẽ mạch in là Orcad hay Protel vậy ? Kính bác một ly
toàn đồ cổ thôi bác ơi. cái máy tính này là bạn lớp 9 tặng. cách dây 6 năm cái máy tính mua vào thời hoàng kim của PIII slot 1 cách dây 6 năm cái mạch cũng cổ nốt cách đây 3 năm hồi đó tí vẽ PCB = tay vời eagle đấy
cái này khó nói. vì khi làm ko có tính toán. nếu không kể phần nguồn thì hết tầm 500k cho 2 bo công suất. 8 chú sò là hết 200k rồi. nếu ko tải loa 4ohm thì dùng 2 con cho 1 kênh công suất thôi
Sub woofer amplifier bác có thể dùng cái mạch thứ 2 ấy. cái ấy là vô địch cho sub rồi nhưng ko biết bác có thùng loa sub chưa? với lại bác dùng loa sub ấy cho hệ thồng setereo hay hệ thống X.1 nếu dùng cho hệ thống X.1 thì chì cần ampli thôi còn nếu ko có line out của sub thì ta cần 1 mạch lọc như hình dưới (tí lấy từ ESP nói chung là hoạt động tốt) Phase Controller Schematic Nguồn cho Pow nguồn này cho ổn thì thêm mạch loc RLC cho cả cuộn thứ cấp và cuộn sơ cấp luôn ko biết bác định làm sub như thế nào đây nói rõ tí thì tivoi mới hỗ trợ được cho bác chứ
Bác Tívoi chơi hay quá ! cho em tham gia với ?? Em muốn làm một dự án mạch classA giống như của bác 40W/kênh Bác ở HN, hay SG nhỉ , PM cho em cái số điện thoại được không ? Emcamr ơn bác trước nhé ! :lol:
Chào mừng bác đến với topic của tí. class A thì nhiều con bố đỉnh lắm. bác thích âm thanh hoành tráng thì oánh BTL con class A đó thì sẽ được 80oát có điều chơi Class A thì tốn nguồn và tụ ko kể tiền điện. Tí thì ở sì gòn, không khí nóng bức quanh năm cái class a có vẻ ko phù hợp. bác ở hà nội tiết đông chí mà có con class sưởi ấm thì khoái phải biết nhể. Nhân đây tí post shecma mấy con class A bố đỉnh của Nelson Pass chỉ có shecma thôi chưa có PCB tí chưa có điều kiện để làm nó nhưng nhân đây phong trào được ủng hộ của bà con cô bác chắc là sẽ lên tinh thần mà chiến đấu với nó đây ALEPH-X ALEPH-2 ALEPH 3 ALEPH 4 ALEPH 5 ALEPH - M ALEPH - X
bác định xin cái gì? bác Gamar có sẵn luôn cái PCB con TDA7294 mà. bác Gamar còn làm PCB roi share mà có vấn đề gì đâu???
định lọ mọ làm một em sub giá rẻ để có bài gửi VNAV cho nó xôm tụ ! xài 1 loa 2 tấc nhốt vào một cái thùng khoảng 40cm mỗi bề ( có thể to hơn !)! sub này để xem phim , nên ý định là sẽ all in box ! giá cả cố gắng sao cho không vượt 600k ! tức là 300k cho mạch và 300k cho loa và thùng ! :mrgreen: nếu như giá mạch trên hơn 300k thì em sẽ lại sử dụng TDA 7294 vậy !
bác thử chơi với sloide sate xem sao. cái mạch thứ 2 làm giỏi lắm hết 270k thôi tất tần tật. 100k cho nguồn, 70 cho sò, 100 cho linh kiện. bác thấy thế nào. Tí vẫn ko biết bác có cổng ra của sub chưa ấy nhể hay là bác là mạch woofer filter từ 2 kenh stereo vậy
