quê quá chả hiểu em nghe thế nào thành 1.2 . vừa kiểm tra lại thông tin là có dynaudio coutour 1.3 mkII ,hehe
Chúc mừng bác nhé, như vậy là đã chọn được loa hợp nhĩ rồi. PE- LEON luôn được đánh giá rất cao, dù bất kỳ model nào. Em sẽ liên hệ về cặp P.L MKiii theo chỉ dẫn của bác. Cảm ơn bác thật nhiều.
có Bạn nào xài qua cái Klipsch RB61 (dòng loa RB của Klipsch) hay cái Studio monitor 350 của Definitive nì chưa ? tính chọn em nì về để chơi nhạc mạnh và hát O.K Thanks ------------- Klipsch RB61 Because compromise isn't an option, the Reference Series RB-61 lets listeners experience all the power, detail, and emotion of cinematic spectacles and riveting concert performances in the comfort and privacy of their own home. With its superior technology and elegant design, this speaker definitely stands out in a crowd. Witness the demise of compromise. Power Handling: 100 W Maximum Continuous (400 W Peak) Nominal Impedance: 8 Ohms Compatible Tweeter: 1 Inch Titanium Diaphragm Compression Driver High Frequency Horn: 6-Inch Square Tractrix Horn (90 Degree Horizontal x 60 Degree Vertical Dispersion) Woofer: One 6.5-Inch Cerametallic Cone/Cast Polymer Frame Crossover Frequency: 2000Hz Frequency Response: 43Hz-23kHz +/-3dB Sensitivity: 95 dB @ 2.83 Volts/1 Meter Enclosure: Bass Reflex Via Front-Firing Port, MDF (Medium Density Fiberboard) Input Connections: 2 Sets Of Binding Post Speaker Terminals (Connected Via Brass Strap Jumpers) Bottom Mount Via Dual 1/4" Threaded Inserts For Stand Attachment Video-Shielded Magnets 15.4" H x 8.5" W x 12.25" D 22 Lbs. ------------- Studio monitor 350 The StudioMonitor 350 is a high-definition full-range speaker with extended low-frequency characteristics that enable it to sound excellent by itself as well as blending better with a subwoofer and delivering dramatically better sound than would more limited-range satellite speakers. Recommended amplifier power: 20 - 180 watts Nominal impedance: compatible with 4 - 8 ohms 1" pure aluminum dome tweeter 5.25" cast-basket polymer coned bass/midrange driver 8" pressure-driven bass radiator Non-resonant monocoque cabinet Magnetically shielded Elegant piano-gloss black lacquer endcap/wraparound grill cloth Efficiency: 90 dB Frequency response: 26 Hz - 30 kHz Dimensions: 6.94" W x 10.69" H x 9.69" D
Em vote cho con Totem Mani 2 signature. Em thích nhất tiếng mid và khả năng trình diễn của em này, quá tuyệt. Có điều phải có amp khỏe một chút mới chơi tốt. Ở Sài Gòn đang có hàng đấy bác. http://www.totemacoustic.com/vn/product ... fications/
Dyn special 25 em chưa có dịp nghe nên không có ý kiến, nhưng so với dyn contour 1.3se em từng nghe thì totem đẳng cấp hơn nhiều
Cho em hỏi giá cặp Totem Mani 2 signature là bao nhiêu ? Tại Sài gòn có hàng là của CH nào hay ai định bán ạ ?
Tôi đã nghe Dynaudio 25, quá tuyệt vời, không có gì phải bàn,đều cả 3 giải, trung âm rất êm và mở, trung trầm đầy đặn..rất rất hay, chỉ phải cái giá hơi cao.Totem cũng dùng củ loa của Dynaudio. Nếu có $ tôi sẽ mua ngay Dynaudio 25.Chúc bác vui.
Các biết có biết ở sài gòn ai sài Dyn 25 không vậy? Có chỗ nào bán không các bác? và giá bây giờ cỡ bảo nhiêu các bác nhỉ? Chân thành cám ơn các bác
Theo review của tạp chí nghe nhìn VN thì loa này giá 4900$ ,và...vẫn được coi là giá hời đó bác(!) Ở Sg thì có công ty Ưu điểm gì đó phân phối loa này mà.
Dynaudio Special 25 giờ ở Hoàng Hải bán giá hơn 5.000$, theo em thì loa này chắc được xếp vào một trong những đôi loa cực dở trong tầm giá nên chả thấy ai chơi thì phải :lol:. Năm ngoái thấy niêm yết giá hơn 3.000$, chắc các bác bàn tán ghê quá nên giá nó lên không kiểm soát như vỡ ống dẫn dầu :lol:
