1/ Audio - Technica LP-120USB : Type 3-speed, fully manual operation Motor DC motor Drive Method Direct Drive Direct drive Speeds 33-1/3 RPM, 45 RPM, 78 RPM Pitch Variation +/-10% or +/-20% Turntable Platter Die-cast aluminum Starting Torque >1.6 kgf-cm Braking System Electronic brake Wow and Flutter <0.2% WRMS (33 RPM) Signal-to-Noise Ratio >50 dB Output Level Pre-amp "PHONO": 2.5 mV nominal at 1 kHz, 5 cm/sec Pre-amp "LINE": 150 mV nominal at 1 kHz, 5 cm/sec Phono Pre-Amp Gain 36 dB nominal, RIAA equalized USB Function A/D, D/A - 16 bit 44.1 kHz or 48 kHz USB selectable; Computer interface - USB 1.1 Compliant Windows XP, Vista or MAC OSX Power Supply Requirements 115/230V AC, 60/50 Hz Power Consumption 11W Dimensions 450.0 mm (17.72") W x 352.0 mm (13.86") D x 157.0 mm (6.1") H Weight 10.7 kg (23.5 lbs.) Phụ kiện bao gồm Headshell/cartridge; AC line cord; dual RCA (female) to 3.5 mm (1/8") mini-plug (male) stereo adapter cable; dual RCA (female) to 3.5 mm (1/8") mini-plug (female) stereo adapter cable; 45 RPM adapter; USB cable; recording software. Giá : 11.250.000 Đ 2/ Audio-Technica LP1240USB : Type 3-speed, fully manual operation Motor 16-pole, 3-phase, brushless DC motor Drive Method Direct Drive Direct drive Speeds 33-1/3 RPM, 45 RPM, 78 RPM Turntable Platter 332 mm dia. die-cast aluminum Starting Torque >4.5 kgf.cm Braking System Electronic brake Wow and Flutter < 0.1% WRMS (JIS WTD) with 33 RPM Signal-to-Noise Ratio > 55 dB (DIN-B) Output Level Pre-amp "PHONO": 2.5 mV nominal at 1 kHz, 5 cm/sec (HP-4005) Pre-amp "LINE": 150 mV nominal at 1 kHz, 5 cm/sec (HP-4005) USB Function A/D, D/A - 16 bit 44.1 kHz or 48 kHz USB selectable; Computer interface - USB 1.1 Compliant Windows XP or above or MAC OSX or above Power Supply Requirements 120V AC, 60 Hz Power Consumption 13W Dimensions 450.0 mm (17.72") W x 353.0 mm (13.90") D x 166.5 mm (6.56") H Weight 12.5 kg (27.6 lbs.) Phụ kiện Slip mat; dust cover; platter; 45 RPM adapter; counterweight; headshell; power cord; USB cable; dual RCA (female) to 1/8" (3.5 mm) mini-plug (male) stereo adapter cable; dual RCA (female) to 1/8" (3.5 mm) mini-plug (female) stereo adapter cable; dual RCA (male) cable with integrated ground wire; stylus target light; Audacity software (CD) RIAA: 20-20kHz, +1/-3dB (In: 1.5mV 1kHz) Tone arm type: Static balanced S-shaped tone arm with detachable headshell Effective arm length: 230 mm Overhang: 15 mm Height of tone arm adjustment range: 0-6 mm Tracking error angle: Less than 3 degrees Applicable cartridge weight: Without headshell 3.5 - 8.5 g, With headshell 13 - 18 g Anti-skating range: 0-3 g Giá : 15.800.000 VND 3/ Audio-Technica LP5 : Type: 2-Speed, fully manual operation Motor: DC motor Drive method: Direct drive Speeds: 33-1/3 RPM, 45 RPM Turntable platter: Die-cast aluminium Starting torque: >1.6 kgf.cm Braking system: Electronic brake Wow and flutter: < 0.2% WRMS (33 RPM) Signal-to-noise ratio: > 50 dB Output Levels: “PHONO” (Pre-amp bypassed) - 4 mV nominal at 1 kHz, 5 cm/sec “LINE” (Pre-amp engaged) - 150 mV nominal