AE mình không lập hội Music Laptop
Discussion in 'Nguồn phát từ máy tính' started by DVD-A, 20/9/09.
  1. phuongthu
    phuongthu Advanced Member
    Sai Gon
    đúng Bác có bọn khoai tây nó nói thế này muốn lên 24/96 thì lên 32/192 xong xuống lại 24/96, Em chả hiểu thí nào nửa....Em đang làm theo cách này thấy hiệu quả tốt nhưng lâu quá...kệ túc tắc làm hoài cũng được, chất lượng 1 album nâng cao lên cũng xứng đáng công...Em đọc thấy giải thuật Upsampling phần cứng và phần mềm cũng tựa như nhau, có cái soft Weiss-Saracon quá tốt nhưng chưa có bản full hay crack soft này đắt quá...
    I do the stepped upsampling using izotope rx advanced. Its as good as wave editor and it is pc compatible.By stepped I mean I do the upsampling in steps. First I rip the file to flac and let jriver find it so it has all its associated data and picture with it. Then I use dbpoweramp music converter to change it into a wave file and save it to folder 1 on my desktop. I then use izotope with batch processing to dither folder 1 to 24 bit and save it to folder 2 on desktop. I use medium noise shaping and normal dither amount. I then use batch processing again to upsample folder 2 to 96000 and save it to folder three on desktop. I use 32 filter with 1 cutoff shift and 1 preringing settings. i then take folder 3 and use dbpoweramp music converter to convert it back to flac and save it back to the original folder now as a 24/96 flac file. When I open up jriver again it automatically finds the 24/96 songs and puts them in with the 16/44 songs. The associated data and picture automatically jumps to the new files so I dont have to input anything.(tags or picture) Then I erase the contents of folder 1,2,3 and the original 16/44 files. I find the music is smoother but it has better detail. The whole process takes about 1-2 hour per cd. Its really not that bad to do once you get the hang of it.
  2. tranguyen
    tranguyen Advanced Member
    Sài Gòn
    http://cplay.sourceforge.net/pmwiki.php?n=CMP.02Upsampling
    Ở đây có nói về 3 kỹ thuật nội suy dùng để upsampling là linear, ladder and sinc interpolation, em đọc mà không hiểu sâu lắm. Tác giả kết luận kỹ thuật sinc intepolation cho kết quả tốt nhất. Và DAC hoặc chương trình có khả năng up lên các số không chẵn 44.1Khz lên 96Khz hoặc 192Khz (chứ không phải 44.1Khz chỉ lên được 88.2Khz hoặc 176.4Khz thôi) là DAC/chương trình tốt vì đối với các DAC/chương trình này, người thiết kế đã để ý và giải quyết phần không chẵn chứ không phải chỉ nhân đôi hoặc nhân 4 cho gọn.
    Em đọc đâu đó thấy ở các phòng thu Studio, người ta thường thu ở độ phân giải cao 192Khz hoặc 384Khz rồi sau đó downsampling xuống 44.1Khz để ghi CD thì sẽ cho chất lượng tốt hơn là thu trực tiếp ở 44.1Khz và ghi ra CD.
  3. mmvmm
    mmvmm Approved Member
    Bác Cynep ơi. Con Tera-link của bác ra sao rồi?
  4. Супер
    Супер Advanced Member
    Антарктида
    Sau khi mod thêm một chút thì tiếng nó rấ khá,rất xứng đáng với khoản đầu tư của em.Nhưng nó đấu ko lại với konnekt live nên tạm thời bị cất tủ :mrgreen:
  5. phuongthu
    Sai Gon
    Em khoái cụ Super này cái gì hay nói hay dở nói dở à hé...Em cũng đang tìm thêm con konnekt live về nghe thử mà tìm hoài chưa thấy... Em lục Ebay toàn konnekt 8, konnekt 24,konnekt 32...
    Bác cho Em hỏi con konnekt 8 nó có bằng con konnekt live không ???? Đợi tìm lâu quá hỏng có konnekt live Em lượm con konnekt 8 được không ???
