Tên mặt hàng:ASW 610 Tình trạng, mô tả: như mới vì đem ra thử 1 lần rồi cất vô lại, đầy đủ phụ kiện và hộp Giá bán: Đã Bán Khu vực: 209/73 tôn thất thuyết, phường 3, quận 4, tphcm Điện thoại: 0903.09.79.11 Giao hàng: Mình không hỗ trợ giao hàng Ảnh chụp thực tế Thông tin thêm: Crossover Tuning Mushrooms Description Active closed-box subwoofer system Drive unit ø250mm (10 in) paper/Kevlar® cone long-throw Frequency range -6dB at 20Hz and 25/140Hz adjustable (EQ at A) Frequency response ±3dB 27Hz – 40/140Hz adjustable (EQ at A) Bass Extension -6dB at 20Hz (position A) -6dB at 25Hz (position B) -6dB at 30Hz (position C) Power output: 200W Rated power consumption: 40W / 0.5W standby Input impedance: 33kΩ Signal / noise: >90dB Functions: Input level (line in) Input level (speaker in) Low-pass filter bypass Bass extension Bass roll-off alignment Auto sense on/standby Phase switch Inputs: Line In (RCA Phono) Speaker in (Binding post) 12v trigger (3.5mm jack) Low-pass filter Active 4th-order, variable cut-off frequency Dimensions Height: 310mm (12.2 in) not including feet Width: 310mm (12.2 in) Depth: 375mm (14.8 in) including grille and controls Net weight 12.5kg (27.6 lb) Finishes Matte Black
