CD Player từ $3000 trở lên!!!
Discussion in 'Nguồn phát Digital' started by altecta7, 25/11/06.
  1. altecta7
    altecta7 Advanced Member
    Hải phòng
    Em xin mạn phép các Bác đưa ra cái topic này, xin giới thiệu vài CD player mà em đang hâm mộ.
    Đầu tiên là em CARY CD 303/300
    Transport 3 Beam CD/DVD ROM drive
    Frequency Response 2 Hz - 22 kHz (44.1 kHz)
    Signal-to-Noise Ratio 127 dB (1 kHz)
    THD 0.004% (1 kHz)
    Channel Separation 109 dB (1 kHz)
    Power Consumption 60 Watts (15 standby)
    Digital/Analog Converters (DAC) (2) Burr Brown PCM1792u 24 bit DAC chip sets
    Sample Rate Settings 44.1, 96, 192, 384, 512 or 768 kHz sample rates for CD, CD-R or CD-RW disk playback to the analog output, digital output Fs of 44.1, 96 or 192 kHz
    Audio Output Level Single-Ended 3.0 Vrms
    Balanced XLR 6.0 Vrms
    Analog Outputs (1) pair balanced via XLR connectors
    (1) pair single-ended via RCA connectors
    Features 48 bit DSP digital buffer circuit, bubble level balance on the chassis top panel, adjustable metal cone feet, variable analog volume control, vacuum tube and solid state output sections with remote selection or front panel button, dimmer light control for display, C-core power transformer, fully regulated power supplies, RS 232 port control for custom installation systems, chassis top removable panel above the 12AU7 vacuum tubes in the output stage, HDCD decoding with Cary DSP-300 digital filter
    Digital Outputs (1) Balanced
    (1) Coaxial
    (1) Toslink
    Power Input 100-120 or 200-240 VAC, 50-60 Hz
    Finish Black or Silver Anodized Aluminum Faceplates, Black Epoxy Coated Steel Chassis, black anodized cone feet
    Weight 38 lbs
    Dimensions 4" H x 18" W x 15" D
  2. altecta7
    Hải phòng
    Mặt sau
    Phía sau
  3. altecta7
    Hải phòng
    Ruột gan
    Ruột gan
  4. altecta7
    Hải phòng
    Naim CDX2 CD player
    Em thứ hai Naim CDX2 CD player
    Specifications
    Frequency response
    10Hz – 20kHz + 0.1dB – 0.5 dB
    Output level
    2.1V rms at 1kHz
    Output impedance
    10 Ohms maximum
    Phase response
    Linear phase, absolute phase correct
    Laser type
    Semiconductor AIGaAs
    Wavelength
    780nm ± 20nm
    Light output (cw)
    Maximum 0.5 mW
    De-emphasis
    ± 0.1 dB referred to main response
    Distortion and noise
    <0.1% 10 Hz - 18 kHz at full level
    Mains supply
    100V, 115V, 230V (50 or 60Hz)
    Dimensions (H x W x D)
    87 x 432 x 314mm
    Finish
    Black
  5. altecta7
    Hải phòng
    Meridian 808 signiture reference cd player
    Em này thì khủng khiếp quá
    Technical Specification
    THD & Noise: Better than -96dBFS
    Mechanism: Triple-beam laser, multi-speed CD/DVD-ROM transport
    Converters: 192kHz-capable, 24-bit, Delta Sigma converters operating at 4 x CD sample rate (176.4kHz)
    Stereo Outputs: Analogue: 1 unbalanced on phono, 1 balanced on XLR-3M: 2.3V rms fixed/variable, Class A, 47R impedance. Digital S/PDIF (IEC60958): main coax with MHR plus auxiliary coax, operating at up to 2 x CD sample rate (88.2kHz), 24-bit
    Stereo Inputs: (808i only) Analogue: 6 unbalanced on phono. Digital S/PDIF: 3 coax and 2 Toslink optical
    Formats: CD Audio (CD-DA), CD-R, CD-R/W, MP3
    Comms: Two 5-pin 240¡ DIN sockets for Meridian Comms, and RS232 full remote/configuration interface. Three programmable 12v trigger outputs
    Construction: Black lacquer or satin silver finish in metal & glass
    Dimensions: 480mm (18.9in) x 175mm (6.9in) x 411mm (16.2in) (whd)
    Controls: Front-panel keys for Open/Close, Play, Stop, Pause, Previous, Next, On/Off. Additional controls behind hinged front access cover include Repeat, Fast Forward/Reverse, Display, Mute, Volume Up/Down, Store/Clear; Source. Full remote control via MSR+, RS232
    Display: 20-character dot matrix display with adjustable brightness and contrast. Indicators for Phase, Repeat and EQ (emphasis).
    Power: Universal power supply for 100-240Vac, 50/60Hz, 25W
  6. hiend-to-end
    hiend-to-end Advanced Member
    HANOI
    Em Meỉdian 808 ref có ở Việt Nam không bác?
    Em cám ơn.
  7. WireWorld
    WireWorld Advanced Member
    Hà nội
    Có chú Acc DP 87 (hàng second hand) ở cửa hàng Phát HP hôm qua em đi xem , thấy quát 3k , thấy tra trên audiohoanghai.com thì thấy ghi giá 6k , audiosonha thì thấy ghi 6.5k . Ko hiểu nổi nữa
  8. Jacky5555
    Jacky5555 Advanced Member
    Đây là nói giá mới, chứ VD Cary 303 giá 2ndhand chỉ hơn 1K thôi. Tầm 2K là mua được Cary 306 rồi.
