Bán Switch for audio và Macbook air 219
Discussion in 'Digital - Computer' started by casperhn, 27/6/22.
  1. casperhn
    casperhn Advanced Member
    Tên mặt hàng:
    1. Switch Motu 5 port có hỗ trợ AVB cho chất lượng truyền dữ liệu tốt hơn. Một số thử nghiệm so sánh của anh em đánh giá sân khấu rộng, độ động tốt.
    Hàng new open box, chưa sử dụng. Giá 8t5
    What is AVB (Audio Video Bridging)
    AVB (Audio Video Bridging) is an extension to the Ethernet standard designed to provide guaranteed quality of service, which simply means that audio samples will reach their destinations on time. AVB allows you to create a single network for audio, video, using an AVB-compatible switch.
    AVB offers several features that make it ideal for the home studio:
    1. A single lightweight CAT5e or CAT6 cable can be run up to 1328 feet. This makes it easy to have audio I/O located in different rooms and run multichannel audio between them in real time.
    2. Low, predictable latency. AVB latency is 2 ms (or less) when sending an audio stream over up to seven “hops” (trips through switches or other devices) on a 100 Mbps network.
    3. Scalable, with high channel counts. AVB’s bandwidth is sufficient to carry up to 512 real-time channels using a single Ethernet cable. This offers the future possibility of expanding your system with additional devices that contain different kinds of audio I/O, multiple controllers, and other useful functions.
    4. Integrated clock signal. In a digital audio system with multiple devices, having a master clock is critical to maintaining audio fidelity. The AVB specification defines such a clock to be accurately distributed to all devices in the system.
    2. Macbook air 2019.
    Cấu hình Core i5, ram 8G, ssd nvme 256, sạc 125 lần. Máy đẹp hoạt động hoàn hảo.
    Giá: 15t2
    Liện hệ: Trung 097.25.58.899
    Xã Đàn - Đống Đa - Hà Nội
    Quang61 likes this.
  2. Quang61
    Quang61 Advanced Member
    Một con Switch đáng để trải nghiệm. Có cảm giác dòng chảy âm nhạc dễ dàng hẳn lên
  3. fanslandthu
    fanslandthu Advanced Member
    Em cũng được 1 bác tư vấn và đang sử dụng e này. Quá tuyệt. Up phụ bác chủ.
    Quang61 likes this.
  4. Tran Chau Tuan
    Tran Chau Tuan Approved Member
    em bán buffalo GS2016 huyền thoại 6 củ để chơi thử con switch bác chủ. ai có nhu cầu sms e 0938272000
  5. casperhn
    E ủn lên cho các ae ủng hộ
  6. Tran Chau Tuan
    Em cần mua motu bác nào xả báo e
