Em đang tính mua Usher S520 để kết nối với Denon PMA 655R integrated amplifier. Về phần nguồn phát tín hiệu em muốn dùng laptop (Macbook Pro 13" nên chỉ có USB 2.0). Em đang cân nhắc xem có nên mua E-MU 0202 USB interface sound card không vì em cũng không hiểu rõ lắm về cái sound card này. Thông tin của nó đầy đủ đây ạ: USB 2.0 Audio Interface E-MU's new 0202 USB 2.0 Audio Interface is the ultimate portable USB audio interface for PC, offering pristine 24-bit/192kHz recording and playback, direct monitoring and a host of professional features in a compact, USB bus-powered package. The 0202 USB sets a new standard in portable USB audio, providing users with two Class-A preamps that can be run independently or in stereo to amplify guitars, keyboards or microphones, with individual ground lift switches for optimal audio performance. The E-MU 0202 USB 2.0 features: Premium 24-bit/192kHz A/D and D/A converters* (A/D: 113dB SNR, D/A: 112dB SNR) deliver unmatched USB audio fidelity - gold-plated connectors for pristine audio quality Ultra-low noise Mic/Hi-Z/Line preamplifiers with ground lift switches enable you to plug microphones, keyboards and guitars straight into your computer with professional results (XLR, 1/4" TRS, and 1/8" 5V condenser mic input) Ultra-low latency USB 2.0 drivers offer accurate timing and playback of your recorded audio and software instruments Hardware zero-latency direct monitoring (mono/stereo) allows you to record and overdub with no annoying delay Plug-and-play operation with hands-on control of all major functions like direct monitoring level, headphone level, preamplifier gain and more Compatibility with most popular audio/sequencer applications - (Windows XP/x64: ASIO2 and WDM; Macintosh OS X: Apple CoreAudio) I/O Configuration: Class-A Ultra-low Noise Mic/Hi-Z/Line Preamp XLR, 1/4" TRS and 1/8"* Inputs (113dB SNR) Class-A Hi-Z/Line Preamp 1/4" Input (113dB SNR) Two 1/4" Outputs (112dB SNR) 1/8" Stereo Speaker Output (112dB SNR) Stereo Headphone Output (108dB SNR) Ảnh của em nó đây ạ: Vậy liệu em này có thể kết nối với amp Denon kia của em không? (thông qua cái Outputs L R đó). Xin các bác chỉ giáo cho em. Em chân thành cảm ơn. PS: Mặc dù vậy, trên Mac em này chỉ cho ra tín hiệu Analog tối đa là 96kHz (chắc em sẽ cài thêm Windows 7)
Vậy là sẽ kết nối thế này phải không hả bác? Laptop USB --> EMU 0202 USB --> L R outputs của EMU 0202 --> một trong các Inputs của Denon Amp (CD, DVD/AUX v.v). Liệu cái jack từ L R outputs của EMU 0202 có cắm vừa với cái Inputs của Denon Amp không bác nhỉ vì em chỉ biết cái outputs của EMU dùng 1/4" ,còn của Denon là 1/4" hay là 1/8" nữa? Cảm ơn bác nhiều.
EMU0202 có có đường ra là Jack 6.35mm tín hiệu balance và jack 3.5mm ra tín hiệu single-end. Cả 2 ngõ này đều có jack chuyển đổi để cdduwwocjw vào amp có ngõ vào single-end RCA