  9. theloitran2001
    theloitran2001 Advanced Member
    Nếu là giá mới thì Meridian 508.24 cũng là một lựa chọn tốt giá cũ khoang 1500$
  10. thantainho
    thantainho Advanced Member
    HCMC
    Còn em Esoteric X-01 và X-03 thì hay không các bác, em thấy giá của em nó cũng cao ngất ngưỡng luôn ?
  11. StereoPhe
    StereoPhe Advanced Member
    Sài Gòn
  12. VITIEUBAO
    VITIEUBAO Advanced Member
    wadia 23 giá mới khoảng 3K bây giờ em thấy bán 1k múc được không các bác?
  13. theloitran2001
    Trong khoảng giá đó chơi được nếu máy còn tốt nhớ Text tracking xem phần cơ có chắc không?có bị nhảy tracking không?
  14. Planets
    Planets Advanced Member
    Re: Meridian 808 signiture reference cd player
    Hi hi. Chú này dùng ổ DVD-ROM làm bộ cơ, hay nhỉ. Không hiểu như vậy có hay bằng những máy dùng bộ cơ gấu không hả các bác?
  15. Nguyenanhson
    Nguyenanhson Advanced Member
    HI HI
    thế PHILIPS LHH700 có đựoc đứng trong dòng này không Hỉ
    Giá mới là 330.000 thì bàng bao nhiêu USD nhỉ! có ai biết tỷ giá USD/yên vào năm 1991 không các bác ơi!
    Bác nào đã nghe meridian 506 so vơi Philips LHH 700 thì thấy thế nào? cho em cia review tý nhỉ
  16. theloitran2001
    Philips LHH 700 của bạn mình đoán mò là cũng xếp cùng hạng đấy.nhưng Em này chắc tuổi xếp vào hạng U gì gì đấy còn mấy Em trên cùng thì nó Hạng 8x hay9x cơ.khaaaaaaaà
  17. Zorro
    Zorro Advanced Member
    Saigon
    Tỉ giá năm '91-'92 khoảng 120 yên/$.
    Em không biết LHH-700 sx ở đâu, em nghe nói hàng audio nhập khẩu vào JP phải chịu thuế 60%.
    Thân.
  18. Masterlazy
    Masterlazy Advanced Member
    Có mục CD dưới 1000 cho LHH-700 rồi cơ mà
  19. dunlopillo
    dunlopillo Advanced Member
    Các bác ơi. Muốn mua em Carry 303 hay Meridian 508 ở Hà Nội có không và chỗ nào bán hả các bác.
    Cảm ơn
  20. VITIEUBAO
    [glow=red]Bác theloitran hoặc bác nào đã dùng qua con này cho em xin tí ý kiến.[/glow]
  21. theloitran2001
    Con Wadia 23 này trước cũng trong tầm ngắm của mình,Nhưng dạo đó mình không tìm thấy để mua nên khônng có cơ hội nghe nó hót.Và mình nhớ không nhầm là giá họ bán trên AudioGon thấp nhất là 800$ và cao hơn là khoảng 1200$
  22. theloitran2001
  23. Nguyenanhson
    Hàng này sản xuất ở nhật và có dùng tụ lọc nguồn là Elna và Black gate bác ạ.
    Nếu đắt thế thì hơi quá nhỉ
  24. altecta7
    Hải phòng
    Sony SCD-777ES
    Không biết có bác nào chơi em này chưa nhỉ, có thể cho vài ý kiến góp ý??? Giá lúc ra lò là $3,500, rồi giảm xuống $3,000, còn bây giờ em mua là $1,500. Mới tinh.....
    Full Specifications
    Frequency Range 2-100,000 Hz, 2-50,000Hz (-3dB)
    Dynamic Range more than 105 dB (20-20,000 Hz)
    Total Harmonic Distortion less than 0.0012%
    Wow & Flutter Beneath measurable level (+/-0.001% weighted peak)
    Compact Disc:
    Frequency Response 2-20,000 Hz
    Dynamic Range more than 100 dB
    Total Harmonic Distortion less than 0.0017%
    Wow & Flutter beneath measurable level (+/-0.001% weighted peak)
    Features Disc Capacity 1
    Disc Mechanism Tray
    CD Text Yes
    Display Fluorescent
    Audio Output Hi-Fi stereo
    DAC Type Low Speed Multi Bit
    Playback Modes Program play, Program repeat, All tracks repeat, One track repeat
    Color Black
    Additional Features Super Audio CD compatible, Gold plated connectors
    Connectors Digital Coaxial Connectors 1 x SPDIF output ( RCA phono ) - rear
    Digital Optical Connectors 1 x SPDIF output ( TOS Link ) - rear
    RCA Connectors 1 x audio line-out ( RCA phono x 2 ) - rear
    Other Connectors Total (Free) / Type - rear, - rear
    Accessories Remote Control Included
    General Product Info Base Warranty 5 years warranty
    Warranty Information 5 years warranty
    Weight 55.12 lbs
    Manufacturer Part No. SCD-777ES
    Company Info Sony
    Technical Support URL http://www.sel.sony.com/SEL/service/
    Dimension 5.9 in x 16.9 in x 17.2 in (HxWxD)
  25. Rainbow
    Rainbow Advanced Member
    Đà Nẵng
    Trước đây em cũng đã có cơ hội được nghe con này rùi, cùng chơi với Altec Duplex 904-8A. Tiếng bay bổng thánh thót, âm hình rộng và sáng. Nhưng một điều chưa thích là size nhỏ, phần nhìn chưa đẳng cấp xứng với chất âm.
    Lúc đó, em cũng mê em này lắm, đã trả đến 1100$ nhưng khổ chủ không bán
    Em đề cử thêm một chú CEC TL-3. Giá năm 1999 tại Đức là 7000 Mác Đức. Không biết lúc đó qui đổi ra USD là bao nhiêu nhỉ?
