Bác nào chơi em TEAC này rùi cho em xin ý kiến với!
Discussion in 'Thiết bị khuếch đại' started by bwm, 1/5/13.
  1. bwm
    bwm Advanced Member
    TEAC A-H01
    Compact High-Performance/High-Output Amplifier
    The amplifier circuitry uses the 50ASX2 by Bang & Olufsen ICEpower of Denmark. High efficiency conversion allows compact dimensions despite high-output (60W + 60W) – power comparable to full-size amplifiers. Energy efficient design minimizes power consumption (34W) compared to the approximately 85W consumed by conventional products (45W + 45W).
    Expandability and Input/Output Connector Options Belying it's Compact Dimensions
    Despite its compact dimensions, the A-H01 offers the full range of connection outputs a listener would except of an amplifier designed for use in PC-based audio setups, including two digital inputs (one coaxial and one optical) and two analog inputs, in addition to a USB port (for connecting to a PC). The speaker connections are large binding post accommodating cables up to AWG8. The speaker connectors also support BANANA plugs and a subwoofer pre-out terminal.
    A headphone jack lets users enjoy audio late at night, in spaces with neighbors close by or other situations where speaker playback might disturb others.
    Built-in Burr-Brown PCM5102 DAC for a High Performance and a Broad Range of Digital Audio Sources
    The A-H01 uses a Burr-Brown PCM5102 DAC. After installing the appropriate driver, listeners simply connect a Windows or Mac computer via a USB cable to ensure a digital signal path all the way to the DAC, transforming the iTunes or other media players into high quality audio devices. The A-H01's specifications will satisfy even the most fastidious of audiophiles, including support for audio sources of up to 24bit/192kHz and asynchronous USB.
    High-Performance Components that Measure up to Full-Size Amplifiers
    A-H01 incorporates a motor-driven volume knob and an aluminum front panel. Other components, including the large binding post speaker terminals and 3-pin power socket, are the same size as those found on full-size amplifiers. These design decisions ensure ease of use and secure connections, they also suggest the no-compromise approach taken in designing this compact audio unit.
    Fan-Less Design for Refined Quietness
    Efforts to eliminate signal noise for high-quality audio playback mean nothing with a noisy amplifier fan. To achieve the dual goals of high performance and compact dimensions – two parameters that conflict with efficient heat dissipation – circuit design and chassis design emphasized the selection and effective placement of potential heat-generating components to allow this high-performance compact amplifier to operate without cooling fans.
  2. Men_piano
    Men_piano Approved Member
    Bác muốn nghe ý kiến gì hả bác, giá rẻ là mua k để trưng bày cũng quá đẹp.
  3. hanoi1234
    hanoi1234 Advanced Member
    chắc bác chủ không biết mua nó để làm
    gì. nếu là em mua về ghép loa bôk seo để ở phòng ngủ nghe nhạc không lời là ổn luôn. mấy chú âm li kểu này chắc là làm ở china hết. nói chung là dòng nhìn hay hơn nghe nhi?
  4. longxp
    longxp Approved Member
    Hàng lắp ráp China xuất cho thị trường Japan. Tuy nhiên có thể chuyển qua điện 220V. Chỉ tính riêng bo icepower 50asx2 đã đủ tiền... chất lượng thì xứng đáng tầm tiền.
