[Cần mua] Cần mua Vac avatar Super
Discussion in 'Cần mua' started by thangkv, 7/12/22.
  1. thangkv
    thangkv Advanced Member
    Cần mua:Vac
    Tình trạng:Mới đẹp
    Khoảng giá:123456
    Khu vực:HN
    Điện thoại:0909056168
    Em cần mua âm ly Vac Avatar Super
  2. Minh thoi
    Minh thoi Advanced Member
    Ba Đình - Hà Nội
    thangkv likes this.
  3. thangkv
  4. Minh thoi
    Ba Đình - Hà Nội
    Em thấy hãng bảo được đấy:
    "OPERATING VOLTAGE
    The Avatar Super may be set to run from 100, 120, 220, or 240 volt ac power sources. If your local voltage is between these, select the one just higher than your local voltage. For example, if your power is at 230 volts, set Avatar Super for 240 volts, not 220 volts. Voltage isset bymeans of the voltage configuration card, located behind the main fuse. The setting is indicated by the number which is visible on the installed card.
    THE FUSE MUST MATCH THAT SPECIFIED FOR YOUR LOCAL POWER !"
    thangkv likes this.
  5. thangkv
    Em đã mail hãng hỏi cho chắc. Hihi
    Minh thoi likes this.