  6. Супер
    Антарктида
    Nghe nhạc thì như nhau nhưng mà nếu không kiếm được Live mà kẹt tiền thì cụ kiếm 24D xài đỡ,tính năng gần tương đương với con Live.Giá dưới 300 đồng thôi.Nếu kinh tế dư dả thì múc ngay con 48,con này nhìu kênh hơn,lại có cả điều khiển tha hồ nghịch.Tất nhiên là giá nó gấp đôi con 24D rồi.Con Live của em em rình vài tháng mới chộp được đó cụ.Phần mềm của nó cũng cho chỉnh nhiều thứ lắm,nghịch lâu là tẩu à nhe.
    Em có Live rồi thì lại cứ ngắm 48.Thật là tội lỗi :mrgreen:
  7. tranguyen
    Sài Gòn
    Nghe hấp dẫn quá, em tìm được IZotope RX và dbPowerAmp về làm thử theo như anh này. Kết quả em không thấy mượt hơn nhưng chi tiết hơn như tác giả đề cập. Có vẻ DAC của em upsampling tất cả lên 192/24 nên đưa file tín hiệu từ 44.1/16 lên 96/24 không thấy tác dụng hoặc tai của em không thấy hay hơn.
    Vả lại em nghĩ trước khi ghi ra CD, ở phòng thu Studio đã có các chuyên viên mix đã sử dụng những phần mềm tương tự để cho ra âm thanh tốt nhất và trung thực nhất rồi, nếu tiếp dùng dùng các phần mềm để chỉnh sửa thì âm thanh có thể hay hơn nhưng sẽ kém trung thực hơn. Chương trình IZotope RX dùng tốt nhất là để phục hồi các bản thu kém
  8. phuongthu
    Sai Gon
    IZotope RX làm cho bản thu rất chi tiết, sửa noise rất tốt , còn Up lên Em thấy dùng dbPowerAmp cái này tiếng ấm hơn dày hơn....Bác có thử Up lên hẳn 192 đưa vào DAC lúc này DAC nó không Up nửa so sánh Up bằng soft và Up bằng DAC thì cái nào hay hơn chưa ?
  9. tranguyen
    Sài Gòn
    Em có thử lên 192/24 như lời bác nhưng đối với em dùng phần mềm upsampling không hơn vì:
    1. DAC của em dùng AD1895 Asynchronous Sample Rate Converter mục đích chính để giảm jititer (jitter attenuation), nâng cao chất lượng âm chỉ là mục đích phụ. Nếu upsample bằng phần mềm và đưa vào DAC dùng by-pass mod thì sẽ hạn chế việc jitter attenuation ==> chất lượng âm bị kém hơn. (Em chưa có Off-ramp + superclock để làm việc này :D )
    2. Em thường nghe nhạc bằng cPlay - cPlay chỉ chạy với ASIO thôi chứ không chạy với các driver của Windows. ASIO trong máy em chỉ support sample rate đến 48Khz thôi.
    3. Nếu dùng Foobar có thể đưa vào DAC các tín hiệu có sample rate 192/24 qua driver USB Audio Output nhưng chất âm có vẻ kém hơn đưa file 44.1/16 qua ASIO output và để DAC upsample lên 192/24.
  10. mmvmm
    Em không định Up bằng soft. Khi thử Up sample bằng DAC em thấy như sau: Nguồn 16bit/44khz Up lên 192 chỉ thấy dở hơn, chưa nhận thấy cái hay của nó ở đâu, âm thanh rời rạc, vô hồn... Từ nguồn 24/96khz chuyển lên 192khz không khác nhau là mấy. Nguồn 24/96khz em đang transport bằng con HD media player, các bác khỏi phải nói thêm, đương nhiên là không ổn rồi. :D
  11. phuongthu
    Sai Gon
    Cái này chắc tùy từng cấu hình :
    - 1/Em nếu dùng XXHighend/Foobar file 16/44.1 khi dùng plugins SRC upsample lên 24/96 ra Dac upsample lên 1 lần nửa 24/192 : âm thanh rất chi tiết và đều, Bass không dày.
