Audioprofessor 2A3 SE Power Amplifier
Discussion in 'Amplifiers' started by haiken, 20/3/18.
  1. haiken
    haiken Advanced Member
    Quan 3, TP Ho Chi Minh
    Tên mặt hàng: Audio Professor 2A3 SE Power Amplifier
    Tình trạng, mô tả: Còn rất mới 98%
    Giá bán: 42 triệu đồng
    Khu vực: HCM
    Điện thoại: O9O3 627475
    Giao hàng: TQ
    Thông tin thêm: âm ly 2A3 single end do kỹ sư Nhật đại tài Morikawa thiết kế
    Ảnh chụp thực tế:
    View attachment 299813 6CDF6804-E57D-4EAA-B13C-7FE43754B1EF.jpeg CD9548AD-5509-4CC6-8829-C6715E3EEA36.jpeg
  2. haiken
    Biến áp xuất âm Tango Hitara XE-20S
  3. haiken
    Biến áp nguồn, choke, choke load đều do Audio Professor đặt riêng hãng Tango sản xuất
    tamnguyencong likes this.
  4. tamnguyencong
    tamnguyencong Advanced Member
    Con này công suất bao nhiêu bác.
  5. haiken
    Công suất em nó 3.5W thôi Bác, nhưng chất âm mới quan trọng. 3.5W thôi nhưng bass rất sâu và tiếng treb thì cực hay
  6. haiken
    Đối tác tốt cho loa Fullrange .......
  7. haiken
    You are looking at special made tube amplifier using Hirata Tango XE-20S and PX-4 tube. It was built by Morikawa (森川) master and was introduced in MJ magazine in 90s year. .
    Morikawa is Japanese master in tube amplifier research, he is author of many famous tube amplifier book, this amplifier was introduced in one of his best seller of serial book named "Audio tube amplifier". Amplifier use all Hirata TANGO transformer, output transformer is XE-20S, which use orient cutting core, same as X series transforme. Block condenser is Audio Professional which is order made from ELNA Cerafine, choke and grid choke, power transformer was Audio Professor Inc, which is special ordered made from Hirata Tango. Another parts are high quality and selected one as you can see in pictures. With XE-20S output transformer you can easily change tube to 300B, as well as PX25, DA30 with some modification. Output speaker terminal are 8,16ohm. Out put power is about 4-5W, 2A3 is working in class A. In this circus, 2A3 was driven by grid choke, which is working same as interstage transformer. It make the sound deeper and wider. It also protect your tube. The prestage is SRPP circus which used 6Z-DH3A tube. This tube is nearly same 76 tube, the outlooking is quite same.
  8. haiken
    1C512C6C-4C24-4A3B-BF94-63829CD2B531.jpeg AD5C54D3-7D04-4A4C-8F14-0CF55EC4883B.jpeg DA251A4E-CB8D-464A-81F1-CE3799AA1E26.jpeg 3BFC9323-FC0C-454F-B312-917D8D4B744A.jpeg 41A98966-D256-4A35-ABDD-61F69FE0016F.jpeg
  9. haiken
    Đã bán, cám ơn em trai nhanh nhẹn
  10. anhtraichipheo
    anhtraichipheo Approved Member
    Ho Chi Minh
    Thanks anh, ampli về nghe rất ngọt ngào ạ
