các bác thấy cái này thế nào..?
Discussion in 'Dành cho thành viên mới' started by pduong1977, 7/1/07.
  1. pduong1977
    pduong1977 Advanced Member
    BAN DAN MINI STEREO DENON D-XS11. (Lượt xem: 153)
    Du dung nen can ban mot dan MINI CD/MD DENON model D-XS11. Hinh thuc dep, am thanh hay, phu hop cho dung trong phong xxx. Cong suat 20W/Ch, Trong luong 8.,2Kg, su dung so FET, 2 Bien the nguon. Gia Ban 800,000vnd. (Khong bao gom loa)
    Cam on vi da xem tin
    Thong so tham khao : http://www.minidisc.org/translations/Denon_D-XW33.htm
    Specification of D-XS11-s
    Amplifier
    Practical, maximum output 20W+20W(6Ω、EIAJ)
    Input terminal AUX/PC×1、CDR/TAPE(PB)×1
    Output terminal Headphone and PRE OUT ((*suupah'uuhah*))× 1
    CDR/TAPE(REC) ×1 and speaker (one system) agreement impedance 6-16Ω
    Timer
    Timer form One operation a day (ON/OFF timer)
    (*suriiputaimah*) 10-90 minutes
    Tuner
    Reception frequency band region FM:76.0~108.0MHz、AM:522~1629kHz
    CD player
    Reproduction method Non-contact optics (semiconductor laser use)
    Sampling rate 44.1kHz
    Number of channels Two channels and stereos
    Frequency characteristic 20Hz~20kHz
    MD recorder
    Recording method Magnetic field modulation overwrite method
    Voice compression extension method ATRAC/ATRAC324bit operation method
    *** <power> others
    Power supply AC100V (50/60Hz sharing)
    Consumption electric power 48W standby:3W(At ECO mode ON).
    The maximum and externals sizes W170×H249×D380mm
    Mass About 8.2kg
    Speaker
    Form (*basuref*) type
    Use speaker 1 and (*tsiitah*) × (*uuhah*) × 1 2cm12cm
    Input impedance 6Ω
    The maximum input 50W
    The maximum and externals sizes W150×H249×D247mm
    Mass About 2.9kg (1)
  2. kanehoshi
    kanehoshi Advanced Member
    OSAKA-HO CHI MINH
    bác muốn bán hay muốn mua? mà bác không bỏ dấu tiếng việt em đọc mệt muốn xỉu.
  3. pduong1977
    dạ em thấy rao bán nên em định hỏi xem cái này ghép với loa bookself mini nghe có được không ? hơi thiếu công suất không biết có sao không,,>?
  4. Lion_Heart
    Lion_Heart Advanced Member
    Theo em : không nên!
  5. pduong1977
    ..xin bac vui lòng giai thích rõ hơn 1 chút đươc không ạ, em không rành về kỹ thật lắm, em thấy ghép như vậy d8ược cái rất gọn nhẹ, còn chất âm không biết thế nào..?
  6. pduong1977