    - 2/ Em dùng file 24/96 converter và Upsample trước, rồi dùng XXHighend/Foobar và vẫn dùng plugins SRC qua Dac upsample lên 1 lần nửa 24/192 : âm thanh chi tiết , Mid và Bass dày tròn và ấm hơn.
    * Em thấy dùng plugins SRC Up lên không rồi ra DAC thôi thì âm thanh nghe không bằng mình converter và Upsample lên từ 16/44.1 lên 24/96 bằng soft trước...
  12. phuongthu
    Sai Gon
    Ở đây có cái link so sánh dBpoweramp và EAC. Bác ơi muốn dùng Accurarip trong dBpoweramp phải làm thế nào ???
    http://www.audiocircle.com/index.php?PH ... ic=68223.0
    Các Bác dùng Apple Mac có thử dùng Amarra giá chương trình phát nhạc này tới 1500$ không biết phần mềm mà đắt thế ?
  13. tranguyen
    Sài Gòn
    Link này nói dbPowerAmp tốt hơn EAC.
    Để bật chức năng AccurateRip, click vào nút Options và đánh dấu chéo vào ô AccurateRip (Hình như chức năng mặc nhiên on)
    Theo em hiểu thì AccurateRip là chương trình (plug-in AccurateRip.dll) kiểm tra dữ liệu của dĩa rip (disk ID & checksum gì đó) và so với các dữ liệu trong dababase đã có trên freedb. Nếu dữ liệu của 2 nguồn giống nhau thì mình có thể tự tin là rip của mình là Accurate. Dữ liệu của mình sau khi rip sẽ gửi vể đưa vào database của freedb để những người rip sau tham khảo. Để dùng AccurateRip phải có internet connect và dĩa của mình đã có người Rip và đưa vào database của freedb rồi.
  14. phuongthu
    Sai Gon
    Em thấy cái phần mềm dbPowerAm Rip này khá hay cái chức năng AccuraRip khi bật lên nó so sánh với phần dử liệu trên mạng và tìm thông tin cũng như đánh giá bài nhạc bao nhiêu sao, tự động download hình album bỏ vào thư mục của mình... Bác cho Em hỏi là có nên khai gì trong phần DSP , Encoder... Em đang để As source hết khi Rip, chất lượng bản Rip rất tốt.... Bọn khoai tây nó cầu kỳ và kỷ quá nó bảo khi Rip nên có CD External và dây USB loại tốt không nên dùng CD trong máy để giảm rung giảm Jitter khi đọc ....
  15. tranguyen
    Sài Gòn
    Chức năng AccurateRip thì EAC cũng có - download file AccurarteRip.dll bỏ vào thư mục của chương trình Exact Audio Copy là dùng được. Em dùng dbPowerAmp thì em bật Secure Mode chứ không dùng Burst Mode (Burst Mode rip nhanh hơn nhưng không sửa lỗi).
    Phần download Album art, artist...vv đánh giá bao nhiêu sao là của chức năng Perfect Meta. Chức năng này cho dùng thử miễn phí trong 1 tháng đầu, sau 30 ngày thì bác phải đăng ký $5/tháng mới dùng được.
    Em không dùng DSP vì em nghĩ là file rip phải gần bản gốc nhất có thể. Các DSP có thể sử dụng trong khi play back (Foobar) nếu muốn.
    Em nghĩ không phải tụi nó cầu kỳ đâu. Vì ổ đĩa Rip cũng phải đạt điều kiện nào đó, ví dụ em đang dùng ổ dĩa của laptop Dell E6400 thi ổ này không có C2 Support nên không dùng được chức năng "C2 Error Pointer for Error Detection" hay không hỗ trợ FUA (Em cũng chưa biết những chức năng này làm gì ?). Bác vào thử Options, chọn Secure Rip hay Defective by Design và test thử ổ đĩa của bác xem có hỗ trợ C2 hay FUA không ?