at 1 kHz, 5 cm/sec Phono Pre-amp gain: 36 dB nominal, RIAA equalized USB function: A/D, D/A - 16 bit 44.1 kHz or 48 kHz USB selectable Computer interface: USB 1.1 (or higher) compliant Windows XP, Vista or MAC OS X TONEARM SPECIFICATIONS Type: Static balance shaped tonearm Effective Length: 247mm Typical Overhang: 17mm Maximum tracking error angle: Less than 2.5° curve Stylus pressure adjustment range: 0 to 2.5 g Applicable cartridge weight range (including headshell): 15 to 20 g GENERAL SPECIFICATIONS Power supply requirements: 230V AC, 50 Hz Power consumption: 6W Dimensions: 450.0 mm (17.72”) W x 352.0 mm (13.86”) D x 157.0 mm (6.1”) H Weight: 10.5kg Accessories included: AT95EX Dual Moving Magnet stereo cartridge with replaceable stylus; Exclusive AT-HS10 Lightweight Headshell; AC line cord; dual RCA (male) to dual RCA (male) stereo cable; 45 RPM adapter; USB cable; recording software CARTRIDGE AND HEADSHELL SPECIFICATIONS Cartridge Model: AT95EX Cartridge Type: VM Design Stereo Dual Moving Magnet Recommended load impedance: 47,000 ohms (when using external PHONO preamp) Output voltage: 4 mV (at 1 kHz, 5 cm/sec) Stylus Elliptical: 0,3 x 0,7 mil Tracking force range: 1.5 to 2.5 g (standard 2 g) Cartridge weight: (AT95Ex) 5.7 g Headshell model: AT-HS10 Headshell weight: 10g Headshell overhang adjustment: ± 5 mm AUDACITY General Specifications: PC or Mac with an available USB port (USB 1.1 or higher) Mac running OS X 10.4 or later or PC running Windows (Vista and above) Installation: CD-R or CD-RW writer for burning CDs & software installation. Includes Audacity software for PC & Mac users Giá : 16.900.000 VND Tất cả model trên được Nhập khẩu phân phối bởi Audio Trương Lê và bán tại các cửa hàng Audio trên toàn quốc
Re: Audio-Technica trình làng 3 model đầu đĩa than "ngon, bổ Hôm triển lãm em thấy bày, tiếc rằng phòng đông quá nên không nghe thử được. Mâm này sản xuất ở đâu Bác chủ ơi
Re: Audio-Technica trình làng 3 model đầu đĩa than "ngon, bổ Ở Hà Nội bác ghé Long Audio ở Phố Hai BÀ Trưng. Hà Nội Ở Đà Nẵng ghé showroom Trương Lê Audio 280 Hùng Vương. Đà Nẵng Ở Sài gòn, mời bác ghé 185 Lý Thường Kiệt. Q11 để nghe thử ạh
Re: Audio-Technica trình làng 3 model đầu đĩa than "ngon, bổ Thương hiệu Nhật Bản, linh kiện Nhật BẢn, vỏ hộp lắp ráp tại Nhà máy Audio-Technica tại China
Re: Audio-Technica trình làng 3 model đầu đĩa than "ngon, bổ shop bác có con naim muso khônng vậy? nếu có bác cho em giá vài inbox nhé. cám ơn bác.
Re: Audio-Technica trình làng 3 model đầu đĩa than "ngon, bổ Sản xuất tại Đài Loan bác ạ. Chất âm cũng mộc mạc, ấm áp nói chung so với các đầu đĩa than giá khoảng 30tr đổ lại thì em thấy nó ko có đối thủ. Hay trong tầm tiền, mức giá rất bổ cho bác nào đam mê đĩa than. Nhược điểm là đĩa than thì tốn hơn đĩa cd, lại pải mua thêm máy rửa đĩa nữa. Một số hình ảnh thực tế vừa khui thùng của mấy em đĩa than ạ: Audio-Technica LP1240USB: Audio-Technica LP5 :
Re: Audio-Technica trình làng 3 model đầu đĩa than "ngon, bổ Em Audio - Technica LP-120USB hình thức giống hệt Technics SL1200MK2...
