Bán Linn Sneaky Music DS phục các bác chơi nhạc số
Discussion in 'Digital - Computer' started by ducmdc, 11/1/19.
  1. ducmdc
    ducmdc Advanced Member
    Hà Đông - Hà Nội
    Specs
    • Dimensions (H) 44.5 mm x (W) 345 mm x (D) 274 mm
    (H) 1.8 inches x (W) 13.6 inches x (D) 10.8 inches
    (can be positioned horizontally or vertically)
    • Weight 2.7 kg / 6 lb
    • Mains supply voltage 100 – 120 V ac (±10%) 50 – 60 Hz
    (auto ranging) 200 – 240 V ac (±10%) 50 – 60 Hz
    • Fuse 250 V, T1.6 A (not user replaceable)
    • Power consumption
    standby 10 W
    operational 14 W
    maximum continuous 120 W
    •Supported file types FLAC, ALAC, WAV, MP3, WMA (except lossless), AIFF,
    AAC, OGG
    • Audio sample rates 7.35 k, 8 k, 11.025 k, 12 k, 14.7 k, 16 k, 22.05 k, 24
    k, 29.4 k, 32 k, 44.1 k, 48 k, 88.2 k, 96 k, 176.4 k, 192 k
    • Word depths 16 – 24 bits
    • Ethernet interface 100Base-T RJ45
    • Control protocol Compatible with UPnP™ media servers,
    UPnP™ AV 1.0 control points
    • Local control
    RS232 x 2 RJ11
    Remote controllable (handset not supplied)
    • Connector types
    optical digital output TOSLINK
    coaxial digital output RCA phono
    line outputs RCA phono
    speaker outputs Inverted safety 4 mm BFA sockets
    • Output impedance
    line outputs 300 Ω
    speaker outputs 0.06 Ω
    • Output voltage
    line outputs 2.8 V peak, 2 V rms (0 dBFS)
    speaker outputs 15 V peak, 10 V rms (0 dBFS, 16.6 dB gain, vol. 79)
    • Output offset
    line outputs < 2 mV
    speaker outputs < 3 mV
    • Signal to noise ratio
    Line outputs Better than -120 dB
    Channel balance Better than +/- 0.2 dB
    • Channel separation
    line outputs better than -120 dB
    Speaker outputs better than -100 dB
    • Gain range -80 dB to +20 dB
    • Gain resolution 1 dB
    • Unity gain volume 0 dB = volume 80
    • Dynamic range 120 dB
    • Damping factor 67
    • Signal level for clipping 415 mV rms (0 dBFS, +16.6 dB gain, vol. 79)
    • Harmonic distortion < 0.03% at 1 kHz at 10 W
    • Load tolerance Unconditionally stable into all loudspeaker
    loads
    • Frequency response
    pre-amp 2.5 Hz – 170 kHz (-3 dB)
    power amp 2.5 Hz – 48 kHz (-3 dB)
    • Speaker output voltage 15 V peak
    • Speaker output power 20 W
  2. ducmdc
    Hà Đông - Hà Nội
    Lên..........................................!
  3. ducmdc
    Hà Đông - Hà Nội
  4. ducmdc
    Hà Đông - Hà Nội
    Chơi nhạc qua trang web trả tiền Tidal rất hay, qua Nas cũng hay.
  5. ducmdc
    Hà Đông - Hà Nội
  6. tinhdhmo
    tinhdhmo Advanced Member
    Hàng ngon mà ít bác quan tâm nhỉ ? Phụ bác chủ tý
  7. ducmdc
    Hà Đông - Hà Nội
    Thank Bác. Nhiều bác chuyển sang nhạc số mà ít bác chú ý đến Linn là người tiên phong trong su hướng nhạc số.
    tinhdhmo likes this.
  8. ducmdc
    Hà Đông - Hà Nội
  9. ducmdc
    Hà Đông - Hà Nội
    Hàng đã bán. Thank bác đẹp trai, hiểu về Linn đã ủng hộ.
  10. thanh447
    thanh447 Approved Member
    bác chủ cho hỏi xíu con này chơi loa gì thì hay nhất, chơi nhạc đa thể loại.