  16. phuongthu
    Sai Gon
    Các Bác nào mà nhiều CD/SACD/DVD... ngại Rip mất công phiền phứt này nọ... mua đại cái Ripping CDs In Style GD3 này về Rip, đúng là Music Laptop phát triển thì họ nghĩ ra đủ thứ cái để phục vụ dân chơi lowend laptop muzic luôn chán...
    Mấy Bác download đoạn film xem chơi cái Robot này nó phục vụ các Bác lười Rip....
    Chứ 1 ngày chủ nhật rảnh Em dùng External CD và dùng dbPowerAmp rồi bất tất cả các chế độ AccurarteRip,Secure Mode,Perfect Meta lên để Rip cho nguồn tốt nhất...Rip khoản 20-25 Album nó kiểm tra lâu quá xá, gặp phải mấy CD để lâu hơi củ là chờ mòn mỏi luôn hic...
    http://video.computeraudiophile.com/200 ... per001.mov
  17. tranguyen
    Sài Gòn
    Thấy cái hộp đĩa chắc mỗi lần rip được 200 CD. Bác nào có khoảng 10.000 CD rip chỉ cần 1 tháng là xong :D
  18. phicanh
    phicanh Advanced Member
    Bác nào có cái Cplay bản 1.4 thì cho em xin với, AMD của em chạy bản này là ngon nhất
  19. ClassA
    ClassA Moderator
    Bác trannguyen hướng dẫn cụ thể thêm về cái exchange skin được không ạ? Không hiểu sao cái foobar của em không đọc được nhiều file cue, thế mới chán.
  20. phuongthu
    Sai Gon
    Bác đọc link này tiếng ziệt gỏ gàng zể hiểu...
    http://www.diendantinhoc.vn/showthread.php?t=17195
  21. tranguyen
    Sài Gòn
    Sorry em type nhầm, skin em đang dùng là Xchange Version 3.0.1 với foobar 0.9.6.9. Skin Xchange version mới 3.5.2 có ở đây, em chưa thử http://vnav.vn/forum/posting.php?mode=reply&f=7&t=31185
    Em nghĩ là do file cue bị lỗi, bác phải sửa lại tý xíu là được. Hình như khi rip và tạo file cue bằng EAC, EAC rip sang file .wav rồi tạo file .cue sau đó mới chuyển .wav sang .flac hoặc .ape nên file .cue vẫn chỉ vào tập tin bài hát .wav. Bác thử xem file nhạc của mình dạng gì rồi đổi tên tập tin trong file cue tương ứng.
    Ví dụ của em trong file cue download
    Foobar báo lỗi vì file nhạc trong đĩa cứng là "Shania Twain - Up! (Green Disc) (CD2)\02 - I'm Gonna Getcha Good!.flac" ==> sửa nội dung file cue từ .wav thành .flac thì OK.
  22. phuongthu
    Sai Gon
    Các Bác có nhạc share với Em kiếm ít Album về nghe 3 ngày xuân, khỏi tốn xiền đi mua, Em Rip được 368 nhạc Ngoại và 308 nhạc Việt. Các Bác xem hình có cái nào trùng không ? Xong Em cho mấy cái CD lên đường khỏi phải bảo quản để lâu mốc hư đọc khó...XXhighEnd quản lý kho nhạc tốt quá dể lựa chọn rất thuận tiện và nghe khá hay.
  23. Aries
    Aries Advanced Member
    VNAV
    Bác Phuongthu cho em hỏi là có chương trình nào play nhạc định dạng FLAC mà mình có thể play online hoặc nhúng vào website không ?
    Thanks
  24. phuongthu
    Sai Gon
    Em chưa thử cái vụ chơi online hay nhúng Bác để Em thử tìm xem..
  25. Aries
    VNAV
    Chơi online file wav thì em thấy có nhiều, nhưng file to quá nên up/down load đều không tiện.
    Nếu có giải pháp cho file FLAC thì rất hay: chất lượng tương đương wav, kích thước file chỉ khoảng 1/2
