Tên mặt hàng: Bộ pre-amplifier WAVAC PR-T1 Tình trạng, mô tả: Type: vacuum tube stereo preamplifier Frequency Response: 20Hz to 100kHz (-0dB) Inputs: three single ended (RCA) and two balanced (XLR) or four single ended (RCA) and one balanced (XLR) Other custom combinations available Outputs: single ended (RCA) and balanced (XLR) Other custom combinations available Main Chassis: carved from 70mm solid block of aircraft aluminum Power Supply & Power Transformer: constructed using thick 10mm plates for rigidity and sonics Dimension: 380 x 390 x 86 (WxDxH in mm) main unit only Weight: 69 lbs (all 3 chassis) Giá bán: 195 triệu Khu vực: Q.Bình Tân, TP.HCM Điện thoại: 0938 56 66 78 Giao hàng: TQ Ảnh chụp thực tế Thông tin thêm:
