Type Integrated amplifier Rated output (20Hz~20kHz and both ch operation, THD 0.03%) 6Ω: 90W+90W 8Ω: 80W+80W Dynamic power 4Ω: 175W+175W 8Ω: 105W+105W All the harmonic distortion factors (CD, 8Ω and 80W) 20Hz~20kHz: 0.03% 1kHz: 0.002% Frequency characteristic (overall (Line→Speaker)) 5Hz~80kHz +0 -3dB SN ratio Phono MM: 80dB (EIAJ) 87dB (input short circuit) Phono MC: 74dB (EIAJ) 68dB (input short circuit) DAT, CD, Tuner, AUX and Tape Play: 80dB (EIAJ) 102dB (input short circuit) Input sensitivity/impedance (at the time of rated output) Phono MM: 2.5mV/47kΩ Phono MC: 200μV/100Ω DAT, CD, Tuner, AUX and Tape Play: 200mV/47kΩ Phono maximum permissible input (Phono→Tape Rec, 1kHz and THD 0.03%) MM: 120mV MC: 10mV Output level/impedance Tape Rec (Pin): 200mV/1kΩ Power supply voltage AC100V and 50Hz/60Hz Power source electrical outlet Total: 200W Power source switch gearing: 3 systems Rated electric power consumption (documentation which is based on electric supplies control law) 200W Maximum external size Width 440× height 147× depth 402.5mm Weight 11.6kg Remark Attachment: Remote control hoặc bác vào đây tham khảo: http://www11.plala.or.jp/teikakakucosme ... 5040r.html
đúng nó rồi cảm ơn 2 bác nhé @ kanemottohoshi @ thanh_tam các bác biết giá con này là bao nhiêu không ước chừng thôi
